Make MCUboot run without enabling serial
Im trying to recreate the example from:
https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/hardware-design/posts/measuring-psm-idle-current-on-the-nrf91-dk
But also having MCUboot appplication compiled in.
But is I disable the serial port on SPM and my application project then board seems to go into a loop on only running MCUboot, and MCUboot still uses the serial port. Anyone have any insight into how to recreate the same results in the above blog post but still compliling application + spm + mcuboot?
  • Are you sure you have disabled the serial port? I have added CONFIG_SERIAL=n to SPM and my own custom project and the device no longer prints printk() or printf() to the Link Monitor.
  • Thanks. Then I will start figuring out of the prolem is elsewhere. I will get back with my finding :)
  • A quick question I would have is, did you maybe put the CONFIG_SERIAL=n into the wrong prj.conf? I sometimes mix up the folder files when I'm working across multiple application folders as they are all called the same thing in every sample and custom application folder. Sweat smile
  • My mcuboot outputs:
    ***** Booting Zephyr OS v1.14.99-ncs1 *****
    [00:00:00.004,272] <inf> mcuboot: Starting bootloader
    [00:00:00.012,817] <inf> mcuboot: Primary image: magic=unset, copy_done=0x3, image_ok=0x1
    [00:00:00.023,925] <inf> mcuboot: Scratch: magic=unset, copy_done=0x50, image_ok=0x3
    [00:00:00.034,484] <inf> mcuboot: Boot source: primary slot
    [00:00:00.045,440] <inf> mcuboot: Swap type: none
    [00:00:00.466,979] <inf> mcuboot: Bootloader chainload address offset: 0xc000
    [00:00:00.476,715] <inf> mcuboot: Jumping to the first image slot
    Edit: Hm.. Thats perhaps the boot banner... Recompiling.
  • This is for the nRF9160 right? I've never see any output from mcuboot on start-up. Upon starting any nRF9160 sample or custom program I would only see:
    Flash region		Domain		Permissions
    00 0x00000 0x08000 	Secure		rwxl
    01 0x08000 0x10000 	Non-Secure	rwxl
    02 0x10000 0x18000 	Non-Secure	rwxl
    03 0x18000 0x20000 	Non-Secure	rwxl
    04 0x20000 0x28000 	Non-Secure	rwxl
    05 0x28000 0x30000 	Non-Secure	rwxl
    06 0x30000 0x38000 	Non-Secure	rwxl
    07 0x38000 0x40000 	Non-Secure	rwxl
    08 0x40000 0x48000 	Non-Secure	rwxl
    09 0x48000 0x50000 	Non-Secure	rwxl
    10 0x50000 0x58000 	Non-Secure	rwxl
    11 0x58000 0x60000 	Nol2 0x60000 0x68000 	Non-Secure	rwxl
    13 0x68000 0x70000 	Non-Secure	rwxl
    14 0x70000 0x78000 	Non-Secure	rwxl
    15 0x78000 0x80000 	Non-Secure	rwxl
    16 0x80000 0x88000 	Non-Secure	rwxl
    17 0x88000 0x90000 	Non-Secure	rwxl
    18 0x90000 0x98000 	Non-Secure	rwxl
    19 0x98000 0xa0000 	Non-Secure	rwxl
    20 0xa0000 0xa8000 	Non-Secure	rwxl
    21 0xa8000 0xb0000 	Non-Secure	rwxl
    22 0xb0000 0xb8000 	Non-Secure	rwxl
    23 0xb8000 0xc0000 	Non-Secure	rwxl
    24 0xc0000 0xc8000 	Non-Secure	rwxl
    25 0xc8000 0xd0000 	Non-Secure	rwxl
    26 0xd0000 0xd8000 	Non-Secure	rwxl
    27 0xd8000 0xe0000 	Non-Secure	rwxl
    28 0xe0000 0xe8000 	Non-Secure	rwxl
    29 0xe8000 0xf0000 	Non-Secure	rwxl
    30 0xf0000 0xf8000 	Non-Secure	rwxl
    31 0xf8000 0x100000 	Non-Secure	rwxl
    SRAM region		Domain		Permissions
    00 0x00000 0x02000	Secure		rwxl
    01 0x02000 0x04000	Secure		rwxl
    02 0x04000 0x06000	Secure		rwxl
    03 0x06000 0x08000	Secure		rwxl
    04 0x08000 0x0a000	Secure		rwxl
    05 0x0a000 0x0c000	Secure		rwxl
    06 0x0c000 0x0e000	Secure		rwxl
    07 0x0e000 0x10000	Secure		rwxl
    08 0x10000 0x12000	Non-Secure	rwxl
    09 0x12000 0x14000	Non-Secure	rwxl
    10 0x14000 0x16000	Non-Secure	rwxl
    11 0x16000 0x18000	Non-Secure	rwxl
    12 0x18000 0x1a000	Non-Secure	rwxl
    13 0x1a000 0x1c000	Non-Secure	rwxl
    14 0x1c000 0x1e000	Non-Secure	rwxl
    15 0x1e000 0x20000	Non-Secure	rwxl
    16 0x20000 0x22000	Non-Secure	rwxl
    17 0x22000 0x24000	Non-Secure	rwxl
    18 0x24000 0x26000	Non-Secure	rwxl
    19 0x26000 0x28000	Non-Secure	rwxl
    20 0x28000 0x2a000	Non-Secure	rwxl
    21 0x2a000 0x2c000	Non-Secure	rwxl
    22 0x2c000 0x2e000	Non-Secure	rwxl
    23 0x2e000 0x30000	Non-Secure	rwxl
    24 0x30000 0x32000	Non-Secure	rwxl
    25 0x32000 0x34000	Non-Secure	rwxl
    26 0x34000 0x36000	Non-Secure	rwxl
    27 0x36000 0x38000	Non-Secure	rwxl
    28 0x38000 0x3a000	Non-Secure	rwxl
    29 0x3a000 0x3c000	Non-Secure	rwxl
    30 0x3c000 0x3e000	Non-Secure	rwxl
    31 0x3e000 0x40000	Non-Secure	rwxl
    Peripheral		Domain		Status
    00 NRF_P0		Non-Secure	OK
    01 NRF_CLOCK		Non-Secure	OK
    02 NRF_RTC1		Non-Secure	OK
    03 NRF_NVMC		Non-Secure	OK
    04 NRF_UARTE1		Non-Secure	OK
    05 NRF_UARTE2		Secure		SKIP
    06 NRF_IPC		Non-Secure	OK
    07 NRF_VMC		Non-Secure	OK
    08 NRF_FPU		Non-Secure	OK
    09 NRF_EGU1		Non-Secure	OK
    10 NRF_EGU2		Non-Secure	OK
    11 NRF_TWIM2		Non-Secure	OK
    12 NRF_SPIM3		Non-Secure	OK
    13 NRF_TIMER0		Non-Secure	OK
    14 NRF_TIMER1		Non-Secure	OK
    15 NRF_TIMER2		Non-Secure	OK
    16 NRF_SAADC		Non-Secure	OK
    17 NRF_GPIOTE1		Non-Secure	OK
    SPM: NS image at 0x8000
    SPM: NS MSP at 0x20023be8
    SPM: NS reset vector at 0xe94d
    SPM: prepare to jump to Non-Secure image.
    Application Started
    Followed by the rest of my code. This is all silenced when setting CONFIG_SERIAL=n. The only time I would see information close to that is when I invoke NVS which would show:
    [00:00:01.230,987] <inf> fs_nvs: 102 Sectors of 4096 bytes
    [00:00:01.230,987] <inf> fs_nvs: alloc wra: 0, ff0
    [00:00:01.230,987] <inf> fs_nvs: data wra: 0, 0
    But that is again silenced by SERIAL=n. Have you invoked something in either your code or in your prj.conf to display this kind of information. Maybe some kind of logging configuration?
    EDIT:
    Ah ok, re-read your OP, so you are adding MCUBoot to your project which isn't normally done in the example files. Looking at the MCUBoot template, have you tried setting #define MCUBOOT_HAVE_LOGGING to 0?
