nRF 9160 DK - Asset Tracker (and NTP) not working (nrf_cloud_connect_failed: 22)
Hello!
I'm trying to make the asset_tracker sample working on the nRF9160 DK. The at_client worked just fine and I was able to connect to the base station (I'm using NBiOT). Now I'm planning to send/receive some data through UDP and first I wanted to try to connect to the nRF Cloud and then try some other sample programs, such as NTP. Here's the problem:
I changed the network mode in SES to NBIoT and it works as I checked it with %XSYSTEMMODE (it returns 0,1,0,0). But as soon as the system boots I'm getting an error:
***** Booting Zephyr OS v1.14.99-ncs1 *****
Application started
LTE LC config ...
nrf_cloud_connect failed: 22
and then it just reboots. With network set as default (LTE-M) it won't "fail" but won't connect either obviously. Now i've looked for a solution online but none of it worked (even custom .hex files targeted specifically at this problem). I've tried the AT%XEPCO=0 and AT%XBANDLOCK=1, "10010101" (this one doesn't work, returns an error).
Firmware: 1.0.0
Board v0.7.0
SES V4.16 Nordic Edition (64-bit)
I've had similar experience with other example programs trying to connect to the network. They work in LTE-M mode (trying to connect), but after changing it to NBIoT they're just crashing.
NTP for example:
getaddrinfo err: 22
Exception occurred in Secure State
***** HARD FAULT *****
  Fault escalation (see below)
***** BUS FAULT *****
  Precise data bus error
  BFAR Address: 0x50008120
***** Hardware exception *****
Current thread ID = 0x20020134
Faulting instruction address = 0xe380
Fatal fault in ISR! Spinning...
Again, the at_client works fine as some of the other samples (like gps), so i believe the programming procedure isn't the problem. I'm guessing there's an additional configuration procedure needed which i don't know about.
merged.hex
