It was mentioned before that the compiler_abstraction.h file for gcc produces this error sequence when -std=c99
is selected:
In file included from /prj/arm/nrf51-sdk/components/drivers_nrf/hal/nrf.h:44:0,
from /prj/arm/nrf51-sdk/components/toolchain/system_nrf51.c:36:
/prj/arm/nrf51-sdk/components/drivers_nrf/hal/compiler_abstraction.h: In function 'gcc_current_sp':
/prj/arm/nrf51-sdk/components/drivers_nrf/hal/compiler_abstraction.h:85:30: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'asm'
register unsigned sp asm("sp");
/prj/arm/nrf51-sdk/components/drivers_nrf/hal/compiler_abstraction.h:85:30: error: implicit declaration of function 'asm' [-Werror=implicit-function-declaration]
/prj/arm/nrf51-sdk/components/drivers_nrf/hal/compiler_abstraction.h:86:16: error: 'sp' undeclared (first use in this function)
return sp;
/prj/arm/nrf51-sdk/components/drivers_nrf/hal/compiler_abstraction.h:86:16: note: each undeclared identifier is reported only once for each function it appears in
Since that file carefully defines __ASM
to the toolchain-specific spelling, please use that instead of asm
in the immediately following inline function, viz:
static inline unsigned int gcc_current_sp(void)
register unsigned sp __ASM("sp");
return sp;
Switching to -std=gnu99
is not really satisfactory to me, since it causes the inline
keyword to be implemented in a non-conforming way. Using -std=c99
helps ensure code is more portable.
Thanks.
