UARTE can't receive data
I've been playing around with the UART drivers on SDK 15.2.  No issues with the Legacy (w/DMA) however I've tried switching over the NRFX_UARTE driver and I can't get the driver to Recieve data.  The Rx Event is never called in the handler, nor does nrfx_uarte_rx_ready() ever return true?   The only real difference in the driver API's is the legacy driver has the nrf_drv_uart_rx_enable(.) call which isn't in the NRFX_UARTE module.  Is there anything I could have missed that would prevent data receiving on this driver?
p.s. in the sdk_config file I did enabled NRFX_UARTE and NRFX_UARTE0.  Also commented out the Legacy #defines as per requirements for other drivers
    Can you post the code you used for configuring UARTE, and setting up the transfers? I'm not sure what the purpose of the function nrfx_uarte_rx_ready() is in the driver, to me it seems that using this function only makes sense to use together with nrfx_uart_rx_enable() in the legacy UART driver for polling UART.
    Jørgen
  • static nrfx_config_t my_uart_config = NRFX_UARTE_DEFAULT_CONFIG
    err_code = nrfx_uarte_init( &mu_uarte,
    &my_uarte_config ,
    my_uarte_event_handler );
    nrfx_uarte_rx( &my_uart,
    (uint8_t*)my_uart_rx_buffer_assigned,
    UART_RX_BUF_SIZE);
    With this code, the my_uarte_event_handler is never called.  I've checked that the pin assignment is correct in the board file, and I've disabled flow control
  • Did you set the pins in the config? By default, these are set to NRF_UARTE_PSEL_DISCONNECTED.
    I tested this similar code, and I'm able to receive data in the event handler:
    #define UART_RX_BUF_SIZE 10
    static uint8_t my_uart_rx_buffer_assigned[UART_RX_BUF_SIZE] = {0x00};
    static void my_uarte_event_handler(nrfx_uarte_event_t const * p_event,
                                  void *                     p_context)
        if(p_event->type == NRFX_UARTE_EVT_RX_DONE)
            memset(my_uart_rx_buffer_assigned, 0x00, UART_RX_BUF_SIZE);
        nrfx_uarte_t instance = NRFX_UARTE_INSTANCE(0);
        static nrfx_uarte_config_t my_uarte_config = NRFX_UARTE_DEFAULT_CONFIG;
        my_uarte_config.pselrxd = 8;
        my_uarte_config. pseltxd = 6;
        ret_code_t err_code = nrfx_uarte_init( &instance, &my_uarte_config ,  my_uarte_event_handler );
        err_code = nrfx_uarte_rx( &instance,
        UART_RX_BUF_SIZE);
        while (true)
            __WFE();
