Warning: USING OUT OF TREE BOARD
I deleted nrf-related files and set up nrf programs from a scratch following Get Started Assistant of nRF Connect v3.0.0
I've got this warning when I opened a project by "Open nRF Connect SDK Project".
SEGGER Embedded Studio v.4.18
How can I solve this?
Zephyr version: 1.14.99
nrf9160_pca10090ns.dts.pre.tmp:269.19-275.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
warning: MQTT_LIB_TLS (defined at subsys/net/lib/mqtt/Kconfig:30) was assigned the value 'y' but got
the value 'n'. You can check symbol information (including dependencies) in the 'menuconfig'
interface (see the Application Development Primer section of the manual), or in the Kconfig
reference at http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_MQTT_LIB_TLS.html (which
is updated regularly from the master branch). See the 'Setting configuration values' section of the
Board Porting Guide as well.
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:13: warning: attempt to assign the value 'y' to the undefined symbol MQTT_SOCKET_LIB
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:15: warning: attempt to assign the value '2048' to the undefined symbol MQTT_MAX_PACKET_LENGTH
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:19: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:20: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:23: warning: attempt to assign the value 'y' to the undefined symbol MODEM_INFO
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:26: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:29: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:36: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:37: warning: attempt to assign the value 'n' to the undefined symbol DK_LIBRARY_INVERT_LEDS
/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:50: warning: attempt to assign the value '1024' to the undefined symbol GPS_SIM_THREAD_STACK_SIZE
Error: Aborting due to non-whitelisted Kconfig warning
'/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf:13: warning:
attempt to assign the value 'y' to the undefined symbol MQTT_SOCKET_LIB'. Note: If this warning
doesn't point to an actual problem, you can add it to the whitelist at the top of
/Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/scripts/kconfig/kconfig.py.
CMake Error at /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/cmake/kconfig.cmake:200 (message):
  command failed with return code: 1
  /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/cmake/app/boilerplate.cmake:529 (include)
  CMakeLists.txt:11 (include)
When I use SEGGER Embedded Studio v.4.16, there is no error.
  • > What operating system are you using?
    Mac OS Mojave
  • Thanks, I have inquired the rest of our support team, to find any other occurrences similar to yours. Moving into vacation time will yield a longer response time.
    Have you tried what I suggested in the last comment?
    "Have you tried to delete all build folders from the project? Can you please provide the output from both v4.16 and v4.18? Along with settings in Tools > options > nRF Connect for both? I am not able to reproduce the error here, using both v4.16 and v4.18."
  • >Have you tried to delete all build folders from the project?
    Yes, I did. I saw the same result.
    --- 4.18 ---
    <transcript in 4.18>
    Loading solution asset_tracker.emProject
    Executing load commands
    /usr/local/bin/cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=/Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb/gcc-arm-none-eabi-7-2018-q2-update -B/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns -H/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=~/.local/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Applications/arm_segger_embedded_studio_v418_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Using application from '/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker'
    -- Selected BOARD nrf9160_pca10090ns
    -- Found west: /Users/fukuharayuusuke/.local/bin/west (found suitable version "0.5.8", minimum required is "0.5.6")
    -- Cache files will be written to: /Users/fukuharayuusuke/Library/Caches/zephyr
    -- Loading /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
    -- Overlaying /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/dts/common/common.dts
    Parsing Kconfig tree in /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/Kconfig
    Loading /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig as base
    Merging /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/prj.conf
    Configuration written to '/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns/zephyr/.config'
    -- The C compiler identification is GNU 7.3.1
    -- The CXX compiler identification is GNU 7.3.1
    -- Found assembler: /opt/gnuarmemb/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc
    -- Performing Test toolchain_is_ok
    -- Performing Test toolchain_is_ok - Success
    Including module: nrf in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf
    -- Using application from '/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/samples/nrf9160/spm'
    Changed board to secure nrf9160_pca10090 (NOT NS)
    -- Loading /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
    -- Overlaying /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay
    nrf9160_pca10090.dts.pre.tmp:127.18-133.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/uart@a000: duplicate unit-address (also used in node /soc/peripheral@50000000/i2c@a000)
      also defined at nrf9160_pca10090.dts.pre.tmp:526.8-528.3
    nrf9160_pca10090.dts.pre.tmp:271.19-277.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
    Parsing Kconfig tree in /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/Kconfig
    Loading /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090_defconfig as base
    Merging /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/samples/nrf9160/spm/prj.conf
    Configuration written to '/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns/spm/zephyr/.config'
    Including module: nffs in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/modules/fs/nffs
    Including module: segger in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/modules/debug/segger
    Including module: mbedtls in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/modules/crypto/mbedtls
    Including module: mcuboot in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/mcuboot/zephyr
    Including module: mcumgr in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/modules/lib/mcumgr
    Including module: tinycbor in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/modules/lib/tinycbor
    Including module: nrfxlib in path: /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrfxlib
    CMake Warning at /Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/CMakeLists.txt:1345 (message):
            --- WARNING:  __ASSERT() statements are globally ENABLED ---
            --- The kernel will run more slowly and use more memory  ---
    Running Partition Manager...
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns
    /Applications/arm_segger_embedded_studio_v418_macos_x64_nordic/bin/ninja_import all
    Loading solution build.emProject
    Mapping project information
    Mapping project all
    Mapping project merged_hex
    Mapping project CMakeFiles/merged_hex
    Mapping project zephyr/merged.hex
    Mapping project spm/zephyr/zephyr.elf
    Mapping project cmake_object_order_depends_target_spm_zephyr_final
    Mapping project cmake_object_order_depends_target_spm_app
    Mapping project spm/zephyr/spm_offsets_h
    Mapping project spm/zephyr/CMakeFiles/spm_offsets_h
    Mapping project spm/zephyr/include/generated/offsets.h
    Mapping project spm/zephyr/spm_driver_validation_h_target
    Mapping project spm/zephyr/CMakeFiles/spm_driver_validation_h_target
    Mapping project spm/zephyr/include/generated/driver-validation.h
    Mapping project spm/zephyr/spm_kobj_types_h_target
    Mapping project spm/zephyr/CMakeFiles/spm_kobj_types_h_target
    Mapping project spm/zephyr/include/generated/kobj-types-enum.h
    Mapping project spm/zephyr/include/generated/otype-to-str.h
    Mapping project cmake_object_order_depends_target_spm_offsets
    Mapping project spm/zephyr/spm_syscall_list_h_target
    Mapping project spm/zephyr/CMakeFiles/spm_syscall_list_h_target
    Mapping project spm/zephyr/include/generated/syscall_list.h
    Mapping project spm/zephyr/misc/generated/syscalls.json
    Mapping project spm/zephyr/misc/generated/syscalls_subdirs.trigger
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_app_memory
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_audio
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_bluetooth
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_cmsis_rtos_v1
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_cmsis_rtos_v2
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_crypto
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_debug
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dfu
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_display
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_fs
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_linker
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_logging
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_mgmt
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_misc
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_net
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_nvs
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_posix
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_random
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_settings
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_shell
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_toolchain
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_usb
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_zephyr
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arc
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_common
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_nios2
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_posix
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_riscv32
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_x86
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_x86_64
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_xtensa
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arc_v2
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arc_v2_mpu
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm_cortex_m
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm_cortex_m_mpu
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm_cortex_m_scripts
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_riscv32_common
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_riscv32_riscv-privilege
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_bluetooth_mesh
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_bluetooth_services
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_bluetooth
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_clock_control
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_console
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_gpio
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_i2c
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_ieee802154
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_led
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_modem
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_pci
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_pcie
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_serial
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_usb
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_wifi
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_i2c_slave
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_clock
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_gpio
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_i2c
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_interrupt-controller
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_pcie
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_pinctrl
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_rdc
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_usb
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_posix_sys
    Mapping project spm/zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_usb_class
    Mapping project spm/zephyr/include/generated/syscall_dispatch.c
    Mapping project spm/zephyr/spm_syscall_macros_h_target
    Mapping project spm/zephyr/CMakeFiles/spm_syscall_macros_h_target
    Mapping project spm/zephyr/include/generated/syscall_macros.h
    Mapping project cmake_object_order_depends_target_spm_arch__arm__core
    Mapping project cmake_object_order_depends_target_spm_arch__arm__core__cortex_m
    Mapping project cmake_object_order_depends_target_spm_arch__arm__core__cortex_m__mpu
    Mapping project cmake_object_order_depends_target_spm_drivers__serial
    Mapping project cmake_object_order_depends_target_spm_kernel
    Mapping project cmake_object_order_depends_target_spm_lib__libc__minimal
    Mapping project cmake_object_order_depends_target_spm_mbedcrypto_vanilla
    Mapping project cmake_object_order_depends_target_spm_mbeddrbg
    Mapping project spm/zephyr/isr_tables.c
    Mapping project spm/zephyr/spm_zephyr_prebuilt.elf
    Mapping project cmake_object_order_depends_target_spm_zephyr_prebuilt
    Mapping project spm/zephyr/spm_linker_script_target
    Mapping project spm/zephyr/CMakeFiles/spm_linker_script_target
    Mapping project spm/zephyr/linker.cmd
    Mapping project spm/spm_app/libspm_app.a
    Mapping project spm/zephyr/libspm_zephyr.a
    Mapping project spm/zephyr/arch/arm/core/libspm_arch__arm__core.a
    Mapping project spm/zephyr/arch/arm/core/cortex_m/libspm_arch__arm__core__cortex_m.a
    Mapping project spm/zephyr/arch/arm/core/cortex_m/mpu/libspm_arch__arm__core__cortex_m__mpu.a
    Mapping project spm/zephyr/lib/libc/minimal/libspm_lib__libc__minimal.a
    Mapping project spm/zephyr/drivers/serial/libspm_drivers__serial.a
    Mapping project spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbeddrbg.a
    Mapping project spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbedcrypto_vanilla.a
    Mapping project spm/zephyr/kernel/libspm_kernel.a
    Mapping project spm/zephyr/spm_linker_pass_final_script_target
    Mapping project spm/zephyr/CMakeFiles/spm_linker_pass_final_script_target
    Mapping project spm/zephyr/linker_pass_final.cmd
    Mapping project zephyr/zephyr.elf
    Mapping project cmake_object_order_depends_target_zephyr_final
    Mapping project cmake_object_order_depends_target_..__nrf__drivers__at_cmd
    Mapping project spm/zephyr/arch/arm/core/cortex_m/tz/nsc_veneers
    Mapping project spm/zephyr/arch/arm/core/cortex_m/tz/CMakeFiles/nsc_veneers
    Mapping project libspmsecureentries.a
    Mapping project zephyr/offsets_h
    Mapping project zephyr/CMakeFiles/offsets_h
    Mapping project zephyr/include/generated/offsets.h
    Mapping project zephyr/driver_validation_h_target
    Mapping project zephyr/CMakeFiles/driver_validation_h_target
    Mapping project zephyr/include/generated/driver-validation.h
    Mapping project zephyr/kobj_types_h_target
    Mapping project zephyr/CMakeFiles/kobj_types_h_target
    Mapping project zephyr/include/generated/kobj-types-enum.h
    Mapping project zephyr/include/generated/otype-to-str.h
    Mapping project cmake_object_order_depends_target_offsets
    Mapping project zephyr/syscall_list_h_target
    Mapping project zephyr/CMakeFiles/syscall_list_h_target
    Mapping project zephyr/include/generated/syscall_list.h
    Mapping project zephyr/misc/generated/syscalls.json
    Mapping project zephyr/misc/generated/syscalls_subdirs.trigger
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_app_memory
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_audio
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_bluetooth
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_cmsis_rtos_v1
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_cmsis_rtos_v2
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_crypto
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_debug
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dfu
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_display
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_fs
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_linker
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_logging
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_mgmt
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_misc
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_net
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_nvs
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_posix
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_random
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_settings
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_shell
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_toolchain
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_usb
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_zephyr
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arc
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_common
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_nios2
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_posix
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_riscv32
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_x86
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_x86_64
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_xtensa
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arc_v2
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arc_v2_mpu
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm_cortex_m
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm_cortex_m_mpu
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_arm_cortex_m_scripts
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_riscv32_common
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_arch_riscv32_riscv-privilege
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_bluetooth_mesh
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_bluetooth_services
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_bluetooth
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_clock_control
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_console
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_gpio
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_i2c
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_ieee802154
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_led
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_modem
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_pci
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_pcie
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_serial
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_usb
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_wifi
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_drivers_i2c_slave
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_clock
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_gpio
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_i2c
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_interrupt-controller
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_pcie
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_pinctrl
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_rdc
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_dt-bindings_usb
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_posix_sys
    Mapping project zephyr/misc/generated/syscalls_links/_Users_fukuharayuusuke_Documents_nRF9160_ncs_zephyr_include_usb_class
    Mapping project zephyr/include/generated/syscall_dispatch.c
    Mapping project zephyr/syscall_macros_h_target
    Mapping project zephyr/CMakeFiles/syscall_macros_h_target
    Mapping project zephyr/include/generated/syscall_macros.h
    Mapping project cmake_object_order_depends_target_..__nrf__drivers__gps_sim
    Mapping project cmake_object_order_depends_target_..__nrf__drivers__lte_link_control
    Mapping project cmake_object_order_depends_target_..__nrf__drivers__sensor__sensor_sim
    Mapping project cmake_object_order_depends_target_..__nrf__ext__cjson
    Mapping project cmake_object_order_depends_target_..__nrf__lib__at_cmd_parser
    Mapping project cmake_object_order_depends_target_..__nrf__lib__at_host
    Mapping project cmake_object_order_depends_target_..__nrf__lib__bsdlib
    Mapping project cmake_object_order_depends_target_..__nrf__lib__dk_buttons_and_leds
    Mapping project cmake_object_order_depends_target_..__nrf__lib__modem_info
    Mapping project cmake_object_order_depends_target_..__nrf__subsys__net__lib__cloud
    Mapping project cmake_object_order_depends_target_..__nrf__subsys__net__lib__mqtt_socket
    Mapping project cmake_object_order_depends_target_..__nrf__subsys__net__lib__nrf_cloud
    Mapping project cmake_object_order_depends_target_app
    Mapping project cmake_object_order_depends_target_arch__arm__core
    Mapping project cmake_object_order_depends_target_arch__arm__core__cortex_m
    Mapping project cmake_object_order_depends_target_arch__arm__core__cortex_m__mpu
    Mapping project cmake_object_order_depends_target_drivers__gpio
    Mapping project cmake_object_order_depends_target_drivers__serial
    Mapping project cmake_object_order_depends_target_kernel
    Mapping project cmake_object_order_depends_target_lib__libc__newlib
    Mapping project cmake_object_order_depends_target_subsys__net
    Mapping project cmake_object_order_depends_target_subsys__net__ip
    Mapping project zephyr/isr_tables.c
    Mapping project zephyr/zephyr_prebuilt.elf
    Mapping project cmake_object_order_depends_target_zephyr_prebuilt
    Mapping project zephyr/linker_script_target
    Mapping project zephyr/CMakeFiles/linker_script_target
    Mapping project zephyr/linker.cmd
    Mapping project app/libapp.a
    Mapping project zephyr/libzephyr.a
    Mapping project zephyr/arch/arm/core/libarch__arm__core.a
    Mapping project zephyr/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a
    Mapping project zephyr/arch/arm/core/cortex_m/mpu/libarch__arm__core__cortex_m__mpu.a
    Mapping project zephyr/lib/libc/newlib/liblib__libc__newlib.a
    Mapping project zephyr/subsys/net/libsubsys__net.a
    Mapping project zephyr/subsys/net/ip/libsubsys__net__ip.a
    Mapping project zephyr/drivers/gpio/libdrivers__gpio.a
    Mapping project zephyr/drivers/serial/libdrivers__serial.a
    Mapping project zephyr/modules/nrf/ext/cjson/lib..__nrf__ext__cjson.a
    Mapping project zephyr/modules/nrf/lib/bsdlib/lib..__nrf__lib__bsdlib.a
    Mapping project zephyr/modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a
    Mapping project zephyr/modules/nrf/lib/at_host/lib..__nrf__lib__at_host.a
    Mapping project zephyr/modules/nrf/lib/at_cmd_parser/lib..__nrf__lib__at_cmd_parser.a
    Mapping project zephyr/modules/nrf/lib/modem_info/lib..__nrf__lib__modem_info.a
    Mapping project zephyr/modules/nrf/subsys/net/lib/cloud/lib..__nrf__subsys__net__lib__cloud.a
    Mapping project zephyr/modules/nrf/subsys/net/lib/mqtt_socket/lib..__nrf__subsys__net__lib__mqtt_socket.a
    Mapping project zephyr/modules/nrf/subsys/net/lib/nrf_cloud/lib..__nrf__subsys__net__lib__nrf_cloud.a
    Mapping project zephyr/modules/nrf/drivers/at_cmd/lib..__nrf__drivers__at_cmd.a
    Mapping project zephyr/modules/nrf/drivers/gps_sim/lib..__nrf__drivers__gps_sim.a
    Mapping project zephyr/modules/nrf/drivers/lte_link_control/lib..__nrf__drivers__lte_link_control.a
    Mapping project zephyr/modules/nrf/drivers/sensor/sensor_sim/lib..__nrf__drivers__sensor__sensor_sim.a
    Mapping project zephyr/kernel/libkernel.a
    Mapping project zephyr/linker_pass_final_script_target
    Mapping project zephyr/CMakeFiles/linker_pass_final_script_target
    Mapping project zephyr/linker_pass_final.cmd
    Populating dynamic folders
    Populating folder ‘dts files’
    Preparing solution ‘asset_tracker’
    Preparing solution ‘build’
    Preparing project ‘all’
    Preparing project ‘spm/zephyr/zephyr.elf’
    Preparing project ‘spm/zephyr/spm_zephyr_prebuilt.elf’
    Preparing project ‘spm/spm_app/libspm_app.a’
    Preparing project ‘spm/zephyr/libspm_zephyr.a’
    Preparing project ‘spm/zephyr/arch/arm/core/libspm_arch__arm__core.a’
    Preparing project ‘spm/zephyr/arch/arm/core/cortex_m/libspm_arch__arm__core__cortex_m.a’
    Preparing project ‘spm/zephyr/arch/arm/core/cortex_m/mpu/libspm_arch__arm__core__cortex_m__mpu.a’
    Preparing project ‘spm/zephyr/lib/libc/minimal/libspm_lib__libc__minimal.a’
    Preparing project ‘spm/zephyr/drivers/serial/libspm_drivers__serial.a’
    Preparing project ‘spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbeddrbg.a’
    Preparing project ‘spm/zephyr/modules/nrfxlib/nrf_security/src/mbedtls/libspm_mbedcrypto_vanilla.a’
    Preparing project ‘spm/zephyr/kernel/libspm_kernel.a’
    Preparing project ‘zephyr/zephyr.elf’
    Preparing project ‘zephyr/zephyr_prebuilt.elf’
    Preparing project ‘app/libapp.a’
    Preparing project ‘zephyr/libzephyr.a’
    Preparing project ‘zephyr/arch/arm/core/libarch__arm__core.a’
    Preparing project ‘zephyr/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a’
    Preparing project ‘zephyr/arch/arm/core/cortex_m/mpu/libarch__arm__core__cortex_m__mpu.a’
    Preparing project ‘zephyr/lib/libc/newlib/liblib__libc__newlib.a’
    Preparing project ‘zephyr/subsys/net/libsubsys__net.a’
    Preparing project ‘zephyr/subsys/net/ip/libsubsys__net__ip.a’
    Preparing project ‘zephyr/drivers/gpio/libdrivers__gpio.a’
    Preparing project ‘zephyr/drivers/serial/libdrivers__serial.a’
    Preparing project ‘zephyr/modules/nrf/ext/cjson/lib..__nrf__ext__cjson.a’
    Preparing project ‘zephyr/modules/nrf/lib/bsdlib/lib..__nrf__lib__bsdlib.a’
    Preparing project ‘zephyr/modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a’
    Preparing project ‘zephyr/modules/nrf/lib/at_host/lib..__nrf__lib__at_host.a’
    Preparing project ‘zephyr/modules/nrf/lib/at_cmd_parser/lib..__nrf__lib__at_cmd_parser.a’
    Preparing project ‘zephyr/modules/nrf/lib/modem_info/lib..__nrf__lib__modem_info.a’
    Preparing project ‘zephyr/modules/nrf/subsys/net/lib/cloud/lib..__nrf__subsys__net__lib__cloud.a’
    Preparing project ‘zephyr/modules/nrf/subsys/net/lib/mqtt_socket/lib..__nrf__subsys__net__lib__mqtt_socket.a’
    Preparing project ‘zephyr/modules/nrf/subsys/net/lib/nrf_cloud/lib..__nrf__subsys__net__lib__nrf_cloud.a’
    Preparing project ‘zephyr/modules/nrf/drivers/at_cmd/lib..__nrf__drivers__at_cmd.a’
    Preparing project ‘zephyr/modules/nrf/drivers/gps_sim/lib..__nrf__drivers__gps_sim.a’
    Preparing project ‘zephyr/modules/nrf/drivers/lte_link_control/lib..__nrf__drivers__lte_link_control.a’
    Preparing project ‘zephyr/modules/nrf/drivers/sensor/sensor_sim/lib..__nrf__drivers__sensor__sensor_sim.a’
    Preparing project ‘zephyr/kernel/libkernel.a’
    Restoring state from previous session
    Preparing to load data
    Loading session data from file
    SEGGER Embedded Studio is ready to use
    --- 4.16 ---
    <transcript in 4.16>
    /usr/local/bin/cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=/Users/fukuharayuusuke/Documents/nRF9160/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb/gcc-arm-none-eabi-7-2018-q2-update -B/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090ns -H/Users/fukuharayuusuke/Documents/nRF9160/ncs/nrf/applications/asset_tracker -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DCMAKE_MAKE_PROGRAM=/usr/local/bin/ninja -DDTC=/usr/local/bin/dtc -D WEST=~/.local/bin/west -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/Applications/arm_segger_embedded_studio_v416_macos_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Found PythonInterp: /usr/local/bin/python3 (found suitable version "3.7.3", minimum required is "3.4")
    -- Configuring done
    -- Generating done
    /Applications/arm_segger_embedded_studio_v416_macos_x64_nordic/bin/ninja_import all -hide zephyr/zephyr_prebuilt.elf -show zephyr/merged.hex
    Mapping project all
    Preparing project ‘zephyr/merged.hex’
    Preparing project ‘libspmsecureentries.a’
    Can you please provide the build output where the warning message is printed? From both 4.16 and 4.18.
    Thank you!
    -Øyvind
  • When I open a project file, the warning shows up, not when it's built. Please read the first post
