Zigbee attribute reporting not reporting as configured.
Since migrating to the Zigbee 3.1 SDK I have noticed a few oddities with the behavior of attribute reporting that I am thinking are related to the following bugfix:
- Added configuring Default Reporting automatically for all attributes that support reporting,
with MinInterval equal to 5 sec, MaxInterval equal to 0 sec (no periodic reports), and Delta (analog attributes) equal to 0.
The end device that I am working on is connected to a SmartThings hub. The device handler I have written for the end device configures reporting for a number of attributes when the device is commissioned and all seems to work fine. Once my device establishes a connection I adjust the long poll interval and I log the sleep interval to the console. In SDK 3.0 the end device, upon reboot, would connect to the ST hub, report its attribute values, and eventually settle down and poll at the long poll interval. After moving to SDK 3.1 however, if the device is rebooted it never settles down and constantly polls at a shortened interval, behavior I usually observe after an attribute has been reported.
Prior to migrating to SDK 3.1 I came across this question in which the solution was to configure attribute reporting from the device. Although it seems the API has changed a little in SDK 3.1 I have the following for my configure reporting function and call this function in zboss_signal_handler on device first start/reboot.:
void configure_attribute_reporting()
        zb_zcl_reporting_info_t temp_rep_info;
        memset(&temp_rep_info, 0, sizeof(temp_rep_info));
        temp_rep_info.direction = ZB_ZCL_CONFIGURE_REPORTING_SEND_REPORT;
        temp_rep_info.ep = MULTI_SENSOR_ENDPOINT;
        temp_rep_info.cluster_id = ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT;
        temp_rep_info.cluster_role = ZB_ZCL_CLUSTER_SERVER_ROLE;
        temp_rep_info.attr_id = ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID;
        temp_rep_info.dst.profile_id = ZB_AF_HA_PROFILE_ID;
        temp_rep_info.u.send_info.min_interval = 30;      // 30 seconds
        temp_rep_info.u.send_info.max_interval = 300;    // 5 minutes
        temp_rep_info.u.send_info.delta.s16 = 0x0032;        // 0.5 degrees
        zb_zcl_reporting_info_t humid_rep_info;
        memset(&humid_rep_info, 0, sizeof(humid_rep_info));
        humid_rep_info.direction = ZB_ZCL_CONFIGURE_REPORTING_SEND_REPORT;
        humid_rep_info.ep = MULTI_SENSOR_ENDPOINT;
        humid_rep_info.cluster_id = ZB_ZCL_CLUSTER_ID_REL_HUMIDITY_MEASUREMENT;
        humid_rep_info.cluster_role = ZB_ZCL_CLUSTER_SERVER_ROLE;
        humid_rep_info.attr_id = ZB_ZCL_ATTR_REL_HUMIDITY_MEASUREMENT_VALUE_ID;
        humid_rep_info.dst.profile_id = ZB_AF_HA_PROFILE_ID;
        humid_rep_info.u.send_info.min_interval = 60;       // 60 seconds
        humid_rep_info.u.send_info.max_interval = 600;     // 10 minutes
        humid_rep_info.u.send_info.delta.u16 = 0x0064;         // 1% rh
        zb_zcl_reporting_info_t batt_rep_info;
        memset(&batt_rep_info, 0, sizeof(batt_rep_info));
        batt_rep_info.direction = ZB_ZCL_CONFIGURE_REPORTING_SEND_REPORT;
        batt_rep_info.ep = MULTI_SENSOR_ENDPOINT;
        batt_rep_info.cluster_id = ZB_ZCL_CLUSTER_ID_POWER_CONFIG;
        batt_rep_info.cluster_role = ZB_ZCL_CLUSTER_SERVER_ROLE;
        batt_rep_info.attr_id = ZB_ZCL_ATTR_POWER_CONFIG_BATTERY_REMAINING_ID;
        batt_rep_info.dst.profile_id = ZB_AF_HA_PROFILE_ID;
        batt_rep_info.u.send_info.min_interval = 30;       // 30 seconds
        batt_rep_info.u.send_info.max_interval = 21600;     // 5 minutes
        batt_rep_info.u.send_info.delta.u8 = 0x01;         // 1%
        // Prior to SDK 3.1 this function was zb_zcl_put_default_reporting_info(zb_zcl_reporting_info_t*)
        zb_zcl_put_reporting_info(&temp_rep_info, ZB_TRUE);    // Assume the override parameter here is to override the new default configuration.
        zb_zcl_put_reporting_info(&humid_rep_info, ZB_TRUE);
        zb_zcl_put_reporting_info(&batt_rep_info, ZB_TRUE);
With the device now configuring attribute reporting I seem to have fixed the problem above in that now between attribute updates (every minute), the device uses the long poll interval when sleeping unless an attribute is to be reported (without having to issue an attribute report configuration through SmartThings). This now leaves me with another set of issues that have me scratching my head a little.
  1. The temperature attribute to update every half degree with a maximum interval of 300 seconds. The problem, that is illustrated in the attached image, is that I am getting random reporting intervals that seem to completely ignore maximum interval.
    1. While writing this post it occurred to me that I am working with temperature in celsius on the device and it is translated to fahrenheit in SmartThings. I was expecting half degrees F, not C (doh).
  2. Relative humidity is configured to report every 600 seconds or every 1%. Again, the maximum interval appears to be ignored.
  3. Battery remaining percent changes too infrequently for me to have any data but given the points above I think I can safely assume it does not work as I want it to.
This leaves me with the following questions:
  1. When configuring the reporting value delta should we be using the hex value or integer value? I am leaning towards a hex value based on the observations in the above image and when configuring reporting in SmartThings, they use a hex value. Which is correct?
  2. What could be the cause of my maximum interval being ignored? I am wondering if just because I am configuring reporting locally to the device perhaps the central is not acknowledging it. I'm guessing a "re-binding" needs to occur on the central for reporting.
    1. Would setting temp_rep_info.dst.short_addr have any effect in triggering the central/hub to bind to the report?
    2. Regardless of the settings the end device configures for reporting, the central has to explicitly bind to these correct?
  3. If the device does not configure reporting as I have done above and relies on the hub to configure reporting, as my ST device handler does, what is the process for saving those parameters so that when the device reboots it does not have to be configured by the hub/device handler (or any other way other hubs handle devices). Are we to utilize zb_zcl_reporting_info_nvram_t?
Thanks in advance
-Patrick
  • Andreas,
    I have attached a hex file configured as requested. Sensor readings have been replaced with values from the sensorsim library so hopefully it behaves in a similar enough fashion for testing. I did let the device run a bit and I think reporting is following the configuration set by the device, not the hub. After a period of time I did notice that reports would be delayed, though not to the extent as I was previously seeing.
    Finally, in an effort to make this a little easier than me having to compile any change you need I have created a SES project. Unfortunately I was unable to get SES to play nicely with any C++ so I have removed the sensor drivers and changed over a few other calls to make it compile in C. I fear that this may change too much to have testing mean much but it is worth a shot.zigbee_multi_sensor_pca10056.hex
    ZigbeeTempSensor.zip
  • Hi.
    Could we try to summarize a bit here, there is a lot of information in this ticket now.
    There is a known bug in ZBOSS that if ERASE_PERSISTENT_CONFIG is set to ZB_FALSE, as you previously had, the reporting configuration is not properly stored in NVRAM data, so it is reset to defaults after device reboot. The log file appear to show that the device is reporting correctly.
    From the log file you provided, do you see that there are places, where the report is generated, but it shouldn't be? Do you see that there are places where report should be generated, but it wasn't?
    See attached table for reference.
    Andreas
  • Perhaps I have misunderstood how periodic reporting works. I was expecting that once the maximum interval was reached for any given cluster the reportable attribute  would be reported, regardless of value. I thought I had read this in the copy of the ZCL spec I have but looking again I see that the section that should describe report behavior (2.4.7) is apparently a misprint. Looking at another vendor's documentation it would seem than even when the maximum interval has been reached, a report will only be sent if the reportable attribute is also greater than the reportable change value. Is this correct?
    Is there a workaround to the bug you mentioned to store the reporting configuration?
  • Hi.
     I will ask our developers about this so that we get a proper answer.
     The only workaround so to speak is to set ERASE_PERSISTENT_CONFIG to ZB_TRUE.
    Andreas
  • The only workaround so to speak is to set ERASE_PERSISTENT_CONFIG to ZB_TRUE.
    So do not rely on attribute report configuration in at least this version of ZBOSS for both device-side and coordinator side configuration. This configuration must take place every time the device connects.
