How to create a custom board file for the nRF9160
I am trying to create a custom board file in the ncs/zepher/boards directory for our nRF9160.
If I copy the nrf9160_pca10090 directory to a new nam eg. nrf9160_newboard it will compile and run just fine.
Then when i change the name of the files to nrf9160_newboard and change the references in each of the files to correspond to the new file names.
I was able to get the hello world example to compile and run as a nrf9160_newboard, but when I tried to compile as nrf9160_newboardns I get the following errors in spm.c
1> C:/ncs/nrf/subsys/spm/spm.c:129:2: error: 'NRF_SPU' undeclared (first use in this function); did you mean 'NRF_SPU_S'?
1> C:/ncs/nrf/subsys/spm/spm.c:129:2: note: each undeclared identifier is reported only once for each function it appears in
1> C:/ncs/nrf/subsys/spm/spm.c:160:3: error: 'NRF_SPU' undeclared (first use in this function); did you mean 'NRF_SPU_S'?
1> C:/ncs/nrf/subsys/spm/spm.c:207:3: error: 'NRF_SPU' undeclared (first use in this function); did you mean 'NRF_SPU_S'?
1> C:/ncs/nrf/subsys/spm/spm.c:224:21: error: 'NRF_SPU' undeclared (first use in this function); did you mean 'NRF_SPU_S'?
1> C:/ncs/nrf/subsys/spm/spm.c:262:3: error: 'NRF_SPU' undeclared (first use in this function); did you mean 'NRF_SPU_S'?
1> C:/ncs/nrf/subsys/spm/spm.c:293:24: error: 'NRF_UARTE2' undeclared (first use in this function); did you mean 'NRF_UARTE0'?
1> C:/ncs/nrf/subsys/spm/spm.c:93:23: note: in definition of macro 'NRFX_PERIPHERAL_ID_GET'
1> C:/ncs/nrf/subsys/spm/spm.c:293:3: note: in expansion of macro 'PERIPH'
1> C:/ncs/nrf/subsys/spm/spm.c:301:22: error: 'NRF_PWM1' undeclared (first use in this function); did you mean 'NRF_PWM0'?
1> C:/ncs/nrf/subsys/spm/spm.c:301:3: note: in expansion of macro 'PERIPH'
1> C:/ncs/nrf/subsys/spm/spm.c:302:22: error: 'NRF_PWM2' undeclared (first use in this function); did you mean 'NRF_PWM1'?
1> C:/ncs/nrf/subsys/spm/spm.c:302:3: note: in expansion of macro 'PERIPH'
1> C:/ncs/nrf/subsys/spm/spm.c:303:22: error: 'NRF_PWM3' undeclared (first use in this function); did you mean 'NRF_PWM2'?
1> C:/ncs/nrf/subsys/spm/spm.c:303:3: note: in expansion of macro 'PERIPH'
1> C:/ncs/nrf/subsys/spm/spm.c:321:3: error: 'NRF_SPU' undeclared (first use in this function); did you mean 'NRF_SPU_S'?
1> C:/ncs/nrf/subsys/spm/spm.c:321:10: error: 'const struct periph_cfg' has no member named 'GPIOPORT'
1> C:/ncs/nrf/subsys/spm/spm.c:321:23: error: 'const struct periph_cfg' has no member named 'PERM'
1> C:/ncs/nrf/subsys/spm/spm.c:321:3: warning: statement with no effect [-Wunused-value]
Build failed
i tried this using a grep replace function for 10090 on the new directory since I though I may have missed a line somewhere.
Is there a tutorial or set of directions on how to create new boards other than the one in Zephyr.
(Note: I did this before the introduction of the secure and non-secure versions of the board for section placement)
  • Have you remembered to set the Secure Partition Manager to your custom board too? It seems that the SPM example is still using the regular board. I would try opening the SPM example with that custom board, building & then go back to your example & trying that again.
  • I have run the hello world example as a secure application and that works.  The problem is when I try to run it as a non-secure application.  I am attaching a zip file of the board directory.nrf9160_cti.zip
  • On your advice I tried programming the SPM sample.
    When I first tried Programming SPM with the board set to nrf9160_newboard I did get the PWM and UART errors.
    Then I edited the device tree configuration, using the device tree tool, and changed that status of the peripherals that were giving me the errors.  The SPM sample then compiled.
    When I moved back to my hello world test I needed to edit the device tree for that project.  However the changes made in the device tree did not affect the errors when compiling.
  • I was able to flash and build a hello world nonsecure example with your custom board by executing these steps:
    • Placed the folder nrf9160_pca20190 into <..>/ncs/zephyr/boards/arm with all the files you provided
    • Added the following lines of code into <..>\ncs\zephyr\cmake\app\boilerplate.cmake:
    if(FIRST_BOILERPLATE_EXECUTION)
    else() # NOT FIRST_BOILERPLATE_EXECUTION
        set(BOARD nrf9160_pca20035)
        message("Changed board to secure nrf9160_pca20035 (NOT NS)")
      endif()
        if(${BOARD} STREQUAL nrf9160_pca20190ns)                     //Added this
        set(BOARD nrf9160_pca20190)                                  //Added this
        message("Changed board to secure nrf9160_pca20035 (NOT NS)") //Added this
      endif()                                                        //Added this
      unset(${IMAGE}DTC_OVERLAY_FILE)...
    • Built and flashed the hello world sample by running the commands  "west build -b nrf9160_pca20190ns" and "west flash"
    I might have done some more changes that I have forgotten, but try to execute my steps and see if you are able to make it work.
    Simon
