nrf52832 S132 v6.1.1
i want to write saadc data in flash, so i call "write_to_flash" function in "void saadc_callback(nrf_drv_saadc_evt_t const * p_event)"
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
int product;
uint16_t val;
uint8_t value;
ret_code_t err_code;
product = channel3_enabled*8 + channel2_enabled*4 + channel1_enabled*2 + channel0_enabled;
static uint8_t data_array[SAMPLES_IN_BUFFER*2];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
uint8_t i;
printf("\r\nADC event number:%d \r\n", (int)m_adc_evt_counter);
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
data_array2[i]=p_event->data.done.p_buffer[i];
val = p_event->data.done.p_buffer[i];
printf("%d\r\n",val);
sizeof(data_array3) is 240, so every record in flash is 60 words,
virtual page is 3;
virtual page size 1024;
then i stop adc and read data when flash is full, i get 32 records ,every record only contains 16 or 19 or ......words ,less than 60 words.
if everythng is correct, i can get 32 records and 60 words in every record;
the following is my read_from_flash() function
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
void read_from_flash()
//±£´æÃØÔ¿µÄÁîÅÆÇåÁã
fds_find_token_t tok = {0};
ret_code_t rc;
rc = fds_record_find(CONFIG_FILE, CONFIG_REC_KEY, &desc, &tok);//¶ÔÓ¦KEY¼Ç¼²éÕÒÊý¾Ý
NRF_LOG_INFO("record_id:%8x",desc.record_id);
NRF_LOG_INFO("p_record:%8x",desc.p_record);
if (rc == FDS_SUCCESS)
/* A config file is in flash. Let's update it. */
fds_flash_record_t config = {0};
/* Open the record and read its contents. */
rc = fds_record_open(&desc, &config);
APP_ERROR_CHECK(rc);
NRF_LOG_INFO("Found Record ID = %d",desc.record_id);
NRF_LOG_INFO("Data = ");
data = (uint32_t *)config.p_data;
static uint8_t data_array_send[4];
it's called by a timer.
so what's the problem about "read data less than written data" ?
Any suggestion will be appreciated.
