Problem changing pins of gfx ST7735 Example in SDK 15.3
Hi all,
I am running in a strange problem. I am using the gfx example under peripheral with the nRF52840 DK and a display with ST7735 driver. I connected the display to the pins I found in the sdk_config.h:
ST7735_SCK_PIN 47 --> P1.15
ST7735_MOSI_PIN 45 --> P1.13
ST7735_SS_PIN 44 --> P1.12
ST7735_DC_PIN 42 --> P1.10
Everything worked fine with this configuration. Then I tried to change the configuration of all pins and the display did not work any more (showed just a white screen). From what I read about the GPIO pins I thought every configuration should be possible.
I then tried to change only one pin at a time and saw some strange behavior. I set the DC pin to different values:
ST7735_DC_PIN 40 --> P1.08 => worked
ST7735_DC_PIN 9 --> P0.09 => did not work (white screen)
ST7735_DC_PIN 32 --> P1.00 => worked
Then I set the DC Pin back to 42 and changed only the SCK pin:
ST7735_SCK_PIN 40 --> P1.08 => worked
ST7735_SCK_PIN 10 --> P0.10 => did not work (white screen)
So it seems like everything works fine as long as I take only pins of register 1, and problems occur as soon as I take pins of register 0. Do the pins have to be in the same register? Or am I connecting the cables to the wrong pins? Or is it something else what I am not thinking of?
Greetings
Walther
