Hi all,
I added ble central multilink example with ble_app_uart_c code, i am able to compile code successfully, but not able to run this code on board due to this error.
<error> app: Fatal error
Please find the attached main.c and sdk_config.c file for reference.
Nrf52 sdk used : 15.01
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_advdata.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_ble_scan.h"
static nrf_drv_uart_t app_uart_inst = NRF_DRV_UART_INSTANCE(APP_UART_DRIVER_INSTANCE);
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define UART_TX_BUF_SIZE 1024 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1024 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< BLE NUS service client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT); /**< Database discovery module instances. */
NRF_BLE_SCAN_DEF(m_scan);
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static uint8_t data_crc[BLE_NUS_MAX_DATA_LEN];
void uart_event_handle(app_uart_evt_t * p_event);
static char const m_target_periph_name[] = "Nordic_UART";
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
(uint16_t)SLAVE_LATENCY, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
m_scan_buffer_data,
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
.active = 1,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_1MBPS,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
/**@brief Function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void)
ret_code_t ret;
NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
// Turn on the LED to signal scanning.
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
NRF_LOG_DEBUG("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!",
p_evt->conn_handle,
p_evt->conn_handle);
ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
/**@brief Function for handling characters received by the Nordic UART Service.
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static uint32_t ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
uint8_t byte[1024] = {0};
uint32_t check = 0;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
byte[i] = p_data[i];
bsp_board_led_invert(BSP_BOARD_LED_0);
return nrf_drv_uart_tx(&app_uart_inst,byte,data_len);
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
static uint16_t index = 0;
uint8_t rx_byte;
uint32_t ret_val;
uint32_t get_state;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
do
get_state = app_uart_get(&rx_byte);
if(get_state == NRF_SUCCESS)
data_array[index] = rx_byte;
if( data_array[index] == 0x03 || index + 1 >= m_ble_nus_max_data_len )
if(m_ble_nus_c->conn_handle != BLE_CONN_HANDLE_INVALID)
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if(0)
index = 0;
index++;
if(index > sizeof(data_array))
index = 0;
while(get_state == NRF_SUCCESS);
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling NUS Client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
* @param[in] p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
* @brief Function for shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Function for handling the advertising report BLE event.
* @param[in] p_adv_report Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
&m_scan_params,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
if (err_code == NRF_SUCCESS)
// scan is automatically stopped by the connect
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_adv_report->peer_addr.addr[0],
p_adv_report->peer_addr.addr[1],
p_adv_report->peer_addr.addr[2],
p_adv_report->peer_addr.addr[3],
p_adv_report->peer_addr.addr[4],
p_adv_report->peer_addr.addr[5]
err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&p_gap_evt->params.adv_report);
break; // BLE_GAP_EVT_ADV_REPORT
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
p_gap_evt->conn_handle);
err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle], p_ble_evt->evt.gap_evt.conn_handle, NULL);
err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
if (err_code != NRF_ERROR_BUSY)
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
NRF_LOG_INFO("Scan timed out.");
scan_start();
else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
// Pairing not supported
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c->conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
nrf_pwr_mgmt_run();
// Initialize.
log_init();
timer_init();
uart_init();
buttons_leds_init();
db_discovery_init();
power_management_init();
ble_stack_init();
gatt_init();
nus_c_init();
// Start execution.
printf("BLE UART central example started.\r\n");
NRF_LOG_INFO("BLE UART central example started.");
scan_start();
// Enter main loop.
for (;;)
idle_state_handle();
