Getting started
The demo board would not connect (no second LED)
Since in Italy we only have NB-IoT, I guess I should recompile a more recent version of the demo application.
I have followed all steps in Getting Started Assistant but:
Even after registering Segger Embedded Studio, the Nordic version says I am not registered. The standard version of  Embedded Studio runs just fine with the same credentials.
When I try  "Open nrfConnect SDK Project" with:
  • C:/Projects/ncs/nrf/applications/asset_tracker/CMakeLists.txt
  • C:/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090
  • nrf9160_pca10090
  • C:/Projects/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090
I get an error that asset_tracker.emProject is invalid. When i exit the window, an error marker is on the message(FATAL_ERROR... line:
execute_process(
  COMMAND
  ${PYTHON_EXECUTABLE}
  ${ZEPHYR_BASE}/scripts/kconfig/kconfig.py
  ${KCONFIG_ROOT}
  ${DOTCONFIG}
  ${AUTOCONF_H}
  ${PARSED_KCONFIG_SOURCES_TXT}
  ${merge_fragments}
  WORKING_DIRECTORY ${APPLICATION_SOURCE_DIR}
  # The working directory is set to the app dir such that the user
  # can use relative paths in ${IMAGE}CONF_FILE, e.g. CONF_FILE=nrf5.conf
  RESULT_VARIABLE ret
if(NOT "${ret}" STREQUAL "0")
  message(FATAL_ERROR "command failed with return code: ${ret}")
endif()
  • I have programmed mfw_nrf9160_1.0.0.zip and then run Asset Tracker.
    I have to press the RESET button on the board, then I get some output from the board, ending:
    ***** Booting Zephyr OS v1.14.99-ncs2 *****
    Application started
    LTE LC config ...
    I get an OK answer to AT, so it seems alive; yet some other command do not work; e.g
    AT+CLAC
    ERROR
    I also tried a command copied from the Asset Tracker:
    AT%XSYSTEMMODE=0,1,0,0
    ERROR
    Because in Italy we only have NB-IoT
    Concerning the failure I get when programming the Segger utility (which is a little more verbose than the SES) blocks when trying to erase the first sector. As I said, using nRF Connect to reprogram mfw_nrf9160_1.0.0.zip unblocks the device; cycling power both on PC and device does not.
     What does it return if you issue the command:
    AT%XSYSTEMMODE?
    cmag said:
    AT+CLAC
    I can confirm that this does not work. It is a known bug.
    Were you able to issue the AT+CFUN? command?
  • AT%XSYSTEMMODE?
    %XSYSTEMMODE: 0,1,0,0
    After startup, sometimes, after the usual blue dump ending with:
    :***** Booting Zephyr OS v1.14.99-ncs2 *****
    Application started
    LTE LC config ...
    I Get:
    AT+CESQ
    LTE LC config ...
    +CESQ: 99,99,255,255,255,255
    OK
    AT+CESQ
    OK
    AT+CESQ
    +CESQ: 99,99,255,255,255,69
    OK
    AT+CESQ
    OK
    nrf_cloud_connect failed: 22
    AT+CESQ
    And then:
    Flash region Domain Permissions
    And it starts all over again
    There also is some sign of life (see attached image) with  the iBasis SIM.
    Since we only have NB-IoT and not LTE, I do not know what should happen next.
  • Is this all you get in the LTE Link Monitor output? You seem to be missing SPM. Have you flashed the correct .hex file: merged.hex. What version of SES are you using? Please ensure that you are using SES v4.18 and that Project zephyr/merged.hex is set to Active Project.
  • 2019-07-12T10_58_22.484Z-log.txt
    This is the full dump. After the initial blue part (boot?) I typed:
    AT
    OK
    AT
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    Then it started to do everything by itself and UART/MODEM/UICC/PDN became green; LTE was yellow (Using iBasis).
    I retried with Vodafone SIM and LTE stays gray. Signal is also weaker (2 marks instead of 3) so maybe iBasis is based on a different network.
    In this case the answer is:
    AT+CESQ
    Which makes me think that Vodafone lied when they said that any M2M SIM supports NB-IoT.
