Asset Tracker demo with working GPS on PCA10090?
Hi there,
I’m trying to find the path-of-least resistance to get the GPS working in the Asset Tracker demo on a PCA10090 (v0.8.5), and I noticed that one of you engineers has a version working on the PCA20035 (?) board (https://github.com/joakimtoe/fw-nrfconnect-nrf/commit/44f267701578aa3c66035409cadc662fd1b829e7).  Interestingly, it seems like this is the only reference (at least according to Google) that includes CONFIG_GPS_DEV_NAME="NRF9160_GPS".
For a laugh, I took the sources from latest commit on the gps_psm_dk branch of the said fw-nrfconnect-nrf repo and tried to build it against the other components pulled in with official v1.0.0 west release – didn’t go too well.  Transcript is below:
Loading solution asset_tracker.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=/home/<user>/nordic/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/home/<user>/gnuarmemb7-2018q2 -B/home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker/build_nrf9160_pca10090ns -H/home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/home/<user>/segger-em-studio/html/configure_nordic_project_menuconfig.py
-- Using application from '/home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker'
Zephyr version: 1.14.99
-- Selected BOARD nrf9160_pca10090ns
-- Found west: /home/<user>/.local/bin/west (found suitable version "0.5.8", minimum required is "0.5.6")
-- Cache files will be written to: /home/<user>/.cache/zephyr
USING OUT OF TREE BOARD
-- Loading /home/<user>/nordic/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying /home/<user>/nordic/ncs/zephyr/dts/common/common.dts
nrf9160_pca10090ns.dts.pre.tmp:269.19-275.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
Parsing Kconfig tree in /home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker/Kconfig
Loading /home/<user>/nordic/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns_defconfig as base
Merging /home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker/prj.conf
/home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker/prj.conf:39: warning: attempt to assign the value 'y' to the undefined symbol CLOUD_API
/home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker/prj.conf:51: warning: attempt to assign the value 'y' to the undefined symbol NRF9160_GPS
/home/<user>/nordic/ncs/fw-nrfconnect-nrf/applications/asset_tracker/prj.conf:52: warning: attempt to assign the value 'y' to the undefined symbol NRF9160_GPS_LOG_LEVEL_DBG
warning: FLASH_MAP (defined at subsys/storage/flash_map/Kconfig:12) has direct dependencies FLASH_HAS_DRIVER_ENABLED with value n, but is currently being y-selected by the following symbols:
 - MCUBOOT_IMG_MANAGER (defined at subsys/dfu/Kconfig:25), with value y, direct dependencies <choice> (value: y), and select condition <choice> (value: y)
Error: Aborting due to non-whitelisted Kconfig warning '/home/<user>/nordic/ncs/fw-nrfconnect-
undefined symbol CLOUD_API'. Note: If this warning doesn't point to an actual problem, you can add
it to the whitelist at the top of /home/<user>/nordic/ncs/zephyr/scripts/kconfig/kconfig.py.
CMake Error at /home/<user>/nordic/ncs/zephyr/cmake/kconfig.cmake:200 (message):
  command failed with return code: 1
  /home/<user>/nordic/ncs/zephyr/cmake/app/boilerplate.cmake:529 (include)
  CMakeLists.txt:11 (include)
Was hoping someone could provide some guidance to assist getting this working on a PCA10090 board please.  FYI, I have run ’s GPS demo (https://github.com/Rallare/fw-nrfconnect-nrf/tree/master/samples/nrf9160/gps) and it worked  as expected.
Sincere thanks in advance for your assistance.
Z
