How to vary gain in SAADC example nrf52832 SDK15.3 ?
Im using nrf52832 kit with sdk15.3 SAADC example for ADC output, which is working fine but im not getting how to vary gain.
i want to set gain these values  1,2,4,5,8,10,16,32 . Im using only 1 channel channel0 (AIN0).
Is it possible to set more than one gain value to only 1 channel ?
please suggest
  • You will need to execute a new ADC measurement for each configuration, only 1 gain setting can be active at the time.
  • Hello Kenneth,
    Im trying to configure or set gain in  SAADC example, for various gains it should operate but im not getting how to set gain register so that i get SAADC output depending on various gain and even i tried to change gain values in nrfx.saadc.h file but getting error. gains defined in nrfx.saadc.h files are default one but i want it to work as per my amplifier. So how can i define gains and make it work properly. Im using only 1channel AIN0
    Presently its working properly with default gain values.
    Please Suggest.
  • If you base your code on \examples\peripheral\saadc\ I believe this should be straight forward. Simply call nrf_drv_saadc_channel_init(), nrf_drv_saadc_buffer_convert(), and nrf_drv_saadc_channel_uninit() for each gain setting you want to sample.
  • but if i define gain in nrf.saadc.h then it gives error.
    it works fine for default gain, but i want to set gain with different values. How can i do that ?
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup nrf_adc_example main.c
     * @ingroup nrf_adc_example
     * @brief ADC Example Application main file.
     * This file contains the source code for a sample application using ADC.
     * @image html example_board_setup_a.jpg "Use board setup A for this example."
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #include "nrf_drv_timer.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_timer.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    //-------------------------spi code---------------------------
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #define SPI_INSTANCE  1 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    //#define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[00100000];           /**< TX buffer. */
    static uint8_t       m_rx_buf[40];    /**< RX buffer. */
    //static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
     * @brief SPI user event handler.
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event)
       spi_xfer_done = true;
    		NRF_LOG_INFO(" Sent %d bytes: ", p_event->data.done.tx_length);
    		for(int i=0; i< p_event->data.done.tx_length;i++)
    				NRF_LOG_INFO(" ;(0x%x); ",p_event->data.done.p_tx_buffer[i], p_event->data.done.p_tx_buffer[i]);
    		//NRF_LOG_INFO("\r\n");
    		NRF_LOG_INFO(" Received %d bytes: ", p_event->data.done.rx_length);
    		 for(int i=0; i< p_event->data.done.rx_length;i++)
    				NRF_LOG_INFO(" ;(0x%x); ",p_event->data.done.p_rx_buffer[i], p_event->data.done.p_rx_buffer[i]);
    				nrf_delay_ms(5);
    		//NRF_LOG_INFO("\r\n\n");
    void spi_con(void)
     nrf_gpio_cfg_output(18); //Configure pin 18 as output
     NRF_CLOCK->TASKS_HFCLKSTART = 1; //Start high frequency clock
     while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
          //Wait for HFCLK to start
     NRF_CLOCK->EVENTS_HFCLKSTARTED = 0; //Clear event
     //Configure GPIOTE to toggle pin 18
     NRF_GPIOTE->CONFIG[0] = GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos |
                             GPIOTE_CONFIG_POLARITY_Toggle << GPIOTE_CONFIG_POLARITY_Pos |
                             18 << GPIOTE_CONFIG_PSEL_Pos |
                             GPIOTE_CONFIG_OUTINIT_Low << GPIOTE_CONFIG_OUTINIT_Pos;
     //Configure timer
     NRF_TIMER1->PRESCALER = 3;
     NRF_TIMER1->CC[0] = 1;  // Adjust the output frequency by adjusting the CC.
     NRF_TIMER1->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
     NRF_TIMER1->TASKS_START = 1;
     //Configure PPI
     NRF_PPI->CH[0].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[0];
     NRF_PPI->CH[0].TEP = (uint32_t) &NRF_GPIOTE->TASKS_OUT[0];
     NRF_PPI->CHENSET = PPI_CHENSET_CH0_Enabled << PPI_CHENSET_CH0_Pos;
        LEDS_CONFIGURE(BSP_LED_0_MASK);
        LEDS_OFF(BSP_LED_0_MASK);
    		nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        NRF_LOG_INFO("SPI example started.");
            // Reset rx buffer and transfer done flag
            memset(m_rx_buf, 0, 40);
            spi_xfer_done = false;
    			  m_tx_buf[0]=0x0d;
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 2, m_rx_buf, 40));
            while (!spi_xfer_done)
                __WFE();
    #define SAMPLES_IN_BUFFER 20
    volatile uint8_t state = 1;
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    int GAIN=0;
    void timer_handler(nrf_timer_event_t event_type, void * p_context)
        ret_code_t err_code;
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 100);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            int i;
            NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
            for (i = 0; i < SAMPLES_IN_BUFFER; i++)
                NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
            m_adc_evt_counter++;
    void saadc_init(void)
        nrf_saadc_channel_config_t channel_config =
         NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
        switch(GAIN)
    			case 1:
    				nrf_drv_saadc_channel_uninit(NRF_SAADC_GAIN1);
    			case 2:
    			 nrf_drv_saadc_channel_uninit (NRF_SAADC_GAIN2);
    			case 3:
    				nrf_drv_saadc_channel_uninit(NRF_SAADC_GAIN4);
    				NRF_LOG_INFO("no operation");
        err_code = nrf_drv_saadc_init(NULL, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
        uint32_t err_code = NRF_LOG_INIT(NULL);
        ret_code_t ret_code = nrf_pwr_mgmt_init();
        APP_ERROR_CHECK(ret_code);
    		spi_con();
        saadc_init();
        saadc_sampling_event_init();
        NRF_LOG_INFO("SAADC HAL simple example started.");
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
    Hello Kenneth,
    I have attached code please verify the code and give feedback what changes to be made if required.
    As channel 0 consists of AIN0-AIN7 so i want each of AIN pins to get configured with each gain. I have added switch case but im not sure with code what i did. I want t use each gain defined in header file.
    Please suggest
    /** @file
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nrf.h"
    #include "boards.h"
     * @param event
    				nrf_delay_ms(5);
    void spi_con(void)
     //Configure timer
     //Configure PPI
    			  m_tx_buf[0]=0x0d;
                __WFE();
    int GAIN=0;
                                       ticks,
                                       false);
            int i;
        switch(GAIN)
    			case 1:
    			case 2:
    			case 3:
    		spi_con();
        saadc_init();
        while (1)
            nrf_pwr_mgmt_run();
            NRF_LOG_FLUSH();
    Hello Kenneth,
    Please suggest
