How to turn on/off GPS while LTE is on?
I'm attempting t to turn on and off GPS function while LTE is on, but it doesn't work out. I merged mqtt_simple and gps example programs into a new project. What's wrong with the program?
In configure_gps_off_on function, buf stores "ERROR" in the line of bytes_received = recv(at_sock, buf, 2, 0),  which means that receiving data through socket does not work.
ncs version: 1.0.0
In version 1.0.0, is it possible to use LTE and GPS at the same time?
<prj.conf>
# General config
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_NEWLIB_LIBC=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=4
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# BSD library
CONFIG_BSD_LIBRARY=y
# AT Host
CONFIG_AT_HOST_LIBRARY=y
# MQTT
CONFIG_MQTT_LIB=y
CONFIG_MQTT_LIB_TLS=n
# Appliaction
CONFIG_MQTT_PUB_TOPIC="myPubTopic"
CONFIG_MQTT_SUB_TOPIC="mySubTopic"
CONFIG_MQTT_CLIENT_ID="myClientID"
CONFIG_MQTT_BROKER_HOSTNAME="xxxxxxxx.com"
CONFIG_MQTT_BROKER_PORT=xxxx
# Main thread
CONFIG_MAIN_THREAD_PRIORITY=7
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=1024
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
CONFIG_NET_UDP=n
CONFIG_NET_TCP=n
CONFIG_NET_RX_STACK_SIZE=256
CONFIG_NET_TX_STACK_SIZE=256
<main.c>
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr.h>
#include <stdio.h>
#include <uart.h>
#include <string.h>
#include <net/mqtt.h>
#include <nrf_socket.h>
#include <net/socket.h>
#include <lte_lc.h>
#include <stdio.h>
#define MQTT_USERNAME "username"
#define MQTT_PASSWORD "password"
#define AT_XSYSTEMMODE_EN_M1_GPS "AT\%XSYSTEMMODE=1,0,1,0" // %XSYSTEMMODE=<M1_support>,<NB1_support>,<GNSS_support>,<LTE_preference>
#define AT_XSYSTEMMODE_EN_M1 "AT\%XSYSTEMMODE=1,0,0,0"
#define AT_CFUN_EN_MODEM "AT+CFUN=1"
/* Set the modem functional mode.
 * 0 – Power off
 * 1 – Normal mode
 * 4 – Offline mode
 * 44 – Offline mode without shutting down UICC */
#ifdef CONFIG_BOARD_NRF9160_PCA10090NS
#define AT_MAGPIO_EN_GPS "AT\%XMAGPIO=1,0,0,1,1,1574,1577" // %XMAGPIO=<MAGPIO0>,<MAGPIO1>,<MAGPIO2>,<The number of frequency ranges>,<state_0>,<flo_0>,<fhi_0><state_1>,<flo_1>,<fhi_1>,...
#define AT_MAGPIO_DIS  "AT\%XMAGPIO"
#define GPS_EN true
#define GPS_DIS false
static int            fd;
static char           nmea_strings[10][NRF_GNSS_NMEA_MAX_LEN];
static u32_t          nmea_string_cnt;
static bool           got_first_fix;
static bool           update_terminal;
static u64_t          fix_timestamp;
nrf_gnss_data_frame_t last_fix;
/* Buffers for MQTT client. */
static u8_t rx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t tx_buffer[CONFIG_MQTT_MESSAGE_BUFFER_SIZE];
static u8_t payload_buf[CONFIG_MQTT_PAYLOAD_BUFFER_SIZE];
/* The mqtt client struct */
static struct mqtt_client client;
/* MQTT Broker details. */
static struct sockaddr_storage broker;
/* Connected flag */
static bool connected;
/* File descriptor */
static struct pollfd fds;
#if defined(CONFIG_BSD_LIBRARY)
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
	printk("bsdlib recoverable error: %u\n", err);
/**@brief Irrecoverable BSD library error. */
void bsd_irrecoverable_error_handler(uint32_t err)
	printk("bsdlib irrecoverable error: %u\n", err);
	__ASSERT_NO_MSG(false);
#endif /* defined(CONFIG_BSD_LIBRARY) */
/* GPS setting*/
static int configure_gps_off_on(bool status)
	int  at_sock;
	int  bytes_sent;
	int  bytes_received;
	char buf[2];
        char *at_commands[3];
        if(status == GPS_EN){
                at_commands[0] = AT_XSYSTEMMODE_EN_M1_GPS;
                at_commands[1] = AT_MAGPIO_EN_GPS;
        } else {
                at_commands[0] = AT_XSYSTEMMODE_EN_M1;
                at_commands[1] = AT_MAGPIO_DIS;
        at_commands[2] = AT_CFUN_EN_MODEM;
        printf("at_commands[0] = %s\n", at_commands[0]);
        printf("at_commands[1] = %s\n", at_commands[1]);
        printf("at_commands[2] = %s\n", at_commands[2]);
	at_sock = socket(AF_LTE, 0, NPROTO_AT); // retunr 4
        printk("at_sock = %u\n", at_sock);
	if (at_sock < 0) {
                printk("Error1\n");
		return -1;
	for (int i = 0; i < ARRAY_SIZE(at_commands); i++) {
		bytes_sent = send(at_sock, at_commands[i], strlen(at_commands[i]), 0);
                printk("at_commands[i] = %s\n", at_commands[i]);
                printk("strlen(at_commands[i]) = %u\n", strlen(at_commands[i]));
		if (bytes_sent < 0) {
			close(at_sock);
                        printk("Error2\n");
			return -1;
		do {
			bytes_received = recv(at_sock, buf, 2, 0); // this is not successful
		} while (bytes_received == 0);
                printk("buf = %s\n", buf); // "ER"
		if (memcmp(buf, "OK", 2) != 0) {
			close(at_sock);
                        printk("Error3\n"); // reach here
			return -1;
	close(at_sock);
	return 0;
static int init_gps(void)
	u16_t fix_retry     = 0;
	u16_t fix_interval  = 1;
	u16_t nmea_mask     = NRF_CONFIG_NMEA_GSV_MASK |
			      NRF_CONFIG_NMEA_GSA_MASK |
			      NRF_CONFIG_NMEA_GLL_MASK |
			      NRF_CONFIG_NMEA_GGA_MASK |
			      NRF_CONFIG_NMEA_RMC_MASK;
	int   retval;
	if (configure_gps_off_on(GPS_EN) != 0) {
		printk("Failed to enable GPS\n");
		return -1;
	fd = nrf_socket(NRF_AF_LOCAL, NRF_SOCK_DGRAM, NRF_PROTO_GNSS);
	if (fd >= 0) {
		printk("Socket created\n");
	} else {
		printk("Could not init socket (err: %d)\n", fd);
		return -1;
	retval = nrf_setsockopt(fd,
				NRF_SOL_GNSS,
				NRF_SO_GNSS_FIX_RETRY,
				&fix_retry,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set fix retry value\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_FIX_INTERVAL,
				&fix_interval,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set fix interval value\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_NMEA_MASK,
				&nmea_mask,
				sizeof(uint16_t));
	if (retval != 0) {
		printk("Failed to set nmea mask\n");
		return -1;
				NRF_SOL_GNSS,
				NRF_SO_GNSS_START,
				NULL,
				0);
	if (retval != 0) {
		printk("Failed to start GPS\n");
		return -1;
	return 0;
int process_gps_data(nrf_gnss_data_frame_t *gps_data)
	int retval;
	retval = nrf_recv(fd, gps_data, sizeof(nrf_gnss_data_frame_t), NRF_MSG_DONTWAIT);
	if (retval > 0) {
		switch (gps_data->data_id) {
		case NRF_GNSS_PVT_DATA_ID:
			if ((gps_data->pvt.flags &
				NRF_GNSS_PVT_FLAG_FIX_VALID_BIT)
				== NRF_GNSS_PVT_FLAG_FIX_VALID_BIT) {
				if (!got_first_fix) {
					got_first_fix = true;
				fix_timestamp = k_uptime_get();
				memcpy(&last_fix, gps_data, sizeof(nrf_gnss_data_frame_t));
				nmea_string_cnt = 0;
				update_terminal = true;
		case NRF_GNSS_NMEA_DATA_ID:
			if (nmea_string_cnt < 10) {
				memcpy(nmea_strings[nmea_string_cnt++],
				       gps_data->nmea,
				       retval);
	return retval;
static void print_pvt_data(nrf_gnss_data_frame_t *pvt_data)
	printf("Longitude:  %f\n", pvt_data->pvt.longitude);
	printf("Latitude:   %f\n", pvt_data->pvt.latitude);
	printf("Altitude:   %f\n", pvt_data->pvt.altitude);
	printf("Speed:      %f\n", pvt_data->pvt.speed);
	printf("Heading:    %f\n", pvt_data->pvt.heading);
	printk("Date:       %02u-%02u-%02u\n", pvt_data->pvt.datetime.day,
					       pvt_data->pvt.datetime.month,
					       pvt_data->pvt.datetime.year);
	printk("Time (UTC): %02u:%02u:%02u\n", pvt_data->pvt.datetime.hour,
					       pvt_data->pvt.datetime.minute,
					      pvt_data->pvt.datetime.seconds);
/**@brief Function to print strings without null-termination
static void data_print(u8_t *prefix, u8_t *data, size_t len)
	char buf[len + 1];
	memcpy(buf, data, len);
	buf[len] = 0;
	printk("%s%s\n", prefix, buf);
/**@brief Function to publish data on the configured topic
static int data_publish(struct mqtt_client *c, enum mqtt_qos qos,
	struct mqtt_publish_param param;
	param.message.topic.qos = qos;
	param.message.topic.topic.utf8 = CONFIG_MQTT_PUB_TOPIC;
	param.message.topic.topic.size = strlen(CONFIG_MQTT_PUB_TOPIC);
	param.message.payload.data = data;
	param.message.payload.len = len;
	param.message_id = sys_rand32_get();
	param.dup_flag = 0;
	param.retain_flag = 0;
	data_print("Publishing: ", data, len);
	printk("to topic: %s len: %u\n",
		CONFIG_MQTT_PUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_PUB_TOPIC));
	return mqtt_publish(c, &param);
/**@brief Function to subscribe to the configured topic
static int subscribe(void)
	struct mqtt_topic subscribe_topic = {
		.topic = {
			.utf8 = CONFIG_MQTT_SUB_TOPIC,
			.size = strlen(CONFIG_MQTT_SUB_TOPIC)
		.qos = MQTT_QOS_1_AT_LEAST_ONCE
	const struct mqtt_subscription_list subscription_list = {
		.list = &subscribe_topic,
		.list_count = 1,
		.message_id = 1234
	printk("Subscribing to: %s len %u\n", CONFIG_MQTT_SUB_TOPIC,
		(unsigned int)strlen(CONFIG_MQTT_SUB_TOPIC));
	return mqtt_subscribe(&client, &subscription_list);
/**@brief Function to read the published payload.
static int publish_get_payload(struct mqtt_client *c, size_t length)
	u8_t *buf = payload_buf;
	u8_t *end = buf + length;
	if (length > sizeof(payload_buf)) {
		return -EMSGSIZE;
	while (buf < end) {
		int ret = mqtt_read_publish_payload(c, buf, end - buf);
		if (ret < 0) {
			int err;
			if (ret != -EAGAIN) {
				return ret;
			printk("mqtt_read_publish_payload: EAGAIN\n");
			err = poll(&fds, 1, K_SECONDS(CONFIG_MQTT_KEEPALIVE));
			if (err > 0 && (fds.revents & POLLIN) == POLLIN) {
				continue;
			} else {
				return -EIO;
		if (ret == 0) {
			return -EIO;
		buf += ret;
	return 0;
/**@brief MQTT client event handler
void mqtt_evt_handler(struct mqtt_client *const c,
		      const struct mqtt_evt *evt)
	int err;
	switch (evt->type) {
	case MQTT_EVT_CONNACK:
		if (evt->result != 0) {
			printk("MQTT connect failed %d\n", evt->result);
		connected = true;
		printk("[%s:%d] MQTT client connected!\n", __func__, __LINE__);
		subscribe();
	case MQTT_EVT_DISCONNECT:
		printk("[%s:%d] MQTT client disconnected %d\n", __func__,
		       __LINE__, evt->result);
		connected = false;
	case MQTT_EVT_PUBLISH: {
		const struct mqtt_publish_param *p = &evt->param.publish;
		printk("[%s:%d] MQTT PUBLISH result=%d len=%d\n", __func__,
		       __LINE__, evt->result, p->message.payload.len);
		err = publish_get_payload(c, p->message.payload.len);
		if (err >= 0) {
			data_print("Received: ", payload_buf,
			/* Echo back received data */
			data_publish(&client, MQTT_QOS_1_AT_LEAST_ONCE,
				payload_buf, p->message.payload.len);
		} else {
			printk("mqtt_read_publish_payload: Failed! %d\n", err);
			printk("Disconnecting MQTT client...\n");
			err = mqtt_disconnect(c);
			if (err) {
				printk("Could not disconnect: %d\n", err);
	} break;
	case MQTT_EVT_PUBACK:
			printk("MQTT PUBACK error %d\n", evt->result);
		printk("[%s:%d] PUBACK packet id: %u\n", __func__, __LINE__,
				evt->param.puback.message_id);
	case MQTT_EVT_SUBACK:
			printk("MQTT SUBACK error %d\n", evt->result);
		printk("[%s:%d] SUBACK packet id: %u\n", __func__, __LINE__,
				evt->param.suback.message_id);
		printk("[%s:%d] default: %d\n", __func__, __LINE__,
				evt->type);
/**@brief Resolves the configured hostname and
 * initializes the MQTT broker structure
static void broker_init(void)
	int err;
	struct addrinfo *result;
	struct addrinfo *addr;
	struct addrinfo hints = {
		.ai_family = AF_INET,
		.ai_socktype = SOCK_STREAM
	err = getaddrinfo(CONFIG_MQTT_BROKER_HOSTNAME, NULL, &hints, &result);
	if (err) {
		printk("ERROR: getaddrinfo failed %d\n", err);
		return;
	addr = result;
	err = -ENOENT;
	/* Look for address of the broker. */
	while (addr != NULL) {
		/* IPv4 Address. */
		if (addr->ai_addrlen == sizeof(struct sockaddr_in)) {
			struct sockaddr_in *broker4 =
				((struct sockaddr_in *)&broker);
			char ipv4_addr[NET_IPV4_ADDR_LEN];
			broker4->sin_addr.s_addr =
				((struct sockaddr_in *)addr->ai_addr)
				->sin_addr.s_addr;
			broker4->sin_family = AF_INET;
			broker4->sin_port = htons(CONFIG_MQTT_BROKER_PORT);
			inet_ntop(AF_INET, &broker4->sin_addr.s_addr,
				  ipv4_addr, sizeof(ipv4_addr));
			printk("IPv4 Address found %s\n", ipv4_addr);
		} else {
			printk("ai_addrlen = %u should be %u or %u\n",
				(unsigned int)addr->ai_addrlen,
				(unsigned int)sizeof(struct sockaddr_in),
				(unsigned int)sizeof(struct sockaddr_in6));
		addr = addr->ai_next;
	/* Free the address. */
	freeaddrinfo(result);
/**@brief Initialize the MQTT client structure
static void client_init(struct mqtt_client *client)
	mqtt_client_init(client);
	broker_init();
        static struct mqtt_utf8 password;
	static struct mqtt_utf8 user_name;
	password.utf8 = (u8_t*)MQTT_PASSWORD;
	password.size = strlen(MQTT_PASSWORD);
	user_name.utf8 = (u8_t*)MQTT_USERNAME;
	user_name.size = strlen(MQTT_USERNAME);
	/* MQTT client configuration */
	client->broker = &broker;
	client->evt_cb = mqtt_evt_handler;
	client->client_id.utf8 = (u8_t *)CONFIG_MQTT_CLIENT_ID;
	client->client_id.size = strlen(CONFIG_MQTT_CLIENT_ID);
	client->password = &password;
	client->user_name = &user_name;
	client->protocol_version = MQTT_VERSION_3_1_1;
	/* MQTT buffers configuration */
	client->rx_buf = rx_buffer;
	client->rx_buf_size = sizeof(rx_buffer);
	client->tx_buf = tx_buffer;
	client->tx_buf_size = sizeof(tx_buffer);
	/* MQTT transport configuration */
	client->transport.type = MQTT_TRANSPORT_NON_SECURE;
/**@brief Initialize the file descriptor structure used by poll.
static int fds_init(struct mqtt_client *c)
	if (c->transport.type == MQTT_TRANSPORT_NON_SECURE) {
		fds.fd = c->transport.tcp.sock;
	} else {
#if defined(CONFIG_MQTT_LIB_TLS)
		fds.fd = c->transport.tls.sock;
#else
		return -ENOTSUP;
	fds.events = POLLIN;
	return 0;
/**@brief Configures modem to provide LTE link. Blocks until link is
 * successfully established.
static void modem_configure(void)
#if defined(CONFIG_LTE_LINK_CONTROL)
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already turned on
		 * and connected.
	} else {
		int err;
		printk("LTE Link Connecting ...\n");
		err = lte_lc_init_and_connect();
		__ASSERT(err == 0, "LTE link could not be established.");
		printk("LTE Link Connected!\n");
int8_t poll_and_check_rcv_data(u32_t interval_msec){
        int err = poll(&fds, 1, interval_msec); // Check if any data comes through LTE-M. When it is waiting for an incoming data, it sleeps
        int8_t ret = 0;
        if (err < 0) {
              printk("ERROR: poll %d\n", errno);
              return -1;
        /* Check if data is received through LTE-M */
        /* Caution!! These are mandatory */
        if ((fds.revents & POLLIN) == POLLIN) {
                err = mqtt_input(&client); // if a publish event comes, mqtt_evt_handler is called here
                if (err != 0) {
                        printk("ERROR: mqtt_input %d\n", err);
                        return -1;
        if ((fds.revents & POLLERR) == POLLERR) {
                printk("POLLERR\n");
                return -1;
        if ((fds.revents & POLLNVAL) == POLLNVAL) {
                printk("POLLNVAL\n");
                return -1;
        return ret;
void main(void)
	int err;
	printk("The MQTT simple sample started\n");
	modem_configure();
	client_init(&client);
	err = mqtt_connect(&client);
	if (err != 0) {
		printk("ERROR: mqtt_connect %d\n", err);
		return;
	err = fds_init(&client);
	if (err != 0) {
		printk("ERROR: fds_init %d\n", err);
		return;
        poll_and_check_rcv_data(K_SECONDS(5));
        /* GPS variables */
        nrf_gnss_data_frame_t gps_data;
	while (1) {
                printk("Staring GPS application\n");
                if (init_gps() != 0) {
                        printk("init_app fail\n");
                printk("Getting GPS data...\n");
		do {
			/* Loop until we don't have more
			 * data to read
		} while (process_gps_data(&gps_data) > 0);
                printk("---------------------------------\n");
                print_pvt_data(&last_fix);
                /* If gps data is broken, get it again */
                configure_gps_off_on(GPS_DIS);
                k_sleep(K_SECONDS(20));
<result>
***** Booting Zephyr OS v1.14.99-ncs2-rc3 *****
LTE Link Connected!
IPv4 Address found xxx.xx.xx.xxx
[mqtt_evt_handler:389] MQTT client connected!
Subscribing to: my/subscribe/topic len 18
at_commands[0] = AT%XSYSTEMMODE=1,0,1,0
at_commands[1] = AT%XMAGPIO=1,0,0,1,1,1574,1577
at_commands[2] = AT+CFUN=1
at_sock = 4
at_commands[i] = AT%XSYSTEMMODE=1,0,1,0
strlen(at_commands[i]) = 22
buf = ER
Error3
init_app fail
Getting GPS data...
Longitude:  0.000000
Latitude:   0.000000
Altitude:   0.000000
Speed:      0.000000
Heading:    0.000000
Date:       00-00-00
Time (UTC): 00:00:00
at_commands[0] = AT%XSYSTEMMODE=1,0,0,0
at_sock = 4
at_commands[i] = AT%XSYSTEMMODE=1,0,0,0
buf = ER
Error3
