Arguments to NRF_LOG_DEBUG() sometimes missing in RTT output, SDK 15.3.0.
I recently migrated from SDK 14.2.0 to SDK 15.3.0 and just noticed that some but not all of my logging is broken. A logging macro call such as this:
NRF_LOG_DEBUG("Output power: %s dBm", (int)m_modem.response);
will log only:
D modem Output power:  dBm
when I expect to see:
D modem Output power: 14 dBm
Is this a known issue? Is there a workaround?
  • Hmm I believe you should use '%d' for decimal integers. Right now it's expecting a string, but you've provided an int.
    Are you sure m_modem.response has a value when you call the NRF_LOG_DEBUG function?
  • That value is in fact a string. In previous SDK releases, the cast to (int) was required to prevent a compile warning or error. Is that no longer the case? It seems not. So I now need to go through all my logging and remove them, and it'll work again?
  • I'm reading the definitions for NRF_LOG_DEBUG, it's a bit of a mess, but it seems it takes in uint32_t as arguments, not int nor strings.
    NRF_LOG_DEBUG will expand into a function that calls
    std_n() on line 536 of nrf_log_frontend.c.
    There's a comment that hints to our issue: // Proceed only if buffer was successfully preallocated.
    Have you set NRF_LOG_ALLOW_OVERFLOW to 1 in sdk_config? I believe the log module will overflow its circular buffer and overwrite the first entries, but this will only happen if NRF_LOG_ALLOW_OVERFLOW is set to 1. Otherwise the log module will skip the last log entry entirely.
    From line 78 in nrf_log_frontend.c:
    * brief An internal control block of the logger
    * @note Circular buffer is using never cleared indexes and a mask. It means
    * that logger may break when indexes overflows. However, it is quite unlikely.
    * With rate of 1000 log entries with 2 parameters per second such situation
    * would happen after 12 days.
    How often do you invoke NRF_LOG_DEBUG?
    I suggest you try increasing the buffer size of the log module and turning deferred logging on/off.
  • Yes, NRF_LOG_ALLOW_OVERFLOW was already set to 1. I'm not doing a ton of logging - perhaps 100 NRF_LOG_*() invocations per second at most? And averaging more like 10 per second.
    I had NRF_LOG_DEFERRED set to 0, but changing it to 1 hasn't fixed the issue. Neither has increasing both of these:
    #define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 256
    #define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 64
  • Any update here? Should I create a private case and add the whole codebase?
