Reading Raw Adv Packet
How can i put out the received Adv Data on the UART? Currently I get for every advertise packet the BLE_GAP_EVT_ADV_REPORT in my ble_stack_handler. Then i wanted to print out the data on my VirtualPort with  printf((char*)p_gap_evt->params.adv_report.data.p_data). But i get nothing useful. How can i print out the raw 31 Byte received advertising packet? Do i need a for-loop to print out every byte?
PS: Using nRF52840 DK
  • Surely, this is a pure 'C' question - nothing specifically to do with Nordic?
    Of course - if you need to print 31 individual values, the obvious way to do that will be in a loop.
  • Thank you for your Answer but p_gap_evt->params.adv_report.data.p_data isnt a Array. Its a uint8_t* type. So im little bit confused. Also watched about the value in the debugger and i get something like "0x2000355c". This istn even close 31 Bytes. And my p_gap_evt->params.adv_report.data.len has the Value "0x001f", which is in dec 31
  • But arrays & pointers are almost the same thing in 'C'
    http://c-faq.com/aryptr/
    The index operator [] can be applied to a pointer:
    uint8_t* my_pointer;
    my_pointer = &some_data;    // set the pointer to point to something
    printf( "1st byte (offset 0) is %d", my_pointer[0] );
    printf( "2nd byte (offset 1) is %d", my_pointer[1] );
    printf( "3rd byte (offset 2) is %d", my_pointer[2] );
    printf( "nth byte (offset n-1) is %d", my_pointer[n-1] );
    which is equivalent to:
    printf( "1st byte (offset 0) is %d", *my_pointer   );
    printf( "2nd byte (offset 1) is %d", *my_pointer+1 );
    printf( "3rd byte (offset 2) is %d", *my_pointer+2 );
    printf( "nth byte (offset n-1) is %d", *my_pointer+(n-1) );
    Or:
    printf( "1st byte (offset 0) is %d", *my_pointer++ );
    printf( "2nd byte (offset 1) is %d", *my_pointer++ );
    printf( "3rd byte (offset 2) is %d", *my_pointer++ );
    Again, this is all standard 'C' - nothing specific to Nordic.
  • I am ashamed. Thank you very much. Im able to print out the 31 Bytes. Im so happy :)
  • Hi Lecram,
    I'm happy to hear you fixed your code. I am working on a similar project and am trying to send beacon data over UART to an esp8266 module, everything looks correct and I am not sure what's going wrong. Would you be willing to help and share your main.c source code?
