Hi:
Because our project using much nRF pin resources, we have to use the defualt function NFC pins (P0.09 and P0.10).we want to set these two pins as uart function ,but i dont know if it is possible? and i have a little test about is ,but when i config pins as follows:
#define RX_PIN_NUMBER 10 #define TX_PIN_NUMBER 9 #define CTS_PIN_NUMBER 44 #define RTS_PIN_NUMBER 44 #define HWFC false
the code run to the hard fault. and when i changed RX_PIN to 12 and TX _PIN to 11,uart workes correctly.
so can you give me some advices? and what can i do to solve this problem?
Thank you !
