In addition to previous ticket I have further queries. I have a stringent requirement for reduction of Current consumption.
https://devzone.nordicsemi.com/support/230962
1) In ‘ble_app_blinky’ since SoftDevice is enabled, whether DCDC enabled by default or need to enabled explicitly by calling
sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE)
2) As mentioned below do I need to enable DC-DC only during BLE active and disable after BLE inactive.
3) To my understanding, keeping build in “Release” mode will disable UART.
a) Below are the macros enabled in Release mode & Debug mode. But when I keep in “Release” mode still I am seeing debug prints on Terminal. Then what is the difference between “Release” & “Debug” builds.
"DEBUG; DEBUG_NRF" from solution in Debug configuration
"NDEBUG" from solution in Release configuration
b) As mentioned in below link, at the same time do I need to disable NRF_LOG_ENABLE explicitly do reduce current consumption. Please confirm.
https://devzone.nordicsemi.com/f/nordic-q-a/35042/current-consumption-in-nrf52
c) How to disable UART if still I am seeing debug prints on Terminal. Do I need to disable NRFX_UARTE_ENABLED macro or just disconnecting debug cable is good enough during current measurement.
4) Do I need to explicitly disable FPU unit. I have floating point calculations. But before going to sleep (System ON or System OFF) do I need to clear FPU as mentioned in below link.
https://devzone.nordicsemi.com/f/nordic-q-a/15243/high-power-consumption-when-using-fpu
5) Before going to System OFF I called nrf_gpio_cfg_default() with all pins expect pin 13 & 14 (Buttons to wake-up the device). This function will configure pullup as NRF_GPIO_PIN_NOPULL. But as per below link, not sure with development kit whether do I need to change to Pullup or Pulldown.
https://devzone.nordicsemi.com/f/nordic-q-a/4505/system-power-off
Please let me know your inputs.
Thanks & Regards
Vishnu Beema
