I can't read on my uart
Hi, i'm using nRF52840
I'm using 2 uarts :
one (uart0) is only for logging and another one (uart1) is for communication.
I can send from both uart, i can see i receive datas from uart1 but i can't read it  Disappointed
I try to read with an event_handle, event occurs i go inside in correct  case, i can see i'm in the good case (using docklight software i can send one charac then another... and each time i send one i enter in case for reading)
see below code for init :
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                      ARDUINO_SDA_PIN, ARDUINO_SCL_PIN,
                      ARDUINO_12_PIN, ARDUINO_13_PIN,
                      APP_UART_FLOW_CONTROL_DISABLED, NRF_UART_PARITY_EXCLUDED,
                      NRF_UART_BAUDRATE_57600,
                      APP_IRQ_PRIORITY_LOWEST);
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart1_drv_config,
					  RX_PIN_NUMBER, TX_PIN_NUMBER,
                      RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                      NRF_UART_BAUDRATE_19200,
NRF_SERIAL_QUEUES_DEF(serial0_queues, 32, 32);
NRF_SERIAL_QUEUES_DEF(serial1_queues, 32, 32);
NRF_SERIAL_BUFFERS_DEF(serial0_buffs, 1, 1);
NRF_SERIAL_BUFFERS_DEF(serial1_buffs, 1, 1);
NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_IRQ,
                      &serial0_queues, &serial0_buffs, NULL, sleep_handler);
NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_IRQ,
                      &serial1_queues, &serial1_buffs, uart_event_handle, sleep_handler);
NRF_SERIAL_UART_DEF(serial0_uart, 0);
NRF_SERIAL_UART_DEF(serial1_uart, 1);
and code for event_handle :
void uart_event_handle(struct nrf_serial_s const * p_serial,
        nrf_serial_event_t event)
    switch (event)
    	case NRF_SERIAL_EVENT_RX_DATA :
        	//I enter each time i send one charac
        	SEGGER_RTT_WriteString(0, "Uart : NRF_SERIAL_EVENT_RX_DATA\n");
        	mbedtls_mutex_lock( &mutex_uart );
			char c;
			nrf_serial_read(&serial1_uart, &c, sizeof(c), NULL, 1000);
			SEGGER_RTT_printf(0, "Data reçue : %#02x \n", c);
			//I always receive 10
            mbedtls_mutex_unlock( &mutex_uart );
   		    SEGGER_RTT_WriteString(0, "Uart : default\n");
All this code comes from examples provided bay sdk...
maybe i'm not reading the correct buffer but i don't know which one to read then.
thx for help
Geoffroy
