I'm trying to use the PA/LNA control feature in S112. However I only want this to be enabled when under specific conditions/configurations at runtime. So I need a way for enabling and disabling the control of these pins from the SD. Is this possible? Can I disable the GPIOTE/PPI task which is controlled by the SD for pin control? I keep getting errors when I disable the GPIOTE task as it says the pin is under use.
