Building NRF9160 sample from command line fails with kconfig error
  • I followed the install instructions from nRF Connect SDK documentation (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/gs_ins_linux.html), to build and install everything on Ubuntu (running in Windows WSL).
  • I'm working with v0.4.0 sources.
  • I'm trying to compile samples from nrf/samples/nrf9160 using the following command: west build -b nrf9160_pca10090ns -d build
  • I get the following error from kconfig:
-- Using application from '/home/fga/BlueWhale/Software/ncs/nrf/samples/nrf9160/mqtt_simple'
Zephyr version: 1.14.99
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.5.2", minimum required is "3.4")
-- Selected BOARD nrf9160_pca10090ns
CMake Error at /home/fga/BlueWhale/Software/ncs/zephyr/cmake/toolchain/zephyr/host-tools.cmake:46 (include):
include could not find load file:
/home/fga/BlueWhale/Software/ncs/zephyr/cmake/toolchain/zephyr/0.10.1/host-tools.cmake
/home/fga/BlueWhale/Software/ncs/zephyr/cmake/host-tools.cmake:3 (include)
/home/fga/BlueWhale/Software/ncs/zephyr/cmake/app/boilerplate.cmake:237 (include)
CMakeLists.txt:10 (include)
-- Found west: /home/fga/.local/bin/west (found suitable version "0.5.8", minimum required is "0.5.6")
-- Cache files will be written to: /home/fga/.cache/zephyr
-- Loading /home/fga/BlueWhale/Software/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base
-- Overlaying /home/fga/BlueWhale/Software/ncs/zephyr/dts/common/common.dts
Parsing Kconfig tree in /home/fga/BlueWhale/Software/ncs/nrf/samples/nrf9160/mqtt_simple/Kconfig
File "/home/fga/BlueWhale/Software/ncs/zephyr/scripts/kconfig/kconfig.py", line 231, in <module>
main()
File "/home/fga/BlueWhale/Software/ncs/zephyr/scripts/kconfig/kconfig.py", line 32, in main
kconf = Kconfig(args.kconfig_root, warn_to_stderr=False)
File "/mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/zephyr/scripts/kconfig/kconfiglib.py", line 976, in __init__
self._parse_block(None, self.top_node, self.top_node)
File "/mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/zephyr/scripts/kconfig/kconfiglib.py", line 2701, in _parse_block
self._parse_block(_T_ENDMENU, node, node)
File "/mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/zephyr/scripts/kconfig/kconfiglib.py", line 2661, in _parse_block
prev = self._parse_block(None, parent, prev)
File "/mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/zephyr/scripts/kconfig/kconfiglib.py", line 2648, in _parse_block
if self.srctree else "unset or blank"))
kconfiglib.KconfigError: ../../../../../../mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/nrf/subsys/Kconfig:8: '../../../../../../mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/nrf/subsys/bootloader/Kconfig' not found (in 'rsource "bootloader/Kconfig"'). Check that environment variables are set correctly (e.g. $srctree, which is set to '/home/fga/BlueWhale/Software/ncs/zephyr'). Also note that unset environment variables expand to the empty string.
CMake Error at /home/fga/BlueWhale/Software/ncs/zephyr/cmake/kconfig.cmake:194 (message):
command failed with return code: 1
/home/fga/BlueWhale/Software/ncs/zephyr/cmake/app/boilerplate.cmake:500 (include)
I'm already developing with zephyr on Ubuntu (installed with WSL on windows) and I never experienced that kind of problem. I checked other forum posts on building with command line, but could not find anything relevant so far for my problem.
Any advice ?
Thanks
    Are you sure you've sourced the correct zephyr-env file? Since you mention that you have other zephyr repos present as well.
    The output complains that it cannot find this file: /mnt/c/Users/m2min/hubic/FGA/Git/Projects/BlueWhale/Software/ncs/nrf/subsys/bootloader/Kconfig
    Does it exist?
    Håkon
  •  On my PC, the Nordic + Zephyr repositories are located on the windows file system and accessed from Ubuntu WSL file system from a symbolic link.
    Unfortunately the build system seems to not fit very well with symbolic links, and seems to mix full paths with symbolic paths.
    Accessing the repositories from the full path (and not via path with symbolic link) solved the issue.
    I did not experienced that problem when developping with zephyr only, but at least I can move forward and build now.
