ECDSA signature reproducibility
Our device is based on nRF52840 with SDK 15.0.0
The device communicates over BLE with PC application (aka client) via "uart" service.
PC (client) messages are signed using ECDSA with secp265r1 curve and the device verifies the signature of received messages before processing them.
PC side  ECDSA implementation is based on Org.BouncyCastle.Asn1.Sec package for C#.
Device side ECDSA implementation is almost identical to ecdsa example (Bob's verification).
Verification alway failed on execution backend implementation with error code 34070  - invalid signature despite I used private and public keys from ecdsa example.
Any ideas?
Moreover I ran ecdsa example from SDK on Nordic's DK PCA10056 and just put alice sign and bob verification in a loop.
Each cycle (see below output) I got different signature but bob's verification pass.
Is that makes sense?
<info> app: ECDSA example started.
<info> app: Alice's signature generation
<info> app: Alice's message hash:
42BA8354DB263A6A5A9F74D6B7CEB4C962A3D8FD58A41969E521EB0222455415
<info> app: Alice's signature:
000F05AD9269E25050B05BB4754C480C66A515650C63863C12A4D6634F04580490DCE86B7CED05C526202A412A7F4D7CD586F768B5FBA0592EAF56A63E7C0320
<info> app: Bob's message verification
<info> app: Signature is valid. Message is authentic.
EECEF1BF8D3CFA84EB748DE4990B14B832BD383ADB4C9B2D5C51AEA7DF0E91DD13B39228BE460A5D6163514B8C7F63A8FF476D9E062BD0E7A50F87DE00AA5BAB
D423EDD1F6ABA0B6213380DA51794A6B724D7F3DFC351AD881DFDD4B86B8348EEAFEC7E0CFCFCA3C64C774E03470A96573E4358FDC873B7F7CDE086241DF89D6
8AF1749C0B605995C7F18E30A68D78D43AD41431174683AF8CDDD89C2105441EB5D00A215FDDF5ACB6AC0D8C465271716819D594F78B5976B3B74759463AED93
03A29A6A08F02E8282AD210CA44253B1D15C66E8194FA27F4EB45D3F6171C65CBB8A7311D1A9CC436F13EBFA7AC3BED3C1C3C365682AEBF2138A28065761A42B
<info> app: ECDSA example executed successfully.
  • The reason for different signatures is the random number which is generated for each cycle as part of the Alice's signing process
    Have you double checked that you use the correct curve in both ends, and that you have not introduced any errors when copying the keys e.g. due to endianness or how they are otherwise encoded?
    Terje
  • Regarding curve both sides is configured to secp256r1 curve
    PC side:
    private static ECDsa LoadPrivateKey(byte[] key)
    var privKeyInt = new Org.BouncyCastle.Math.BigInteger(+1, key);
    var parameters = SecNamedCurves.GetByName("secp256r1");
    var ecPoint = parameters.G.Multiply(privKeyInt);
    var privKeyX = ecPoint.Normalize().XCoord.ToBigInteger().ToByteArrayUnsigned();
    var privKeyY = ecPoint.Normalize().YCoord.ToBigInteger().ToByteArrayUnsigned();
    var d = privKeyInt.ToByteArrayUnsigned();
    return ECDsa.Create(new ECParameters
    Curve = ECCurve.NamedCurves.nistP256,
    D = privKeyInt.ToByteArrayUnsigned(),
    Q = new ECPoint
    X = privKeyX,
    Y = privKeyY
    for device side:
    /*static*/ bool
    bIsValidSignature(const uint8_t* a_ipHashMessage, const uint8_t* a_ipSignature, uint8_t* a_ipEcdsaPublicKey)
    // Brief: verify signature
    // Get: a_ipHashMessage - message
    // a_ipSignature - signature
    // a_ipEcdsaPublicKey - public key
    // Return: true if successful, false otherwise
    // Pre: -
    // Post: signature verified
    // Method: Trivial
    // swap endian
    uint8_t l_iaPkCopy[d_iAuthPubKeySize];
    nrf_crypto_internal_double_swap_endian(l_iaPkCopy, a_ipEcdsaPublicKey, d_iAuthPubKeySize / 2);
    // ecc public key from raw
    nrf_crypto_ecc_public_key_t l_uPublicKey;
    if (NRF_SUCCESS != nrf_crypto_ecc_public_key_from_raw(&g_nrf_crypto_ecc_secp256r1_curve_info, &l_uPublicKey, l_iaPkCopy, d_iAuthPubKeySize))
    LOG_WARNING(LOG_PRINT_CRYPTO, "Crypto - verify signature - failed - ecc public key from raw");
    return false;
    // verify the message using ECDSA and SHA-256
    if (NRF_SUCCESS != nrf_crypto_ecdsa_verify(NULL, &l_uPublicKey, a_ipHashMessage, d_iAuthHashSize, a_ipSignature, d_iAuthSigLen))
    LOG_WARNING(LOG_PRINT_CRYPTO, "Crypto - verify signature - failed - ECDSA verify");
    return false;
    return true;
    Regarding endianness:
    Device code swaps it before verifying
    PC run on Win 10 which is little endian
