Need help regarding custom HID descriptor for nRF51822
I am trying to modify the ble_hids_mouse example project to convert the device into a vendor defined HID device. I need to send 64 bytes of custom sensor data (which I am reading over SPI on nRF51) over custom HID so that my application on the PC can access the data using HID APIs. I have tried multiple HID descriptors but fail to get data on the PC side. I am using the HIDAPI library on a Windows 10 platform to read data from the HID device. The hid_open() function returns a valid handle for the HID device (VID,PID) but hid_read() always returns 0 bytes. Error code from ble_hids_inp_rep_send() function on nRF returns 0 (NRF_SUCCESS), so I am assuming there are no errors in sending HID input reports.
Following are 2 HID descriptors which do not work:
(I)
0x05, 0x01, // Usage Page (Generic Desktop Page)
0x09, 0x00, // Usage (Undefined)
0xA1, 0x01, // Collection (Application)
0x16, 0x00, 0x00, // Logical Minimum (0)
0x26, 0xFF, 0x00, // Logical Maximum (255)
0x36, 0x00, 0x00, // Physical Minimum (0)
0x46, 0xFF, 0x00, // Physical Maximum (255)
0x66, 0x00, 0x00, // Unit (None)
0x75, 0x08, // Report Size (8)
0x95, 0x40, // Report Count (64)
0x81, 0x02, // Input
0xC0, // End Collection
(II)
0x06, 0x00, 0xff, // USAGE_PAGE (Vendor Defined Page 1)
0x09, 0x01, // USAGE (Vendor Usage 1)
0xa1, 0x01, // COLLECTION (Application)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x26, 0xff, 0x00, // LOGICAL_MAXIMUM (255)
0x75, 0x08, // REPORT_SIZE (8)
0x95, 0x40, // REPORT_COUNT (64)
0x81, 0x00, // INPUT (Data,Ary,Abs)
0x91, 0x00, // OUTPUT (Data,Ary,Abs)
0xc0 // END_COLLECTION
I have adjusted the input report length to 64 bytes at multiple places in the code and modified the report id as per the descriptors.
However, reducing the length of the input report from 64 bytes to 8 bytes seems to work and I am able to receive 8 bytes of data in my application.
Can you please help to debug this issue.
Mustafa
    Thanks for the prompt reply.
    Regarding the max allowable user data per packet, why do we have a limit of 20 bytes ? Is there a way we can increase the limit to a higher value ? If yes, what is the maximum allowable data that can be transferred per data packet ?
    For my application, I need to send at least 80 bytes of data at a time using HID service.
    Regards
    Mustafa
  • Its a hard limit of 20 bytes user data in the SoftDevice S130. To get a larger MTU size, you have to use nRF52-series with S132/140 SoftDevice.
    Håkon
  • Is there any limit on the speed at which HID reports can be sent on nrf51 + S130 ? I need to send an HID IN report every 5 ms.
    You need to conform to the BLE connection, which gives you a connection interval (from 7.5 ms to 4 sec), typically asked for by the peripheral device as a range (a min and a max).
    If you send data every 5 ms, you must rely on the central device to accept more packets per connection interval. Lets say that you have a connection interval of 10 ms, then you will send 2 packets per interval.
    Håkon
  • Hi Hakon,
    Thanks for the quick response.
    My BLE central device is a Windows 10 Dell latitude 3490 laptop. I am trying to understand the connection parameters that would be used by the Windows driver. I found BLE design guidelines for iOS and Android platform but I am unable to find similar information for WIndows. Could you please point me in the direction where I can find this information.
    Also, from my current understanding communication is active between the central and peripheral only during the connection event. Now, I am using the ble_hids_inp_rep_send() function to send HID IN reports.So, everytime I call the above function, does it queue all the messages and send them all at once during the next connection event. Is there a check on the maximum number of packets nrf device sends per connection interval ?
    Thank You
    Mustafa
  • Hi Mustafa,
     Look for the defines MIN_CONN_INTERVAL and MAX_CONN_INTERVAL at the top of main.c. This sets the limits for your peripheral.
    The central will always drive the communication, so you are not always guaranteed the same interval on different centrals, but you are very likely to get within the min and max interval that you set.
     There is no specific command to get this, as it is unique to each chipset and may also be a limitation set in the OS driver.
    You can send until the ble_hids_inp_rep_send() function returns error code NRF_ERROR_RESOURCES (for older SDKs you get error code BLE_ERROR_NO_TX_PACKETS), in which you have to wait until the queue is handled.
    You will get an event "BLE_EVT_TX_COMPLETE" when the transfer is complete.
    Håkon
  • Hi Mustafa,
    Håkon
