Unable to communicate with DS1307 using Twi sensor example SDKv15.3.0 on Rigardo nRF52 DK
HI
I started off to test all the drivers before the actual development process kickstarts.I tried using the TWI sensor example for an i2c driver check.I used a DS1307 simple RTC for it.But i am unable to even send my first data frame and here is my code.when I tried debugging the code ,it seems to be stuck in the while loop for completion check of  first tx transmission .
Can you point out my mistakes and any other suggestion i need to check .
Here are the complete specs
Board Rigardo BMD 350
SDK v15.3.0
DS1307 connection with Rigardo board
SCL PIN-->pin0.27
SDA PIN-->pin0.26
GND      -->GND
VCC (not connected using coin cell battery for power )
Rigardo board is powered by USB wire
Thanks in advance
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID     0
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR          (0x90U >> 1)
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
#define DS1307_ADDR        (0x68)
#define DS1307_SEC (0x00)
#define DS1307_MIN (0x01)
#define DS1307_HRS (0x02)
#define DS1307_DAY (0x03)
#define DS1307_DATE (0x04)
#define DS1307_MONTH (0x05)
#define DS1307_YEAR (0x06)
typedef struct
    uint8_t s;
    uint8_t m;
    uint8_t h;
} sum_t;
static sum_t m_sum = {0};
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample[3];
 * @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
    ret_code_t err_code;
uint8_t reg[2] = {0x00,0x00};
    err_code = nrf_drv_twi_tx(&m_twi,DS1307_ADDR, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg1[8] = {DS1307_SEC,0x15,0x59,0x14,0x06,0x05,0x07,0x19};
    err_code = nrf_drv_twi_tx(&m_twi,DS1307_ADDR, reg1, sizeof(reg1), false);
    uint8_t reg1[2] = {DS1307_MIN,0x38};
		uint8_t reg2[2] = {DS1307_HRS,0x14};
    err_code = nrf_drv_twi_tx(&m_twi, DS1307_ADDR, reg2, sizeof(reg2), false);
		uint8_t reg3[2] = {DS1307_DAY,0x06};
    err_code = nrf_drv_twi_tx(&m_twi, DS1307_ADDR, reg3, sizeof(reg3), false);
		uint8_t reg4[2] = {DS1307_DATE,0x05};
    err_code = nrf_drv_twi_tx(&m_twi, DS1307_ADDR, reg4, sizeof(reg3), false);
		uint8_t reg5[2] = {DS1307_MONTH,0x07};
    err_code = nrf_drv_twi_tx(&m_twi, DS1307_ADDR, reg5, sizeof(reg3), false);
		uint8_t reg6[2] = {DS1307_YEAR,0x19};
    err_code = nrf_drv_twi_tx(&m_twi, DS1307_ADDR, reg6, sizeof(reg3), false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t *temp)
    //NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
    /* Subtracting oldest sample. */
    m_sum.s    = temp[1];
    m_sum.m    = temp[2];
    m_sum.h    = temp[3];
	NRF_LOG_INFO("%2x: %2x:%2x",
                m_sum.h ,
                m_sum.m ,
                m_sum.s
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_lm75b_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOW,
       .clear_bus_init     = false
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, DS1307_ADDR, (uint8_t*)&m_sample, 3);
    const uint8_t reg= 0x00;
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    LM75B_set_mode();
    while (true)
        nrf_delay_ms(500);
        ret_code_t err_code = nrf_drv_twi_tx(&m_twi, DS1307_ADDR, &reg, sizeof(reg), true);
			  read_sensor_data();
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
  • Thanks @awneil have at last corrected the issue .It is same as what you said about device addressing .When i used my old controller and monitored those lines i saw the device ACK  to left justified address.If i had paid attention to the driver i wrote i could have rectified it sooner.Now i am getting fatal error and system reset when the code is going into read routine.I guess that's a new case in itself .Thanks for the help anyway.
