App iOSDFULibrary update firmware Error
i download App(iOSDFULibrary) from https://github.com/NordicSemiconductor/IOS-Pods-DFU-Library.
And delete all firmware itself have. Put my firmware into folder (Firmwares/Custom) ,
Build and run app on my phone, select and connect my device , The app will be automatically upgrade 。
but It quickly upgrade and Error .
please help .
Error Log :
Central Manager is now powered on
Start discovery
State changed to: Connecting
V: Connecting to P128...
D: centralManager.connect(peripheral, options: nil)
D: [Callback] Central Manager did connect peripheral
I: Connected to P128
V: Discovering services...
D: peripheral.discoverServices(nil)
I: Services discovered
V: Starting Secure DFU...
V: Secure DFU Service found
V: Discovering characteristics in DFU Service...
D: peripheral.discoverCharacteristics(nil, for: FE59)
I: DFU characteristics discovered
State changed to: Starting
V: Enabling indications for 8EC90003-F315-4F60-9FB8-838830DAEA50...
D: peripheral.setNotifyValue(true, for: 8EC90003-F315-4F60-9FB8-838830DAEA50)
V: Indications enabled for 8EC90003-F315-4F60-9FB8-838830DAEA50
A: Buttonless DFU indications enabled
W: Application with buttonless update found
State changed to: Enabling DFU Mode
V: Trying setting bootloader name to Dfu56485
V: Writing to characteristic 8EC90003-F315-4F60-9FB8-838830DAEA50...
D: peripheral.writeValue(0x02084466753536343835, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Data written to 8EC90003-F315-4F60-9FB8-838830DAEA50
I: Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200201
A: Response (Op Code = 2, Status = 1) received
A: Bootloader name changed successfully
D: peripheral.writeValue(0x01, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200101
A: Response (Op Code = 1, Status = 1) received
D: [Callback] Central Manager did disconnect peripheral
I: Disconnected by the remote device
V: Scanning for the DFU Bootloader...
I: DFU Bootloader found with name Dfu56485
V: Connecting to Dfu28413...
I: Connected to Dfu28413
D: peripheral.discoverServices([FE59])
V: Enabling notifications for 8EC90001-F315-4F60-9FB8-838830DAEA50...
D: peripheral.setNotifyValue(true, for: 8EC90001-F315-4F60-9FB8-838830DAEA50)
V: Notifications enabled for 8EC90001-F315-4F60-9FB8-838830DAEA50
A: Secure DFU Control Point notifications enabled
V: Writing to characteristic 8EC90001-F315-4F60-9FB8-838830DAEA50...
D: peripheral.writeValue(0x0601, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Data written to 8EC90001-F315-4F60-9FB8-838830DAEA50
I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601000100000000000000000000
A: Command object info (Max size = 256, Offset = 0, CRC = 00000000) received
D: peripheral.writeValue(0x010188000000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600101
D: peripheral.writeValue(0x020000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600201
A: Packet Receipt Notif disabled (Op Code = 2, Value = 0)
V: Writing to characteristic 8EC90002-F315-4F60-9FB8-838830DAEA50...
D: peripheral.writeValue(0x1285010a3f0801123b08d30110341a029d012000, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
D: peripheral.writeValue(0x2800300038ec950a4224080312205a3c0ef6e356, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
D: peripheral.writeValue(0xe2939cb2af23a0fec5d78a331214f043e55de13e, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
D: peripheral.writeValue(0xdc26b8099d57480010001a40caaeece4e3962e33, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
D: peripheral.writeValue(0xccca9e2059a1a562a00fa13842ce7e8026090812, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
D: peripheral.writeValue(0xf5c0da38490f123b45aa21acf6197d6b43b0edbd, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
D: peripheral.writeValue(0x09c151d719ec8a3e264517317d7f3b0f, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
A: Command object sent (CRC = D912F08E)
D: peripheral.writeValue(0x03, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301880000008ef012d9
A: Checksum (Offset = 136, CRC = D912F08E) received
D: peripheral.writeValue(0x04, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600401
A: Command object executed
D: peripheral.writeValue(0x020c00, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
A: Packet Receipt Notif enabled (Op Code = 2, Value = 12)
D: peripheral.writeValue(0x0602, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601001000000000000000000000
A: Data object info (Max size = 4096, Offset = 0, CRC = 00000000) received
State changed to: Uploading
D: peripheral.writeValue(0x010200100000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
I: Data object 1/41 created
A: Uploading firmware...
V: Sending firmware to DFU Packet characteristic...
Error 202: Device disconnected unexpectedly
    I have you tried to upload the same DFU package with our nRF connect / nRF toolbox to be sure it's not a problem with your custom app? Although it looks like the link is being terminated by the bootloader.
  • i use you ' nRF connect ' update my custom firmware  is successful. But  use https://github.com/NordicSemiconductor/IOS-Pods-DFU-Library Source code is error .
    error log :
    Start discovery
    V: Connecting to KB96(ID-C708)...
    I: Connected to KB96(ID-C708)
    V: Trying setting bootloader name to Dfu91108
    D: peripheral.writeValue(0x02084466753931313038, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
    I: DFU Bootloader found with name Dfu91108
    V: Connecting to Dfu77093...
    I: Connected to Dfu77093
    D: peripheral.writeValue(0x1285010a3f0801123b08d60110341a029d012000, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x2800300038c48e074224080312206b897bf6a6de, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x23b05cd592226bfec931149ed8e664411d2d000c, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x20b9c3117ef5480010001a40f1702835966cd734, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x45f1df3bc2801b0e25d2ca561e3084421169bf1a, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x6dc151f338c2f047e8123598bd1b33508d291d1f, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x8bfaa0fa251f27d6a56e2f82d438ee1a, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    A: Command object sent (CRC = 926BE5A9)
    I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030188000000a9e56b92
    A: Checksum (Offset = 136, CRC = 926BE5A9) received
    I: Data object 1/29 created
    Start discovery
  • i try another device and firmware to update use  https://github.com/NordicSemiconductor/IOS-Pods-DFU-Library  source code, and successful, Is there any difference between my two devices? I'm confused  .
    success some log:
    Start discovery
    V: Connecting to KH96(ID-C708)...
    I: Connected to KH96(ID-C708)
    V: Trying setting bootloader name to Dfu36508
    D: peripheral.writeValue(0x02084466753336353038, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
    I: DFU Bootloader found with name Dfu36508
    V: Connecting to DfuTarg...
    I: Connected to DfuTarg
    D: peripheral.writeValue(0x1285010a3f0801123b08b00110341a029d012000, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x280030003894f1064224080312209592e9a08a4e, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x067104dc8a11402fe4533d5bd0d36349e5e44fbb, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x346f93f68888480010001a40d0e1b149d6bc3dcf, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x17dc1b268adff5cc5fee5f0b36b80509031bc0fe, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x7ea433387a315f7be78101250e5f7dd29ae4a9a5, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    D: peripheral.writeValue(0x050b623bfb7dac7ebae1d0fc6fe71f26, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
    A: Command object sent (CRC = 63D6BEDC)
    I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030188000000dcbed663
    A: Checksum (Offset = 136, CRC = 63D6BEDC) received
    I: Data object 1/28 created
    I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010010000032986792
    A: Checksum (Offset = 4096, CRC = 92679832) received
    A: Data object executed
    I: Data object 2/28 created
    I: Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010020000014cc1bc4
    A: Checksum (Offset = 8192, CRC = C41BCC14) received
    I: Data object 3/28 created
     Is everything supposed to be identical, or are you using a different mobile app, DFU firmware image, mobile, nRF device?
  •  mobile app(use your source code),  mobile, nRF device  is same .  DFU firmware image is different , bootloader and softdevice is same.
