I am receiving an error when I try to update my custom characteristic in a custom service, which was all working fine until I started playing with app_timer to read battery level every 10 seconds (which I think uses RTC1).
If you see the call stack error below you can see RTC1IRQHandler() function is called first. I have been mucking around with the battery level service (which uses RTC1 I think) which works when not connected. But as soon as I connect and I try to read or write to the custom characteristic in the (custom) service I receive this error.
main.c
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "nrf_soc.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_bas.h"
#include "ble_conn_params.h"
//softdevice handler files
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_util.h"
#include "nordic_common.h"
#include "boards.h"
#include "app_timer.h"
#include "nrf_drv_clock.h" //rtc driver
#include "nrf_drv_saadc.h" //saadc driver
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "ble_advertising.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "fds.h"
#include "nrf_sdm.h"
#include "ble_dis.h"
#include "app_scheduler.h"
#include "ble_conn_state.h"
#include "ble_gap.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "SEGGER_RTT.h"
#include "ble_cus.h"
#define DEVICE_NAME "Front_Garden" /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO 2 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define BATTERY_LEVEL_MEAS_INTERVAL APP_TIMER_TICKS(10000) /**< Battery level measurement interval (ticks). This value corresponds to 120 seconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(10000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS 600 /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
#define ADC_PRE_SCALING_COMPENSATION 6 /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS 270 /**< Typical forward voltage drop of the diode . */
#define ADC_RES_10BIT 1024 /**< Maximum digital value for 10-bit ADC conversion. */
#define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define BLE_ADV_WHITELIST_ENABLED true
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define APP_ADV_FAST_INTERVAL 0x0028 /**< Fast advertising interval (in units of 0.625 ms. This value corresponds to 25 ms.). */
#define APP_ADV_SLOW_INTERVAL 0x00A0 /**< Slow advertising interval (in units of 0.625 ms. This value corresponds to 200 ms.). */
#define APP_ADV_FAST_DURATION 5000 /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION 10000 /**< The advertising duration of slow advertising in units of 10 milliseconds. */
static uint8_t m_custom_value = 0;
static uint8_t pm_paired = 0;
static uint8_t connectedToClient = 0;
/**@brief Macro to convert the result of ADC conversion in millivolts.
* @param[in] ADC_VALUE ADC result.
* @retval Result converted to millivolts.
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)
//BLE_LBS_DEF(m_lbs); /**< LED Button Service instance. */
//APP_TIMER_DEF(m_our_char_timer_id);
APP_TIMER_DEF(m_battery_timer_id); /**< Battery measurement timer. */
//APP_TIMER_DEF(m_notification_timer_id);
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_BAS_DEF(m_bas); /**< Battery service instance. */
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
BLE_CUS_DEF(m_cus); /**< Context for the Queued Write module.*/
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static pm_peer_id_t m_peer_id; /**< Device reference handle to the current bonded central. */
static bool m_in_boot_mode = false; /**< Current protocol mode. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded scan data. */
static void on_bas_evt(ble_bas_t * p_bas, ble_bas_evt_t * p_evt);
static nrf_saadc_value_t adc_buf[2];
// OUR_JOB: Step 3.G, Declare an app_timer id variable and define our timer interval and define a timer interval
//#define OUR_CHAR_TIMER_INTERVAL APP_TIMER_TICKS(120000) // 1000 ms intervals
// STEP 1: Declare a ble_os_t service structure for our application
//ble_os_t m_our_service;
//Step 5: Declare variable holding our service UUID
static ble_uuid_t m_adv_uuids[] =
{CUSTOM_SERVICE_UUID,BLE_UUID_TYPE_VENDOR_BEGIN}
static void advertising_start(bool erase_bonds);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
ret_code_t err_code;
// Increment the value of m_custom_value before nortifing it.
m_custom_value++;
err_code = ble_cus_custom_value_update(&m_cus, m_custom_value);
// ALREADY_DONE_FOR_YOU: This is a timer event handler
static void timer_timeout_handler(void * p_context)
// OUR_JOB: Step 3.F, Update temperature and characteristic value.
int32_t temperature = 0;
static int32_t previous_temperature=0; //Declare a variable to store current temperature until next measurement.
sd_temp_get(&temperature);
float floatNumber = (float) temperature/4.0;
int intPart = (int) floatNumber;
int decimalPart = (floatNumber - intPart) * 10;
char strtemp[5];
snprintf(strtemp,sizeof(strtemp),"%d.%d",intPart,decimalPart);
// Check if current temperature is different from last temperature
SEGGER_RTT_printf(0,"The temperature is %s\n", strtemp);
// the below if statement is used to update the custom service characteristic. We don't wan't this as it is being used for the tap switch
// if(temperature != previous_temperature)
// // If new temperature then send notification
// //uint8_t tmp = &temperature;
// ble_cus_custom_value_update(&m_cus, (uint8_t) &temperature);
// Save current temperature until next measurement
previous_temperature = temperature;
//nrf_gpio_pin_toggle(LED_4);
/**@brief Function for assert macro callback.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for setting filtered whitelist.
* @param[in] skip Filter passed to @ref pm_peer_id_list.
static void whitelist_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
ret_code_t err_code = pm_peer_id_list(peer_ids, &peer_id_count, PM_PEER_ID_INVALID, skip);
SEGGER_RTT_printf(0,"m_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d\n", peer_id_count + 1, BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
err_code = pm_whitelist_set(peer_ids, peer_id_count);
/**@brief Function for handling Service errors.
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
static void service_error_handler(uint32_t nrf_error)
//NRF_LOG_INFO(nrf_error);
SEGGER_RTT_WriteString(0, " the nrf error is: " + nrf_error);
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling advertising errors.
static void ble_advertising_error_handler(uint32_t nrf_error)
/**@brief Function for handling the ADC interrupt.
* @details This function will fetch the conversion result from the ADC, convert the value into
* percentage and send it to peer.
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
nrf_saadc_value_t adc_result;
uint16_t batt_lvl_in_milli_volts;
uint8_t percentage_batt_lvl;
uint32_t err_code;
adc_result = p_event->data.done.p_buffer[0];
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
DIODE_FWD_VOLT_DROP_MILLIVOLTS;
percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
SEGGER_RTT_printf(0,"The battery level is: %d\n", percentage_batt_lvl);
err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
if ((err_code != NRF_SUCCESS) &&
(err_code != NRF_ERROR_INVALID_STATE) &&
(err_code != NRF_ERROR_BUSY) &&
(err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
APP_ERROR_HANDLER(err_code);
nrf_drv_saadc_uninit();
NRF_SAADC->INTENCLR = (SAADC_INTENCLR_END_Clear << SAADC_INTENCLR_END_Pos);
NVIC_ClearPendingIRQ(SAADC_IRQn);
/**@brief Function for configuring ADC to do battery level conversion.
static void adc_configure(void)
ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
nrf_saadc_channel_config_t config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
err_code = nrf_drv_saadc_channel_init(0, &config);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
* This function will start the ADC.
static void battery_level_meas_timeout_handler(void * p_context)
SEGGER_RTT_WriteString(0,"The battery level timeout handler has been called\n");
if(connectedToClient == 0){
SEGGER_RTT_WriteString(0,"The battery level will be measured\n");
adc_configure();
err_code = nrf_drv_saadc_sample();
/**@brief Function for the Timer initialization.
* @details Initializes the timer module.
static void timers_init(void)
// Initialize timer module, making it use the scheduler
// OUR_JOB: Step 3.H, Initiate our timer
// err_code = app_timer_create(&m_our_char_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler); //temp timer
// APP_ERROR_CHECK(err_code);
// Create battery timer.
err_code = app_timer_create(&m_battery_timer_id, APP_TIMER_MODE_REPEATED, battery_level_meas_timeout_handler);
// Create timers.
// err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for handling the Custom Service Service events.
* @details This function will be called for all Custom Service events which are passed to
* the application.
* @param[in] p_cus_service Custom Service structure.
* @param[in] p_evt Event received from the Custom Service.
static void on_cus_evt(ble_cus_t * p_cus_service,
ble_cus_evt_t * p_evt)
switch(p_evt->evt_type)
// case BLE_CUS_EVT_NOTIFICATION_ENABLED:
// err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
// break;
// case BLE_CUS_EVT_NOTIFICATION_DISABLED:
// err_code = app_timer_stop(m_notification_timer_id);
// break;
case BLE_CUS_EVT_CONNECTED:
case BLE_CUS_EVT_DISCONNECTED:
// No implementation needed.
/**@brief Function for setting filtered device identities.
static void identities_set(pm_peer_id_list_skip_t skip)
pm_peer_id_t peer_ids[BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT];
uint32_t peer_id_count = BLE_GAP_DEVICE_IDENTITIES_MAX_COUNT;
err_code = pm_device_identities_list_set(peer_ids, peer_id_count);
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
//whitelist_set(PM_PEER_ID_LIST_SKIP_NO_ID_ADDR);
ret_code_t ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
APP_ERROR_CHECK(ret);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
if ( p_evt->params.peer_data_update_succeeded.flash_changed
&& (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
NRF_LOG_INFO("New Bond, add the peer to the whitelist if possible");
SEGGER_RTT_WriteString(0, "New Bond, add the peer to the whitelist if possible\n");
// Note: You should check on what kind of white list policy your application should use.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_DIRECTED_HIGH_DUTY:
//NRF_LOG_INFO("Directed advertising.");
SEGGER_RTT_WriteString(0, "Directed advertising.\n");
//err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_DIRECTED);
//APP_ERROR_CHECK(err_code);
case BLE_ADV_EVT_FAST:
//NRF_LOG_INFO("Fast advertising.");
SEGGER_RTT_WriteString(0, "Fast advertising.\n");
//err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
case BLE_ADV_EVT_SLOW:
//NRF_LOG_INFO("Slow advertising.");
SEGGER_RTT_WriteString(0, "Slow advertising.\n");
//err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
case BLE_ADV_EVT_FAST_WHITELIST:
//NRF_LOG_INFO("Fast advertising with whitelist.");
SEGGER_RTT_WriteString(0, "Fast advertising with whitelist.\n");
//err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
case BLE_ADV_EVT_SLOW_WHITELIST:
//NRF_LOG_INFO("Slow advertising with whitelist.");
SEGGER_RTT_WriteString(0, "Slow advertising with whitelist.\n");
case BLE_ADV_EVT_WHITELIST_REQUEST:
ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
ble_gap_irk_t whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
uint32_t addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
uint32_t irk_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt, whitelist_irks, &irk_cnt);
//NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist", addr_cnt, irk_cnt);
SEGGER_RTT_printf(0,"pm_whitelist_get returns %d addr in whitelist and %d irk whitelist\n", addr_cnt, irk_cnt);
// Set the correct identities list (no excluding peers with no Central Address Resolution).
identities_set(PM_PEER_ID_LIST_SKIP_NO_IRK);
// Apply the whitelist.
err_code = ble_advertising_whitelist_reply(&m_advertising,whitelist_addrs,addr_cnt,whitelist_irks,irk_cnt);
case BLE_ADV_EVT_PEER_ADDR_REQUEST:
pm_peer_data_bonding_t peer_bonding_data;
SEGGER_RTT_WriteString(0,"a peer address request has been made\n");
// Only Give peer address if we have a handle to the bonded peer.
if (m_peer_id != PM_PEER_ID_INVALID)
err_code = pm_peer_data_bonding_load(m_peer_id, &peer_bonding_data);
if (err_code != NRF_ERROR_NOT_FOUND)
// Manipulate identities to exclude peers with no Central Address Resolution.
identities_set(PM_PEER_ID_LIST_SKIP_ALL);
ble_gap_addr_t * p_peer_addr = &(peer_bonding_data.peer_ble_id.id_addr_info);
err_code = ble_advertising_peer_addr_reply(&m_advertising, p_peer_addr);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_CONNECTED:
//app_timer_stop(m_battery_timer_id);
NRF_LOG_INFO("Connected");
SEGGER_RTT_WriteString(0, "Connected.\n");
connectedToClient = 1;
if(pm_paired == 0) {
pm_conn_secure(m_conn_handle,false);
pm_paired++;
NRF_LOG_INFO("Disconnected");
SEGGER_RTT_WriteString(0, "Disconnected\n");
//app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
SEGGER_RTT_WriteString(0, "PHY update request\n");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
SEGGER_RTT_WriteString(0, "GATT Client Timeout.\n");
case BLE_GATTS_EVT_TIMEOUT:
SEGGER_RTT_WriteString(0, "GATT Server Timeout.");
/**@brief Function for initializing the Battery Service.
static void bas_init(void)
ble_bas_init_t bas_init_obj;
memset(&bas_init_obj, 0, sizeof(bas_init_obj));
bas_init_obj.evt_handler = on_bas_evt;
bas_init_obj.support_notification = true;
bas_init_obj.p_report_ref = NULL;
bas_init_obj.initial_batt_level = 100;
bas_init_obj.bl_rd_sec = SEC_OPEN;
bas_init_obj.bl_cccd_wr_sec = SEC_JUST_WORKS;
bas_init_obj.bl_report_rd_sec = SEC_OPEN;
err_code = ble_bas_init(&m_bas, &bas_init_obj);
//ble_lbs_init_t init = {0};
ble_cus_init_t cus_init = {0};
// Initialize CUS Service init structure to zero.
cus_init.evt_handler = on_cus_evt;
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&cus_init.custom_value_char_attr_md.cccd_write_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cus_init.custom_value_char_attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&cus_init.custom_value_char_attr_md.write_perm);
err_code = ble_cus_init(&m_cus, &cus_init);
bas_init();
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module that
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for handling the Battery Service events.
* @details This function will be called for all Battery Service events which are passed to the
| application.
* @param[in] p_bas Battery Service structure.
* @param[in] p_evt Event received from the Battery Service.
switch (p_evt->evt_type)
case BLE_BAS_EVT_NOTIFICATION_ENABLED:
// Start battery timer
err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
break; // BLE_BAS_EVT_NOTIFICATION_ENABLED
case BLE_BAS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_battery_timer_id);
break; // BLE_BAS_EVT_NOTIFICATION_DISABLED
uint32_t ram_start = 0;
// Enable BLE stack.
//NRF_SDH_BLE_OBSERVER(m_our_service_observer, APP_BLE_OBSERVER_PRIO, ble_our_service_on_ble_evt, (void*) &m_our_service);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_whitelist_enabled = BLE_ADV_WHITELIST_ENABLED; //added for white listing
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_interval = APP_ADV_FAST_INTERVAL;
init.config.ble_adv_fast_timeout = APP_ADV_FAST_DURATION;
init.config.ble_adv_slow_enabled = true;
init.config.ble_adv_slow_interval = APP_ADV_SLOW_INTERVAL;
init.config.ble_adv_slow_interval = APP_ADV_SLOW_DURATION;
static void log_init(void)
/**@brief Function for starting timers.
static void application_timers_start(void)
// OUR_JOB: Step 3.I, Start our timer
//app_timer_start(m_our_char_timer_id, OUR_CHAR_TIMER_INTERVAL, NULL);
nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
//Initialize.
//log_init();
timers_init();
power_management_init();
ble_stack_init();
sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
gap_params_init();
gatt_init();
services_init(); //services init called before advertising init to ensure all services available
advertising_init();
conn_params_init();
peer_manager_init();
application_timers_start();
// Start execution.
SEGGER_RTT_WriteString(0, "Hello World from SEGGER!\n");
advertising_start(true);
// Enter main loop.
for (;;)
idle_state_handle();
Call stack error in Segger embedded studio
Please help.
