Hey, I am trying to incorporate an app timer using the app timer function already on the code in the central and peripheral examples of the SDK for the UART examples. Specifically, I would like to incorporate it into the "uart_event_handle" functions. As you can see, the code has a trigger that waits until a "\n" is found in the array. Instead I would like to make the array collect until the end of a certain time interval and then send that array, then empty the array and repeat the process every interval. I have no idea how this code works so if I could get any help on what kind of logic needs to be put, where to initialize what, etc. Thanks
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
(err_code != NRF_ERROR_NOT_FOUND) )
} while (err_code == NRF_ERROR_BUSY);
index = 0;
case APP_UART_FIFO_ERROR:
