How do you put the nrf51822 chip to sleep?
I am wondering how you put the nrf51822 chip to sleep. I've determined that the way to do this with the soft device is sd_app_event_wait() in the while loop. What about non-softdevice?
I am wanting to have it sleep until woken by interrupts, then sleep again. In another example, I found __wfi() used. Also, __WFI(). Neither seem to do anything, though.
Thanks!
  • Just curious but what happens if there is some event happening in between two __WFE() you mentioned. To guarantee this I am thinking that we need to set SEVONPEND = 0 in ARM system control register.
  • This is not the solution for every situation and please do not copy it without understanding. Clearing event flag just before the WFE that should actually wait for event basically doest the same what WFI instruction. WFI instruction is not safe because it would not wake up the system when interrupt happens just before its call. You may call WFE(); SEV(); WFE(); processing(); Now you are sure that you clear event flag that was set in any interrupts just before processing all the events in the main loop. Single WFE should also clear the flag but it may be set again if there would be many interrupts processing just after system wake-up.
    If you do not clear the event flag your main loop may be processed more times you expect. Just thing twice before you clear event flag: in worst case you may lost information about event that should be processed.
  • I agree what Radoslaw says. I think the correct order should be __WFE(); __SEV(); __WFE(); This way we make sure that the first __WFE does not sleep if the event just happened before calling it. The other way would just clear that event, which is not a problem if this is called in loop inside main. But it will be problem if it is called in different priority context.
1 2 3
