nRF9160 GPS Hard Fault
I am having an issue with the GPS on the nRF9160. I have been developing a custom program that will switch between NB-IoT and GPS when an interrupt pin is triggered. This code has all been tested in isolation and modulised into various source code files.
When the modules are brought together, the code works but only for a while. Eventually the code will hard fault when switching to GPS mode. To be clear, it is not the act of calling the GPS socket set-up but after the socket is initialised and the first 'scanning' line is printed. The hard fault can occur at the very first activation of the GPS, or the second, or the third, etc. it is not specific to any one call of the GPS module.
I have noticed that in the sample GPS program, there is a k_sleep() function placed in the main while loop that controls the scan frequency of the GPS. When this function is manipulated to increase the amount of milliseconds waited between cycles, the device will hardfault immediately after the GPS is initialised. This is leading me to believe my issue lies with this aspect of the GPS code.
From my own tests in my code, manipulating k_sleep(); has lead to more GPS cycles being completed before a hard fault occurs in the device.
For 3 tests across each k_sleep(), 1 full cycle is NB-IoT -> GPS -> NB-IoT without fault
At k_sleep() set to 50 milliseconds: cycles complete 4/6/6 before fault
At k_sleep() set to 100 milliseconds: cycles complete 6/1/6 before fault
At k_sleep() set to 250 milliseconds: cycles complete 3/6/2 before fault
At k_sleep() set to 500 milliseconds: cycles complete 2/3/1 before fault
At k_sleep() set to 750 milliseconds: cycles complete 1/2/2 before fault
At k_sleep() set to 900 milliseconds: cycles complete 3/1/1 before fault
At k_sleep() set to 1000 milliseconds: cycles complete 0/0/0 before fault
Note: Never could seem to get past 6 cycles before a fault (tried 50 milliseconds 10 times and 6 was the highest I could get to), may be a different issue or just bad luck but main issue here isn't related to the number of cycles the code does.
I am not able to show my current code publicly but the k_sleep(); I am referring to can be found on line 302 of the main gps sample code, manipulating that will cause my code to fault faster or slower. github.com/.../main.c
Terminal output for k_sleep() at 500millseconds:
***** Booting Zephyr OS v1.14.99-ncs1 *****
Flash region		Domain		Permissions
00 0x00000 0x08000 	Secure		rwxl
01 0x08000 0x10000 	Non-Secure	rwxl
02 0x10000 0x18000 	Non-Secure	rwxl
03 0x18000 0x20000 	Non-Secure	rwxl
04 0x20000 0x28000 	Non-Secure	rwxl
05 0x28000 0x30000 	Non-Secure	rwxl
06 0x30000 0x38000 	Non-Secure	rwxl
07 0x38000 0x40000 	Non-Secure	rwxl
08 0x40000 0x48000 	Non-Secure	rwxl
09 0x48000 0x50000 	Non-Secure	rwxl
10 0x50000 0x58000 	Non-Secure	rwxl
11 0x58000 0x60000 	Non-Secure	rwxl
12 0x60000 0x68000 	Non-Secure	rwxl
13 0x68000 0x70000 	Non-Secure	rwxl
14 0x70000 0x78000 	Non-Secure	rwxl
15 0x78000 0x80000 	Non-Secure	rwxl
16 0x80000 0x88000 	Non-Secure	rwxl
17 0x88000 0x90000 	Non-Secure	rwxl
18 0x90000 0x98000 	Non-Secure	rwxl
19 0x98000 0xa0000 	Non-Secure	rwxl
20 0xa0000 0xa8000 	Non-Secure	rwxl
21 0xa8000 0xb0000 	Non-Secure	rwxl
22 0xb0000 0xb8000 	Non-Secure	rwxl
23 0xb8000 0xc0000 	Non-Secure	rwxl
24 0xc0000 0xc8000 	Non-Secure	rwxl
25 0xc8000 0xd0000 	Non-Secure	rwxl
26 0xd0000 0xd8000 	Non-Secure	rwxl
27 0xd8000 0xe0000 	Non-Secure	rwxl
28 0xe0000 0xe8000 	Non-Secure	rwxl
29 0xe8000 0xf0000 	Non-Secure	rwxl
30 0xf0000 0xf8000 	Non-Secure	rwxl
31 0xf8000 0x100000 	Non-Secure	rwxl
SRAM region		Domain		Permissions
00 0x00000 0x02000	Secure		rwxl
01 0x02000 0x04000	Secure		rwxl
02 0x04000 0x06000	Secure		rwxl
03 0x06000 0x08000	Secure		rwxl
04 0x08000 0x0a000	Secure		rwxl
05 0x0a000 0x0c000	Secure		rwxl
06 0x0c000 0x0e000	Secure		rwxl
07 0x0e000 0x10000	Secure		rwxl
08 0x10000 0x12000	Non-Secure	rwxl
09 0x12000 0x14000	Non-Secure	rwxl
10 0x14000 0x16000	Non-Secure	rwxl
11 0x16000 0x18000	Non-Secure	rwxl
12 0x18000 0x1a000	Non-Secure	rwxl
13 0x1a000 0x1c000	Non-Secure	rwxl
14 0x1c000 0x1e000	Non-Secure	rwxl
15 0x1e000 0x20000	Non-Secure	rwxl
16 0x20000 0x22000	Non-Secure	rwxl
17 0x22000 0x24000	Non-Secure	rwxl
18 0x24000 0x26000	Non-Secure	rwxl
19 0x26000 0x28000	Non-Secure	rwxl
20 0x28000 0x2a000	Non-Secure	rwxl
21 0x2a000 0x2c000	Non-Secure	rwxl
22 0x2c000 0x2e000	Non-Secure	rwxl
23 0x2e000 0x30000	Non-Secure	rwxl
24 0x30000 0x32000	Non-Secure	rwxl
25 0x32000 0x34000	Non-Secure	rwxl
26 0x34000 0x36000	Non-Secure	rwxl
27 0x36000 0x38000	Non-Secure	rwxl
28 0x38000 0x3a000	Non-Secure	rwxl
29 0x3a000 0x3c000	Non-Secure	rwxl
30 0x3c000 0x3e000	Non-Secure	rwxl
31 0x3e000 0x40000	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0		Non-Secure	OK
01 NRF_CLOCK		Non-Secure	OK
02 NRF_RTC1		Non-Secure	OK
03 NRF_NVMC		Non-Secure	OK
04 NRF_UARTE1		Non-Secure	OK
05 NRF_UARTE2		Secure		SKIP
06 NRF_IPC		Non-Secure	OK
07 NRF_VMC		Non-Secure	OK
08 NRF_FPU		Non-Secure	OK
09 NRF_EGU1		Non-Secure	OK
10 NRF_EGU2		Non-Secure	OK
11 NRF_TWIM2		Non-Secure	OK
12 NRF_SPIM3		Non-Secure	OK
13 NRF_TIMER0		Non-Secure	OK
14 NRF_TIMER1		Non-Secure	OK
15 NRF_TIMER2		Non-Secure	OK
16 NRF_SAADC		Non-Secure	OK
17 NRF_GPIOTE1		Non-Secure	OK
SPM: NS image at 0x8000
SPM: NS MSP at 0x20023bd8
SPM: NS reset vector at 0xf3e1
SPM: prepare to jump to Non-Secure image.
Application Started
Setting up button interrupt
Interrupt Setup Started
Starting up into NB-IoT mode
Opening AT Command Socket
Socket ID: 2
Sending AT command: AT+CFUN=4
Modem response: OK
Bytes received: 5
Sending AT command: AT%XSYSTEMMODE=0,1,0,0
Modem response: OK
Bytes received: 5
Sending AT command: AT%XMAGPIO
Modem response: OK
Bytes received: 5
Sending AT command: AT+CFUN=1
Modem response: OK
Bytes received: 5
Waiting for interrupt
State was: 0!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Sending AT command: AT%XSYSTEMMODE=0,0,1,0
Modem response: OK
Bytes received: 5
Sending AT command: AT%XMAGPIO=1,0,0,1,1,1574,1577
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Socket ID 0
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket ID 1232491587
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix 0
Scanning [|] Tracking: 0 Using: 0 Unhealthy: 0
Scanning [/] Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix 1
Scanning [-] Tracking: 0 Using: 0 Unhealthy: 0
Scanning [\] Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix 2
Seconds since last fix 3
Seconds since last fix 4
Seconds since last fix 5
Seconds since last fix 6
Seconds since last fix 7
Seconds since last fix 8
Seconds since last fix 9
Seconds since last fix 10
Scanning [|] State was: 1!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Scanning [/] State was: 1!
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Scanning [\] State was: 1!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Seconds since lException occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x200207bc
Faulting instruction address = 0x18860
Fatal fault in ISR! Spinning...
What is the purpose behind the k_sleep() function and is there a way to avoid this issue?
EDIT:
Just to demonstrate the GPS code is functioning as expected before the fault and is capable of acquiring locks (including faster locks after the first cycle) after each interrupt trigger.
4 cycles at 500milliseconds:
Application Started
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
State was: 0!
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Socket ID 0
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Scanning [-] Tracking: 2 Using: 0 Unhealthy: 0
Seconds since last fix 70
Scanning [\] Tracking: 2 Using: 0 Unhealthy: 0
Seconds since last fix 71
Scanning [|] Tracking: 2 Using: 0 Unhealthy: 0
Scanning [/]
Longitude:  xxxxxxxxx
Latitude:   xxxxxxxxx
Altitude:   242.866547
Speed:      0.684508
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:36
Latitude:   xxxxxxxxx
Altitude:   246.341095
Speed:      0.822424
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:37
Latitude:   xxxxxxxxx
Altitude:   247.054871
Speed:      0.377199
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:38
Latitude:   xxxxxxxxx
Altitude:   247.381271
Speed:      0.269779
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:39
Latitude:   xxxxxxxxx
Altitude:   240.506256
Speed:      1.033744
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:40
Latitude:   xxxxxxxxx
Altitude:   235.055313
Speed:      0.748148
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:41
Latitude:   xxxxxxxxx
Altitude:   227.877075
Speed:      0.343569
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:36:42
Latitude:   xxxxxxxxx
Altitude:   221.145142
Speed:      4.401939
Heading:    350.317108
Date:       26-06-2019
Time (UTC): 08:36:44
---------------------------------State was: 1!
Interrupt tripped!
State is now: 2!
State was: 2!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Latitude:   xxxxxxxxx
Altitude:   223.007477
Speed:      3.782128
Heading:    334.088593
Date:       26-06-2019
Time (UTC): 08:36:45
Latitude:   xxxxxxxxx
Speed:      3.782128
Heading:    334.088593
Date:       26-06-2019
Tracking: 1 Using: 0 Unhealthy: 0
Seconds since last fix 13
Latitude:   xxxxxxxxx
Speed:      3.782128
Heading:    334.088593
Date:       26-06-2019
Latitude:   xxxxxxxxx
Altitude:   198.201843
Speed:      0.223694
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:08
Latitude:   xxxxxxxxx
Altitude:   198.263840
Speed:      0.748227
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:09
Latitude:   xxxxxxxxx
Altitude:   199.827469
Speed:      0.349585
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:10
Latitude:   xxxxxxxxx
Altitude:   202.830643
Speed:      0.650090
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:11
Latitude:   xxxxxxxxx
Altitude:   209.262085
Speed:      1.462613
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:12
Latitude:   xxxxxxxxx
Altitude:   208.257874
Speed:      0.538839
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:13
Interrupt tripped!
State is now: 2!
State was: 2!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Latitude:   xxxxxxxxx
Altitude:   203.780716
Speed:      1.157283
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:14
Latitude:   xxxxxxxxx
Speed:      1.157283
Heading:    0.000000
Date:       26-06-2019
Seconds since last fix 11
Latitude:   xxxxxxxxx
Speed:      1.157283
Heading:    0.000000
Date:       26-06-2019
Latitude:   xxxxxxxxx
Altitude:   152.475311
Speed:      0.275427
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:38
Latitude:   xxxxxxxxx
Altitude:   159.553726
Speed:      0.693830
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:39
Latitude:   xxxxxxxxx
Altitude:   160.570663
Speed:      0.210465
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:40
Latitude:   xxxxxxxxx
Altitude:   171.190094
Speed:      0.432191
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:41
Latitude:   xxxxxxxxx
Altitude:   177.033356
Speed:      0.419606
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:42
Latitude:   xxxxxxxxx
Altitude:   177.022202
Speed:      0.802719
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:43
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Latitude:   xxxxxxxxx
Altitude:   181.266068
Speed:      0.912318
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:37:44
Latitude:   xxxxxxxxx
Speed:      0.912318
Heading:    0.000000
Date:       26-06-2019
Seconds since last fix 15
Latitude:   xxxxxxxxx
Speed:      0.912318
Heading:    0.000000
Date:       26-06-2019
Latitude:   xxxxxxxxx
Altitude:   165.880707
Speed:      1.194079
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:38:12
Latitude:   xxxxxxxxx
Altitude:   162.105804
Speed:      1.189136
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:38:13
Latitude:   xxxxxxxxx
Altitude:   167.254166
Speed:      0.673746
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:38:14
Latitude:   xxxxxxxxx
Altitude:   165.867783
Speed:      0.253062
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:38:15
Latitude:   xxxxxxxxx
Altitude:   162.832489
Speed:      0.260593
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:38:16
Latitude:   xxxxxxxxx
Altitude:   165.063126
Speed:      0.323328
Heading:    0.000000
Date:       26-06-2019
Time (UTC): 08:38:18
Interrupt tripped!
State is now: 2!
State was: 2!
Interrupt tripped!
State is now: 2!
Shutting down GPS
Enabling NB-IoT
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Entering idle mode
State was: 0!
Interrupt tripped!
State is now: 1!
State was: 1!
Interrupt tripped!
State is now: 1!
Socket ID: 2
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
Modem response: OK
Bytes received: 5
NRF_AF_LOCAL 1
NRF_SOCK_DGRAM 2
NRF_PROTO_GNSS 516
Socket created
Fix retry err: 0
Fix interval err: 0
nmea mask err: 0
GPS start err: 0
Current thread ID = 0x20020710
MJD093
