Now I use sdk15.2.0 hrs project to add the spim.
the mode of the spi is timer+ppi+spi.
question:1.I can't enter the led_timer_handler on time;2.I can't get the right data,when I enable the ble advertise.
no you're going to need to ask a much better question than this with proper details if you expect anyone to be able to help you.
OK,thank you.
my demon code like this.I use spim to read data from the external ADC.
void my_ppi_init(void)
uint32_t err_code = NRF_SUCCESS;
err_code = nrf_drv_ppi_init();//init PPI
err_code = nrf_drv_timer_init(&m_timer1, NULL, timer_handler1);//init timer 1
/* setup m_timer for compare event every 15us */
uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer1, 15);
nrf_drv_timer_extended_compare(&m_timer1, NRF_TIMER_CC_CHANNEL0, ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);//Setting comparison events
nrf_drv_timer_enable(&m_timer1);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer1, NRF_TIMER_CC_CHANNEL0);
uint32_t spi_start_event_addr = nrf_drv_spi_start_task_get(&spi);
uint32_t spi_end_event_addr = nrf_drv_spi_end_event_get(&spi);
uint32_t gpiote_out_event_addr = nrf_drv_gpiote_out_task_addr_get(SPI_SS_PIN);
err_code = nrf_drv_ppi_channel_alloc(&time_ppi_channel);
err_code = nrf_drv_ppi_channel_assign(time_ppi_channel, timer_compare_event_addr, gpiote_out_event_addr);
err_code=nrf_drv_ppi_channel_fork_assign(time_ppi_channel,spi_start_event_addr);
err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, spi_end_event_addr, gpiote_out_event_addr);
err_code = nrf_drv_ppi_channel_enable(time_ppi_channel);
err_code = nrf_drv_ppi_channel_enable(m_ppi_channel);
void spi_event(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_count++;
if(spi_count==data_num)
spi_count=0;
NRF_SPIM0->TXD.PTR=(uint32_t)&SPIWriteList;
NRF_SPIM0->RXD.PTR=(uint32_t)&SPIReadList1;
send_flag = 1;
void CS_Gpiote_Init(void) {
uint32_t err_code; //???GPIOTE????
nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(true); //???GPIOTE????,?????????GPIOTE??
err_code = nrf_drv_gpiote_out_init(SPI_SS_PIN, &config);
APP_ERROR_CHECK(err_code); //???? ??GPIOTE???????
nrf_drv_gpiote_out_task_enable(SPI_SS_PIN);
nrf_drv_gpiote_out_set(SPI_SS_PIN);
void ADC_SPIDMA_Init (void)
uint8_t i=0;
uint8_t j=0;
uint8_t temp_H,temp_L;
NRF_SPIM0->TXD.MAXCNT = 2;
NRF_SPIM0->TXD.LIST=1;
NRF_SPIM0->TXD.PTR=(uint32_t)SPISeletList;
NRF_SPIM0->RXD.MAXCNT = 2;
NRF_SPIM0->RXD.LIST=1;
NRF_SPIM0->RXD.PTR=(uint32_t)SPIReadList1;
void ad7689_spi_init(void)
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
// spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event, NULL));
CS_Gpiote_Init();
ADC_SPIDMA_Init();
void ad7689_readdata(uint16_t *buff)
uint8_t i=0;
uint16_t tmp=0;
for(i=0;i<85;i++)
tmp=SPIReadList1[i].buffer[0];
buff[i]=(tmp<<8)|SPIReadList1[i].buffer[1];
but I find that if I only enable "NRF_SPIM0->TXD.LIST" like this code,the ble can run on right way(the leds_timer_handler can callback on time,the app can search the device).but I can't read the ADCdata.
void * p_context)
spi_count++;
spi_count=0;
NRF_SPIM0->TXD.PTR=(uint32_t)SPIWriteList;
// NRF_SPIM0->RXD.PTR=(uint32_t)SPIReadList1;
send_flag = 1;
SO I use next code,I enable "NRF_SPIM0->TXD.LIST" and "NRF_SPIM0->RXD.LIST".but the ble can't run on right way(the leds_timer_handler can't callback on time,the led always light).
and the SPI data have some wrong data.if I close ble advertise ,I can get the right data throught serial port
uint8_t i=0;
uint8_t j=0;
void * p_context)
spi_count++;
spi_count=0;
send_flag = 1;
question:1.Is the way I use SPI correct?if wrong,please give me a demon code;
2. why I close the ble advertise,I can get the right data throught serial port?
Hi.
I would not recommend that you use the SPI driver while also accessing the registers manually, this is bound to give you trouble.
How do you define the buffers you use? (SPISeletList, SPIReadList1, SPIWriteList)
How ofter do you read the ADC? Very high frequency could give you trouble with BLE. If you have a low frenquency you might not need the list function.
I would recommend that you take a look at the example found in examples\peripheral\spi\main.c for the SPI driver.
Andreas
thank you ,AndreasF.
1.SPI driver code like this,it's same as me to set register.
__STATIC_INLINE void nrf_spim_tx_buffer_set(NRF_SPIM_Type * p_reg,
uint8_t const * p_buffer,
size_t length)
p_reg->TXD.PTR = (uint32_t)p_buffer;
p_reg->TXD.MAXCNT = length;
I define these buffer like this
typedef struct ArrayList
uint8_t buffer[2];
}ArrayList_type;
the frequence to read ADC is about 64Khz,so I set timer1 about 15us to trigger the ADC read
Hi again.
NORDIC_SUR said:1.SPI driver code like this,it's same as me to set register.
Why don't you use the driver then? When you mix up registers and drivers the chance of having bugs increase and it is really hard to read your code. Are you trying to implement something that the driver does not support, since you want to mix the driver usage with your own implementation.
64 kHz is quick, you should set up 64 buffers so that you can read data once each millisecond.
Andreas
