I'm using 3 AIN pins to read analog readings. However, when I go to sleep mode, I want the current to be as low as possible.
I notice that the AIN pins (saadc) is floating or disconnected and I need it to pull high to switch off my optical sensor (collector and emitter. I'm using an optical sensor QRE1113).
I have tried
nrfx_saadc_uninit(); // Go to system-off mode (this function will not return; wakeup will cause a reset). err_code = sd_power_system_off();
But I need the pins to be high.
Please help.
Thank you
Chong
