Updating firmware with dfu bootloader
i would like to program my module nRF52840 via uart.
I generated private then public key using nrfutil.exe tool
i could programm softdevice and bootloader and flash them on my nRF52840.
I use : https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v11.0.0%2Fbledfu_example_serial.html
now i want to update firmware, first i'm testing an existing package : softdevice_s140.zip (nRF5_SDK_15.0.0_a53641a\examples\dfu\secure_dfu_test_images\uart\nrf52840)
so i try to execute this cmd :
D:\Work\nRF5_SDK_15.0.0 ble_telechargement_uart\examples\dfu\secure_dfu_test_images>nrfutil.exe dfu serial --package softdevice_s140.zip --port 4 -fc 1 : here is the result :
  [------------------------------------]    0%
  File "nordicsemi\__main__.py", line 987, in <module>
  File "site-packages\click\core.py", line 722, in __call__
  File "site-packages\click\core.py", line 697, in main
  File "site-packages\click\core.py", line 1066, in invoke
  File "site-packages\click\core.py", line 895, in invoke
  File "site-packages\click\core.py", line 535, in invoke
  File "nordicsemi\__main__.py", line 745, in serial
  File "nordicsemi\__main__.py", line 680, in do_serial
  File "nordicsemi\dfu\dfu.py", line 121, in dfu_send_images
  File "nordicsemi\dfu\dfu.py", line 90, in _dfu_send_image
  File "nordicsemi\dfu\dfu_transport_serial.py", line 200, in open
pc_ble_driver_py.exceptions.NordicSemiException: Serial port could not be opened on {0}. Reason: could not open port '4': WindowsError(2, 'Le fichier sp\xe9cifi\xe9 est introuvable.')
Failed to execute script __main__
on windows device manager , i have  : Jlink CDC UART Port (COM4) and USB Serial Port (COM5), i also tryed with com 5.
what is th correct arg pls ?
  • D:\Work\nRF5_SDK_15.0.0 ble_telechargement_uart\examples\dfu\secure_dfu_test_images>nrfutil.exe dfu serial --package softdevice_s140.zip --port COM4 -fc 1
      File "nordicsemi\dfu\dfu_transport_serial.py", line 211, in open
    pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
  • D:\Work\nRF5_SDK_15.0.0 ble_telechargement_uart\examples\dfu\secure_dfu_test_images>nrfutil.exe dfu serial --package softdevice_s140.zip --port COM5 -fc 1
      File "nordicsemi\dfu\dfu.py", line 97, in _dfu_send_image
      File "nordicsemi\dfu\dfu_transport_serial.py", line 253, in send_init_packet
      File "nordicsemi\dfu\dfu_transport_serial.py", line 370, in __execute
      File "nordicsemi\dfu\dfu_transport_serial.py", line 454, in __get_response
    pc_ble_driver_py.exceptions.NordicSemiException: Response Code InvalidObject
    in this try, i don't see problem with COM port... but i don't understand this new problem ...
    The right documentation page for SDK 15.0.0 will be this one: https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.0.0%2Fsdk_app_serial_dfu_bootloader.html&cp=5_5_1_4_3_4
    If you are testing using one of the provided packages you need to use the default public key included in the bootloader project, do not use your own generated public key. Because these test packages have been generated using a private key that corresponds to the default public key included the project.
    Also make sure the device has enter DFU mode (indicated by LED 3 being lit) before starting the DFU process.
    Marjeris
  • Oh ok thank you very much Marjeris for all those informations !
    I'm goiing to restart all process before asking for more details !
  • ok thanks to you i could program with examples provided !
    it's a beginning, i try now to program my own program
