Getting Started with nRF9160 DK : Problem to connect DK to nrFcloud
I cannot connect my DK to nRF cloud
After following the step "Asset Tracker programming to DK" I have the following error in the logs:
***** Booting Zephyr OS v1.14.99-ncs2-rc2 *****
Flash region Domain License ***** Hardware exception *****
Current thread ID = 0x20001870
Faulting instruction address = 0x30100
Fatal fault in ISR! Spinning ...
Can you help me ?
    Can you please give me some information on what version you are using? I.e. in command prompt give the output to the command "west status"
    Øyvind
    I'm not sure you want this result
    Result of command : west status
    === status of nrf (nrf):
    On branch master
    Your branch is up to date with 'origin/master'.
    Changes not staged for commit:
    (use "git add <file>..." to update what will be committed)
    (use "git checkout -- <file>..." to discard changes in working directory)
    modified: applications/asset_tracker/src/main.c
    modified: subsys/spm/spm.c
    Untracked files:
    (use "git add <file>..." to include in what will be committed)
    applications/asset_tracker/build_nrf9160_pca10090ns/
    applications/nrf_desktop/build_nrf9160_pca10090/
    applications/nrf_desktop/build_nrf9160_pca10090ns/
    samples/bluetooth/central_bas/build_nrf9160_pca10090/
    samples/bluetooth/central_bas/build_nrf9160_pca10090ns/
    samples/bluetooth/throughput/build_nrf9160_pca10090/
    samples/debug/ppi_trace/build_nrf9160_pca10090/
    samples/nfc/record_text/build_nrf9160_pca10090/
    samples/nfc/record_text/build_nrf9160_pca10090ns/
    samples/nfc/tag_reader/build_nrf9160_pca10090/
    samples/nfc/tag_reader/build_nrf9160_pca10090ns/
    samples/nrf9160/Gpio/
    samples/nrf9160/NRF9160/
    samples/nrf9160/at_client/build_nrf9160_pca10090/
    samples/nrf9160/at_client/build_nrf9160_pca10090ns/
    samples/nrf9160/gps/build_nrf9160_pca10090/
    samples/nrf9160/hello_world/
    samples/nrf9160/mqtt_simple/build_nrf9160_pca10090/
    samples/nrf9160/mqtt_simple/build_nrf9160_pca10090ns/
    samples/nrf9160/secure_services/build_nrf9160_pca10090/
    samples/nrf9160/secure_services/build_nrf9160_pca10090ns/
    subsys/spm9/
    no changes added to commit (use "git add" and/or "git commit -a")
    === status of fw-nrfconnect-zephyr (zephyr):
    HEAD detached at refs/heads/manifest-rev
    modified: include/net/buf.h
    === status of nffs (modules\fs\nffs):
    nothing to commit, working tree clean
    === status of segger (modules\debug\segger):
    === status of fw-nrfconnect-mcuboot (mcuboot):
    === status of fw-nrfconnect-mcumgr (modules\lib\mcumgr):
    === status of fw-nrfconnect-tinycbor (modules\lib\tinycbor):
    === status of nrfxlib (nrfxlib):
    === status of cmock (test\cmock):
    === status of unity (test\cmock\vendor\unity):
    === status of mbedtls (mbedtls):
  • Yes, this was exactly what I needed.  (Tip to next time is to use the Insert --> Insert Code)
    You are currently working on the master branch of NCS which can cause issues. I was able to reproduce the issue. My solution was to checkout tag v0.4.0, and this is currently what we suggest customers use v0.4.0 until a new tag is released.
    Before changing to tag v0.4.0, you should remove the untracked files that you have. If these are not important changes, you can use:
    git clean -fd
    To change to tag v0.4.0, please do the following:
    cd ncs/nrf
    git checkout master
    git pull
    git checkout v0.4.0
    west update
    Then try "Asset Tracker programming to DK" step one more time.
    Øyvind
  • Thanks for your help Øyvind.
    It works now.
    Jérôme
