BLE with SPI doesn´t reconnect once bluetooth has been disabled and enabled again.
I'm currently working with nrf52832 implementing bluetooth and spi functionalities. The bluetooth connection to PC is working fine, it connects and after that starts transfering and receiving data from SPI slave. The problem comes once I decide to turn bluetooth off on the PC. It connects and disconnects constantly. It also happens once I turn off/on the power button on the SDK.
Here it is the main code and the spi configuration:
    bool erase_bonds;
    ret_code_t err_code;
    spi_configuration();
    APP_ERROR_CHECK(nrf_drv_clock_init());
    log_init();
    err_code = app_timer_init();
    motion_timer_init();
    // Initialize.
    power_management_init();
    ble_stack_init();
    scheduler_init();
    gap_params_init();
    gatt_init();
    advertising_init();
    services_init();
    conn_params_init();
    peer_manager_init();
    // Start execution.
    advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
      if(connected){
        NRF_LOG_INFO("Connected.");
        laser_frame();  //transfer and receive spi data
      idle_state_handle();
      nrf_delay_ms(2000);
void spi_configuration(void){
  /* SPI Configuration */
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = SPI_SS_PIN;
    spi_config.miso_pin = SPI_MISO_PIN;
    spi_config.mosi_pin = SPI_MOSI_PIN;
    spi_config.sck_pin  = SPI_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
If spi_configuration() and laser_frame() are commented, the problem when reconnecting disappears. Any idea? Thanks!
  • How to properly post source code:
    EDIT
    OP updated - thanks.
  • Also, when I power off and then on the sdk, I get the following in loop:
    <info> app:     m_whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
    <info> app: Fast advertising.
    <info> app: Connected   (the loop starts from this point)
    <info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Encryption, error: 4102
    <info> app: Connected.
    <info> app: Disconnected
    In the PC side I appreciate that Bluetooth connection is alternating from paired to connected states.
  • That nrf_delay_ms(2000); looked scary.
    Can you try to allow re-pairing by adding the following in pm_evt_handler() in main.c
    case PM_EVT_CONN_SEC_CONFIG_REQ:
    // Allow or reject pairing request from an already bonded peer.
    pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
    pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
    } break;
  • Hey, sorry for the late reply. I have been trying what you propossed and a few more things and this is what I get:
    1. (nrf_delay_ms(2000); deleted) After adding your code I realized that it never goes into that case so it keeps disconnecting and connecting when attempting to reconnect. Still getting error 4102.
    2.  I though it could be because it deletes the bonds in the line 37 so I changed it with advertising_start(false);
    3. Now the sequence I get is:
    <info> app:     m_whitelist_peer_cnt 2, MAX_PEERS_WLIST 8
    <info> app: Fast advertising with whitelist.
    (gets one data buffer from spi slave)
    <error> app: Fatal error
    <warning> app: System reset
    Also I keep getting the following (3 times in a row) while BLE configuration but it connects after all:
    <error> nrf_ble_gatt: sd_ble_gatts_exchange_mtu_reply() returned NRF_ERROR_INVALID_STATE.
    Please follow the debug guide here.
    We need to know what function threw the error code .
    sd_ble_gatts_exchange_mtu_reply() should not be called when not in connection.
    Which example did you base your code on ?
