Hi All,
I want to implement a network which will consist of 64 sensors at different location sent to a central node . Can use the nrf51822 with ANT mesh protocol to implement that. What is the maximum nodes supported ?
Regards, Dibin
Hi All,
Regards, Dibin
You need to use the nRF51422 if you want to use the ANT protocol. The 51822 and 51422 have the same pin layout and are almost identical except for the different softdevices they support.
Off the top of my head the max number of nodes supported is over 64 so you should be fine.
Hi Michael, Thankyou verymuch for your response, So I am planning to use S310 , and I need to read more informations about ANT , where do I get more details about ANT wireless network , Like topology Number of hops supported etc . Any inputs are really appreciated . Thanks and regards, Dibin
maybe this could be interesting to you github.com/.../nRF51-ble-bcast-mesh
best regards, Nils Minor
No problem, Check out ANTmes-UG (ANT Message Protocol and Usage). You can find this here: www.nordicsemi.com/.../nRF51422
