problems upgrading nrfConnect for Desktop from 2.6 to 2.7 and higher on LInux
Upgrading from nrfConnect for Desktop from v 2.6  to v 2.7 and higher and its associated apps seems to hang on Linux (ubuntu 16.04). 'strace' suggests that the problem may be related to fusefs and appImage.
I originally installed the development environment for the 9160DK using the 'Getting Started' app for nrfConnect 2.6. The 'LTE monitor' app worked as expected with at_client, as did asset_tracker.
When nrfConnect offered to upgrade to v 2.7 and later to v 3.0, I accepted both times. I also upgraded the 'Getting Started' app, via the 'add/remove apps' menu. With both 2.7 and 3.0, I observe the following failure:
Launching the  'Getting Started' app (now at v 1.0.0), hangs with a blank window and spinning blue icon. The 'LTE monitor' app (still at v 0.9.0, since I didn't upgrade it) also hangs with a blank window and spinning blue icon.
Returning to nrfConnect v 2.6 lets the 'LTE monitor' (still at v 0.9.0) app work again, but the 'Getting Started' app (now at v.1.0.0) still hangs with the spinning blue icon.
Running strace on nrfConnect v 3.0 and running the 'Getting Started' app (v 1.0.0 ) shows a mount permission error and a /bin/fusermount error.
Given the EPERM error, I tried running nrfConnect as root. This hangs hard, with strace showing a tight loop of read/write calls between  the  AppImage and /dev/fuse.
Any suggestions?
  • Hi Laura,
    I would suggest that you delete nRF Connect for Desktop and then re-install nRF Connect for Desktop v3.0 and then "check for updates" as described in this thread.
  • Same issue.
    To reproduce  ubuntu 16.04:
    * running as user (not root)
    * remove .nrfConnect_apps and .config/nrfconnect  from homedir (ie. remove trace of previous install)
    * download ./nrfconnect300x8664.AppImage from the link above
    * start ./nrfconnect300x8664.AppImage
    * use add/remove apps to add Getting Started Assistant (only)
    * use settings menu to check for updates, none are reported
    nrfConnect outputs:
    Installed: X-AppImage-BuildId=de8d6af0-9d82-11a9-30b5-17cb37eb2905 image: X-AppImage-BuildId=de8d6af0-9d82-11a9-30b5-17cb37eb2905
    [18:01:30.689] [info] Checking for update
    [18:01:32.287] [info] Update for version 3.0.0 is not available (latest version: 3.0.0, downgrade is disallowed.
    [18:01:37.146] [info] Checking for update
    [18:01:38.258] [info] Update for version 3.0.0 is not available (latest version: 3.0.0, downgrade is disallowed.
    * use launch apps menu to launch Getting Started Assistant (only app available)
    This creates a blank window with spinning blue icon and hangs
    running under strace still shows the following errors:
    5308 mount("nrfconnect300x8664.AppImage", "/tmp/.mount_nrfconLaqfiI", "fuse.nrfconnect300x8664.AppImage", MS_RDONLY|MS_NOSUID|MS_NODEV, "fd=5,rootmode=40000,user_id=1000"...) = -1 EPERM (Operation not permitted)
    5309 mount("nrfconnect300x8664.AppImage", ".", "fuse.nrfconnect300x8664.AppImage", MS_RDONLY|MS_NOSUID|MS_NODEV, "fd=6,rootmode=40000,user_id=1000"...) = -1 EPERM (Operation not permitted)
    5309 write(2</dev/null>, "fusermount: mount failed: Operat"..., 50) = -1 EBADF (Bad file descriptor)
    5310 mount("/dev/fuse", ".", "fuse", MS_RDONLY|MS_NOSUID|MS_NODEV, "fd=6,rootmode=40000,user_id=1000"...) = -1 EPERM (Operation not permitted)
    I  installed and launched the  'LTE Link Monitor' app in  the same way and have the same problem.
    Again, when I used nrfConnect v 2.6, I had no problem using the Getting Started app to install s/w,  build at_client and asset_tracker in SES and connect to the 9160DK by launching LTE Link Monitor in nrfConnect.   at_client and asset_tracker both worked as expected.  I was also able to upgrade the nrf9160 firmware to support nb-iot and this also worked with LTE Link Monitor for nb-iot connectivity.
    Under 3.0, I cannot even launch the 'Getting Started' app.   (So I'm not sure what the link above about upgrading firmware on the nrf9160 should help? )  I can't even use the app to check/upgrade the software on my computer, much less connect to the card using LTE Link Monitor, since both apps hang.  I see suspicious Fuse errors in the strace.  It's the only  really strange thing I see, though I'm happy to send full strace privately.
    Do the new versions of any of these apps  and/or  appImage use the fuse file system differently?
    Thanks!
  • Hi Laura,
    Unfortunately, Ubuntu 16.04 is too old to run nRF Connect v3.0.0.
    I highly recommend that you upgrade your OS to e.g. Ubuntu 18.04.
    You can confirm this by checking the dev. console when the window open is stuck at a white screen by ctrl+shift+i then you should see an error about libstdc++ required version not found.
    Martin L.
  • Thanks for the info.
    The nrfConnect apps are still documented as supported for Ubuntu 14.04, 16.04 and 18.04. So it would probably be helpful to update the documentation.  See e.g. https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nc_programmer%2FUG%2Fnrf_connect_programmer%2Fncp_introduction.html
    The issue does not seem to be local my installation, as a similar issue has been posted to the ubuntu support forums. So it might be helpful to contribute there as well.  See e.g. https://askubuntu.com/q/1155133
    I don't think many developers would expect ugrading an app to require a full-scale OS upgrade to their entire development environment, without at least some warning.  Especially if "downgrade is disallowed" for the app.
    So I think we'll try to work around this locally.
    Laura
  • Hi Laura,
    Thank you for the feedback.
    I agree that the documentation should be updated, I will forward this internally.
    Best Regards,
    Martin L.
