Zigbee attribute report enabling automatically
Hey everybody!
I'm working with the zigbee cli agent router example.
Can anybody help, how can i get zigbee report automatically? The problem is that i have to enable info in the terminal to get reports. How can i get those whitout the command log enable info in the terminal?
Thank you for your help
    You will need to see inside the example code which Zigbee functions are called in the CLI example and implement these functions yourself in your code. In components/zigbee/cli/zigbee_cli_cmd_zdo.c you can find the functions called for CLI zdo commands, such as "zdo bind on".
    The zcl commands are listed in zigbee_cli_cmd_zcl.c. As you can see, the zcl_subscribe on calls m_sub_subscribe() -> cmd_zb_subscribe(), which is found in components/zigbee/cli/zigbee_cli_cmd_attr_report.c.
    Reports are received by a function cli_agent_ep_handler_report , which gets called from cli_agent_ep_handler which is registered in main function of cli_agent_router example with ZB_AF_SET_ENDPOINT_HANDLER macro.
    See also my answer in this case.
    Marjeris
