nRF Connect v3.0.0 Compatibility With Getting Started Assistant v0.9.3 Cmake Problem
I'm using nRF Connect v3.0.0 to run Getting Started Assistant v0.9.3 and get a message it is only compatible with 2.4.0 (very old).  I can install and verify Tool Chain except cmake.  When I try to build Asset Tracker demo I get "Cannot start cmake" error.  I find the cmake directory at C://ncs/zephyr/cmake.  Should it be in the Segger IDE directory instead?
  • Hey, try upgrading Getting Started Assistant to the latest (v1.0.0) and try again. Go to Settings->Check for updates now and then Add/remove apps and upgrade Getting Started Assistant.
  • All is well now after figuring out how to upgrade all the apps in the nRF Connect module.  Thanks.
