Warning: USING OUT OF TREE BOARD
I deleted nrf-related files and set up nrf programs from a scratch following Get Started Assistant of nRF Connect v3.0.0
I've got this warning when I opened a project by "Open nRF Connect SDK Project".
SEGGER Embedded Studio v.4.18
How can I solve this?
Zephyr version: 1.14.99
nrf9160_pca10090ns.dts.pre.tmp:269.19-275.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
warning: MQTT_LIB_TLS (defined at subsys/net/lib/mqtt/Kconfig:30) was assigned the value 'y' but got
the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_MQTT_LIB_TLS.html (which
is updated regularly from the master branch). See the 'Setting configuration values' section of the
Board Porting Guide as well.
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol MQTT_SOCKET_LIB
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:15: warning: attempt to assign the value '2048' to the undefined symbol MQTT_MAX_PACKET_LENGTH
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:19: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:20: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:23: warning: attempt to assign the value 'y' to the undefined symbol MODEM_INFO
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:26: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:29: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:36: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:37: warning: attempt to assign the value 'n' to the undefined symbol DK_LIBRARY_INVERT_LEDS
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:50: warning: attempt to assign the value '1024' to the undefined symbol GPS_SIM_THREAD_STACK_SIZE
Error: Aborting due to non-whitelisted Kconfig warning
'/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:13: warning:
attempt to assign the value 'y' to the undefined symbol MQTT_SOCKET_LIB'. Note: If this warning
doesn't point to an actual problem, you can add it to the whitelist at the top of
/Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/scripts/kconfig/kconfig.py.
CMake Error at /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/cmake/kconfig.cmake:200 (message):
  command failed with return code: 1
  /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/cmake/app/boilerplate.cmake:529 (include)
  CMakeLists.txt:11 (include)
When I use SEGGER Embedded Studio v.4.16, there is no error.
  • Yea, I've already upgraded to v1.0.0, but I get the warning.
    cd <sourcecode_root>/ncs/nrf
    git checkout v1.0.0
  • After update, did you run west update? Attempt to assign the value... would indicate that something is missing from NCS.
  • I'm sure that I updated west twice like "west update". I installed files according Get Started Assistant.
    SEGGER Embedded Studio may have some bugs as there is no warning using 4.16 while a warning happens with 4.18.
  • This is very strange.  When following the Getting Started Assistant, did you get any warnings? What operating system are you using?
    Have you tried to delete all build folders from the project? Can you please provide the output from both v4.16 and v4.18? Along with settings in Tools > options > nRF Connect for both? I am not able to reproduce the error here, using both v4.16 and v4.18.
  • I am getting the same error. I am using Ubuntu 18.04 with SES v4.18.
    Zephyr version: 1.14.99 USING OUT OF TREE BOARD
    warning: MQTT_LIB_TLS (defined at subsys/net/lib/mqtt/Kconfig:30) was assigned the value 'y' but got the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig' interface (see the Application Development Primer section of the manual), or in the Kconfig reference at docs.zephyrproject.org/.../CONFIG_MQTT_LIB_TLS.html (which is updated regularly from the master branch). See the 'Setting configuration values' section of the Board Porting Guide as well. /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol MQTT_SOCKET_LIB /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:15: warning: attempt to assign the value '2048' to the undefined symbol MQTT_MAX_PACKET_LENGTH /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:19: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:20: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:23: warning: attempt to assign the value 'y' to the undefined symbol MODEM_INFO /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:26: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:29: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:36: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:37: warning: attempt to assign the value 'n' to the undefined symbol DK_LIBRARY_INVERT_LEDS /home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:50: warning: attempt to assign the value '1024' to the undefined symbol GPS_SIM_THREAD_STACK_SIZE Error: Aborting due to non-whitelisted Kconfig warning '/home/matt/Nordic/ncs/nrf/applications/asset_tracker/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol MQTT_SOCKET_LIB'. Note: If this warning doesn't point to an actual problem, you can add it to the whitelist at the top of /home/matt/Nordic/ncs/zephyr/scripts/kconfig/kconfig.py. CMake Error at /home/matt/Nordic/ncs/zephyr/cmake/kconfig.cmake:200 (message): command failed with return code: 1 Call Stack (most recent call first): /home/matt/Nordic/ncs/zephyr/cmake/app/boilerplate.cmake:529 (include) CMakeLists.txt:11 (include)
