I have successfully flashed and run the mqtt-simple example from the nrf samples with the default configuration.
If I run it 10 times in a row, the getaddr with "iot.eclipse.org" as input fails on average 4 times. When it works, I successfully connect to MQTT.
I am using nrf tag v1.0.0 with the most up to date firmware.
Is there some required delay between establishing an lte link and attempting to run getaddrinfo?
Has anyone else observed this behavior ?
UPDATE:
For now, I am using the IP address directly so getaddrinfo always succeeds.
However, I see similar behavior on the tls connect now.
I am now more convinced that a successful link establishment does not necessarily mean that data is immediately routable.
