Getting started
The demo board would not connect (no second LED)
Since in Italy we only have NB-IoT, I guess I should recompile a more recent version of the demo application.
I have followed all steps in Getting Started Assistant but:
Even after registering Segger Embedded Studio, the Nordic version says I am not registered. The standard version of  Embedded Studio runs just fine with the same credentials.
When I try  "Open nrfConnect SDK Project" with:
  • C:/Projects/ncs/nrf/applications/asset_tracker/CMakeLists.txt
  • C:/Projects/ncs/zephyr/boards/arm/nrf9160_pca10090
  • nrf9160_pca10090
  • C:/Projects/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090
I get an error that asset_tracker.emProject is invalid. When i exit the window, an error marker is on the message(FATAL_ERROR... line:
execute_process(
  COMMAND
  ${PYTHON_EXECUTABLE}
  ${ZEPHYR_BASE}/scripts/kconfig/kconfig.py
  ${KCONFIG_ROOT}
  ${DOTCONFIG}
  ${AUTOCONF_H}
  ${PARSED_KCONFIG_SOURCES_TXT}
  ${merge_fragments}
  WORKING_DIRECTORY ${APPLICATION_SOURCE_DIR}
  # The working directory is set to the app dir such that the user
  # can use relative paths in ${IMAGE}CONF_FILE, e.g. CONF_FILE=nrf5.conf
  RESULT_VARIABLE ret
if(NOT "${ret}" STREQUAL "0")
  message(FATAL_ERROR "command failed with return code: ${ret}")
endif()
