using command line tools on Windows
I just started working with a couple of other people on firmware for a BT dongle.
The existing codebase/software build is based on Linux environment using command line tools.
I have a Windows machine and I started working on SES IDE, which seemed to be recommended/popular for Windows.
But now I'm having trouble in integrating the code with other members using Linux and Command Line.
Being new to the firmware world, I cannot find a good tutorial for using command line tools on Windows(after installing nRF jprog). Is there one available?
Is there a way to integrate SES based code with Linux command line based environment?
Please advice,
Thanks
  • Hi.
    I'm a bit unsure what you mean by intergrating the code. Are you talking about using command line commands? You can take a look at infocenter, it is described there what different commands that can be used with the command line tool. It should not play any role if you're using Linux/Windows/iOS.
     Take a look at infocenter for this as well.
    Andreas
  • If you have any other questions, please create a new ticket, I'm going on holiday :-)
    Andreas
