ble_nfc_pairing_reference_pca10040_s132 fails to Bond
Hi
I am trying to connect and bond a nrf52832 to Galaxy S6, Android 7.0 by OOB / NFC with the
ble_nfc_pairing_reference_pca10040_s132 example.
I selected LE Secure Connections OOB pairing by pressing Press Button 2 after start.
The bonding fails with the following debug log:
<debug> nrf_ble_lesc: Initialized nrf_crypto.
<debug> nrf_ble_lesc: Initialized nrf_ble_lesc.
<debug> nrf_ble_lesc: Generating ECC key pair
<info> app: NFC Connection Handover BLE peripheral device example started.
<info> BUTTONS_M: LESC OOB MODE!
<info> BLE_M: Fast advertising.
<debug> peer_manager_handler: Event PM_EVT_BONDED_PEER_CONNECTED
<debug> peer_manager_handler: Previously bonded peer connected: role: Peripheral, conn_handle: 0, peer_id: 0
<debug> peer_manager_handler: Event PM_EVT_CONN_SEC_PARAMS_REQ
<debug> peer_manager_handler: Security parameter request
<debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
<debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
<debug> peer_manager_handler: Event PM_EVT_LOCAL_DB_CACHE_APPLIED
: conn_handle: 0, peer_id: 0
<debug> peer_manager_handler: Event PM_EVT_CONN_SEC_START
<debug> peer_manager_handler: Connection security procedure started: role: Peripheral, conn_handle: 0, procedure: Bonding
<debug> peer_manager_handler: Event PM_EVT_CONN_SEC_CONFIG_REQ
<debug> peer_manager_handler: Security configuration request
<debug> peer_manager_handler: Event PM_EVT_CONN_SEC_FAILED
<info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x0, procedure: Bonding, error: 4352
<info> BLE_M: Disonnected
The message on the phone is "Couldn't pair.."
I get the same problem with example 'ble_app_hrs_nfc_pairing'
My question:
a) potential reasons?
b) where can I find description for error code 4352?
c) strategies for debugging issues?
Thank you for your support.
BR Chris
  • Update: SD V6.1.1, SDK 15.3
    Connecting and bonding with nRF Connect (but not with NFC) works fine.
    <info> BLE_M: Connected.
    <debug> nrf_ble_lesc: BLE_GAP_EVT_LESC_DHKEY_REQUEST
    <info> nrf_ble_lesc: Calling sd_ble_gap_lesc_dhkey_reply on conn_handle: 0
    <info> BLE_M: BLE_GAP_EVT_CONN_SEC_UPDATE
    <info> BLE_M: Security mode: 2
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_SUCCEEDED
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
    <info> BLE_M: BLE_GAP_EVT_AUTH_STATUS
    <info> BLE_M: Authorization succeeded!
    <debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
    <debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
  • I am sorry for the long delay. I am currently looking into your issue, and will try to provide an answer as soon as possible.
    Simon
  • Dear Simon
    I made some progress by deleting all existing bonds before pairing.
    Now, pairing and bonding is possible.
    However, starting a connection fails: Android MSG: Error 133 (0x85): GATT ERROR
  • Could you try to unbond/unpair the device in Bluetooth setting on the phone. Also try to turn off/on Bluetooth on the phone.
    Simon
  • Here is also a case that may be useful.
    Simon
