Unable to receive publish from server after unprovision and re-provision the same node
I've developed a BLE Mesh Network using the NRF MESH 3.1.0 SDK and the nR5F SDK 15.2.0.
My network has 1 client node and max 63 server nodes: I'm using the generic on-off model to implement a light switch.
I've found this strange behaviour:
If I "un-provision" a server node and then provision the same node with the same address, sometimes the client doesn't receive the server's publish. I think that it's a client issue, because i'm pretty sure that the server is publishing correctly and I'm able to turn on-off the light.
In some cases the client start to receive the server's publish after some minutes, in other cases I need to reboot the client node.
Can someone explain this behaviour? Is it due to the re-assign of the same address to the same node?
