Is there any SPI examples by directly accessing the registers?
Based on SDK15.0.2, for NRF52832 or NRF52810, higher freedom, higher memory utilization.
You can use the GPIO emulate the SPI driver in order to save the code size.
Just like this example to use the GPIO to drive SPI flash.
https://github.com/jimmywong2003/nrf5-external-spi-flash-bootloader/tree/master/sdk_mod/spi_driver
We do not have any examples for that. You'll have to read the SPIM — Serial peripheral interface master with EasyDMA and SPIM HAL carefully.
I have read this documentation, some questions need help: If
1. Is TXD.MAXCNT maximum length equal to 255 ? If it set value = 200.
2. Is TXD.LIST maximum length equal to 7 ? If it set value = 2
3. Set TXD.PTR point to an array lists that they are continuous RAM buffer[400] and split them into 2 array lists,
4. set shortcut END_START
5. Enable and Start
Does the SPIM will continuous send buffer data serial to MOSI without any pending .. ?
