How can I read out the actual value of the power supply, using the low power comparator?
Dear all,
I need to read out the voltage of the battery that supplies my nrf52. From what I have read I see that there are 2 options: LPCOMP and ADC.
Due to restrictions that I have because of my hardware, I cannot add any exteranl components in order to add the voltage divider. So I need to use the LPCOMP.
I have checked the SDK example, but I don't see how to actually read out the value. Searching around has only revealed to me there is a way to trigger an event when the supply voltage falls under a certain value. But what do I need to do in order to measure the value of the supply voltage?
    What example did you look at? The Proximity Application (examples\ble_peripheral\ble_app_proximity) measures the battery level every 2 minutes using ADC. If there is a change in the battery level, the application sends the current level as a notification.
    /**@brief Function for handling the ADC interrupt.
     * @details  This function will fetch the conversion result from the ADC, convert the value into
     *           percentage and send it to peer.
    void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
            nrf_saadc_value_t adc_result;
            uint16_t          batt_lvl_in_milli_volts;
            uint8_t           percentage_batt_lvl;
            uint32_t          err_code;
            adc_result = p_event->data.done.p_buffer[0];
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
            batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                      DIODE_FWD_VOLT_DROP_MILLIVOLTS;
            percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
            err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl, BLE_CONN_HANDLE_ALL);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
    Hope this helps.
    Øyvind
  • I don't see how to actually read out the value
    The "LPCOMP" is a comparator - so it does not give you a "read out of the voltage"
    A comparator just tells you that the input is above or below the reference.
    If your battery voltage exceeds the allowable input pin voltage, then you will still need a divider - whether you use the comparator or the ADC
  • So, from what I understand, I can simply read the voltage directly from the pin, without any voltage divider, as long as my supplied voltage is less than 3.3V, correct?
  • Check the Product Specification for the actual limit (which is also related to VDD) - as long as you don't exceed that, you're OK.
    You may also need to adjust the ADC gain so as not to exceed its internal input range
