Please look at the APP_CMD_CHANGE_RESOLUTION in the main.c file of the image transfer demo.
Simon
Thank you very much for your interest. We are very pleased with your technical support.
Is there any chance of lowering kbps? We want to try to extend the distance.
Hi Hasan
Sorry about the misunderstanding. You want to increase the range of your application, am I correct?
If so, which chip are you using? If you're using the nRF52840, you should be able to change the BLE_GAP_PHY setting to BLE_GAP_PHY_CODED, which is "long range mode", a test using this mode is described in this blog post. This mode outputs around 125kbps and is tested outdoors to work at ~1300 meters.
If you're using an nRF52832, you could set the BLE_GAP_PHY to always be at BLE_GAP_PHY_1MBPS as well as increasing the TX power for the longest range possible.
In both these cases, you should probably remove the change_PHY and PHY_UPDATE events from the main file in the image transfer demo.
Simon
Hi Simon,
Can we send the automatic (Take picture, Start stream) .jpg file to nrf52840 without making a don't selection from the mobile application?
