ANCS CONNECTIVITY PROBLEM
Hi, I am running  ANCS example application (nRF5_SDK_15.3.0_59ac345/examples/ble_peripheral/ble_app_ancs_c) i changed allow_repairing = false to allow_repairing = true
case PM_EVT_CONN_SEC_CONFIG_REQ:
// Reject pairing request from an already bonded peer.
pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
for repairing if the device forget from ios . again i connected to same device its connecting and pairing and i am getting notifications. when ever i disconnected previously connected device, and i am trying to connect with another device i am unable to connect and unable to pair the device.
and I am attaching the following files
 * Copyright (c) 2012 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup ble_sdk_apple_notification_main main.c
 * @ingroup ble_sdk_app_apple_notification
 * @brief Apple Notification Client Sample Application main file. Disclaimer:
 * This client implementation of the Apple Notification Center Service can and
 * will be changed at any time by Nordic Semiconductor ASA.
 * Server implementations such as the ones found in iOS can be changed at any
 * time by Apple and may cause this client implementation to stop working.
 * This file contains the source code for a sample application using the Apple
 * Notification Center Service Client.
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble_hci.h"
#include "ble_gap.h"
#include "ble_err.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "fds.h"
#include "nrf_delay.h"
#include "app_scheduler.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "ble_db_discovery.h"
#include "nrf_ble_gatts_c.h"
#include "nrf_ble_ancs_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ATTR_DATA_SIZE                 BLE_ANCS_ATTR_DATA_MAX                 /**< Allocated size for attribute data. */
#define DISPLAY_MESSAGE_BUTTON_ID      1                                      /**< Button used to request notification attributes. */
#define DEVICE_NAME                    "ANCS"                                 /**< Name of the device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO          3                                      /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG           1                                      /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_FAST_INTERVAL          40                                     /**< The advertising interval (in units of 0.625 ms). The default value corresponds to 25 ms. */
#define APP_ADV_SLOW_INTERVAL          3200                                   /**< Slow advertising interval (in units of 0.625 ms). The default value corresponds to 2 seconds. */
#define APP_ADV_FAST_DURATION          0                                      /**< The advertising duration of fast advertising in units of 10 milliseconds. */
#define APP_ADV_SLOW_DURATION          0                                     /**< The advertising duration of slow advertising in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL              MSEC_TO_UNITS(500, UNIT_1_25_MS)       /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL              MSEC_TO_UNITS(1000, UNIT_1_25_MS)      /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                  0                                      /**< Slave latency. */
#define CONN_SUP_TIMEOUT               MSEC_TO_UNITS(4000, UNIT_10_MS)        /**< Connection supervisory time-out (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000)                  /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(30000)                 /**< Time between each call to sd_ble_gap_conn_param_update after the first (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT   3                                      /**< Number of attempts before giving up the connection parameter negotiation. */
#define MESSAGE_BUFFER_SIZE            18                                     /**< Size of buffer holding optional messages in notifications. */
#define SECURITY_REQUEST_DELAY         APP_TIMER_TICKS(1500)                  /**< Delay after connection until security request is sent, if necessary (ticks). */
#define SEC_PARAM_BOND                 1                                      /**< Perform bonding. */
#define SEC_PARAM_MITM                 0                                      /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                 0                                      /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS             0                                      /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES      BLE_GAP_IO_CAPS_NONE                   /**< No I/O capabilities. */
#define SEC_PARAM_OOB                  0                                      /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE         7                                      /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE         16                                     /**< Maximum encryption key size. */
#define DEAD_BEEF                      0xDEADBEEF                             /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE      APP_TIMER_SCHED_EVENT_DATA_SIZE        /**< Maximum size of scheduler events. */
#ifdef SVCALL_AS_NORMAL_FUNCTION
#define SCHED_QUEUE_SIZE               20                                     /**< Maximum number of events in the scheduler queue. More is needed in case of Serialization. */
#else
#define SCHED_QUEUE_SIZE               10                                     /**< Maximum number of events in the scheduler queue. */
NRF_BLE_GATTS_C_DEF(m_gatts_c);                                               /**< GATT Service client instance. Handles Service Changed indications from the peer. */
BLE_ANCS_C_DEF(m_ancs_c);                                                     /**< Apple Notification Service Client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                     /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                       /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                           /**< Advertising module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                              /**< DB Discovery module instance. */
static pm_peer_id_t      m_whitelist_peers[BLE_GAP_WHITELIST_ADDR_MAX_COUNT]; /**< List of peers currently in the whitelist. */
static uint32_t          m_whitelist_peer_cnt;                                /**< Number of peers currently in the whitelist. */
static uint16_t          m_cur_conn_handle = BLE_CONN_HANDLE_INVALID;         /**< Handle of the current connection. */
static ble_gatt_db_srv_t m_peer_srv_buf[2] = {0};                             /**< Array of services with room to store both GATT Service and ANCS. */
static bool              m_ancs_discovered  = false;                          /**< Bool to keep track of when both ancs and gatts have been disovered. Only then do we want to save the peer data. */
static bool              m_gatts_discovered = false;                          /**< Bool to keep track of when both ancs and gatts have been disovered. Only then do we want to save the peer data. */
static ble_ancs_c_evt_notif_t m_notification_latest;                          /**< Local copy to keep track of the newest arriving notifications. */
static ble_ancs_c_attr_t      m_notif_attr_latest;                            /**< Local copy of the newest notification attribute. */
static ble_ancs_c_attr_t      m_notif_attr_app_id_latest;                     /**< Local copy of the newest app attribute. */
static uint8_t m_attr_appid[ATTR_DATA_SIZE];                                  /**< Buffer to store attribute data. */
static uint8_t m_attr_title[ATTR_DATA_SIZE];                                  /**< Buffer to store attribute data. */
static uint8_t m_attr_subtitle[ATTR_DATA_SIZE];                               /**< Buffer to store attribute data. */
static uint8_t m_attr_message[ATTR_DATA_SIZE];                                /**< Buffer to store attribute data. */
static uint8_t m_attr_message_size[ATTR_DATA_SIZE];                           /**< Buffer to store attribute data. */
static uint8_t m_attr_date[ATTR_DATA_SIZE];                                   /**< Buffer to store attribute data. */
static uint8_t m_attr_posaction[ATTR_DATA_SIZE];                              /**< Buffer to store attribute data. */
static uint8_t m_attr_negaction[ATTR_DATA_SIZE];                              /**< Buffer to store attribute data. */
static uint8_t m_attr_disp_name[ATTR_DATA_SIZE];                              /**< Buffer to store attribute data. */
/**@brief String literals for the iOS notification categories. used then printing to UART. */
static char const * lit_catid[BLE_ANCS_NB_OF_CATEGORY_ID] =
		"Other",
		"Incoming Call",
		"Missed Call",
		"Voice Mail",
		"Social",
		"Schedule",
		"Email",
		"News",
		"Health And Fitness",
		"Business And Finance",
		"Location",
		"Entertainment"
/**@brief String literals for the iOS notification event types. Used then printing to UART. */
static char const * lit_eventid[BLE_ANCS_NB_OF_EVT_ID] =
		"Added",
		"Modified",
		"Removed"
/**@brief String literals for the iOS notification attribute types. Used when printing to UART. */
static char const * lit_attrid[BLE_ANCS_NB_OF_NOTIF_ATTR] =
		"App Identifier",
		"Title",
		"Subtitle",
		"Message",
		"Message Size",
		"Date",
		"Positive Action Label",
		"Negative Action Label"
/**@brief String literals for the iOS notification attribute types. Used When printing to UART. */
static char const * lit_appid[BLE_ANCS_NB_OF_APP_ATTR] =
		"Display Name"
static void delete_bonds(void);
/**@brief Callback function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and does not fit a final product.
 *          You must analyze how your product should react to asserts.
 * @warning On assert from the SoftDevice, the system can recover only on reset.
 * @param[in] line_num   Line number of the failing ASSERT call.
 * @param[in] file_name  File name of the failing ASSERT call.
/**@brief Fetch the list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
	pm_peer_id_t peer_id;
	uint32_t     peers_to_copy;
	peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
			*p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
	peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
	*p_size = 0;
	while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
		p_peers[(*p_size)++] = peer_id;
		peer_id = pm_next_peer_id_get(peer_id);
/**@brief Function for starting advertising. */
static void advertising_start(bool erase_bonds)
	if (erase_bonds == true)
		delete_bonds();
		// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
		ret_code_t ret;
		memset(m_whitelist_peers, PM_PEER_ID_INVALID, sizeof(m_whitelist_peers));
		m_whitelist_peer_cnt = (sizeof(m_whitelist_peers) / sizeof(pm_peer_id_t));
		peer_list_get(m_whitelist_peers, &m_whitelist_peer_cnt);
		ret = pm_whitelist_set(m_whitelist_peers, m_whitelist_peer_cnt);
		APP_ERROR_CHECK(ret);
		// Setup the device identies list.
		// Some SoftDevices do not support this feature.
		ret = pm_device_identities_list_set(m_whitelist_peers, m_whitelist_peer_cnt);
		if (ret != NRF_ERROR_NOT_SUPPORTED)
		ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
	ret_code_t ret;
	pm_handler_on_pm_evt(p_evt);
	pm_handler_flash_clean(p_evt);
	switch (p_evt->evt_id)
		case PM_EVT_BONDED_PEER_CONNECTED:
			if (p_evt->peer_id != PM_PEER_ID_INVALID)
				uint16_t data_len = sizeof(m_peer_srv_buf);
				ret = pm_peer_data_remote_db_load(p_evt->peer_id, m_peer_srv_buf, &data_len);
				if (ret == NRF_ERROR_NOT_FOUND)
					NRF_LOG_DEBUG("Could not find the remote database in flash.");
					ret = nrf_ble_gatts_c_handles_assign(&m_gatts_c, p_evt->conn_handle, NULL);
					// Discover peer's services.
					memset(&m_db_disc, 0x00, sizeof(m_db_disc));
					ret = ble_db_discovery_start(&m_db_disc, p_evt->conn_handle);
					// Check if the load was successful.
					ASSERT(data_len == sizeof(m_peer_srv_buf));
					NRF_LOG_INFO("Remote Database loaded from flash.");
					// Assign the loaded handles to the GATT Service client module.
					ble_gatt_db_char_t srv_changed_handles = m_peer_srv_buf[0].charateristics[0];
							p_evt->conn_handle,
							&srv_changed_handles);
					// Enable indications.
					ret = nrf_ble_gatts_c_enable_indication(&m_gatts_c, true);
					//Load the relevant handles into a ble_ancs_c_service_t struct that can be
					// assigned to the ANCS module.
					ble_ancs_c_service_t ancs_handles;
					ble_gatt_db_char_t * p_char           = m_peer_srv_buf[1].charateristics;
					ancs_handles.control_point_char       = p_char[0].characteristic;
					ancs_handles.notif_source_char        = p_char[1].characteristic;
					ancs_handles.notif_source_cccd.handle = p_char[1].cccd_handle;
					ancs_handles.data_source_char         = p_char[2].characteristic;
					ancs_handles.data_source_cccd.handle  = p_char[2].cccd_handle;
					ret = nrf_ble_ancs_c_handles_assign(&m_ancs_c, p_evt->conn_handle,
							&ancs_handles);
		} break;
		case PM_EVT_CONN_SEC_SUCCEEDED:
			NRF_LOG_INFO("PM_EVT_CONN_SEC_SUCCEEDED");
			// Check it the Service Changed characteristic handle exists in our client instance.
			// If it is invalid, we know service discovery is needed.
			// (No database was loaded during @ref PM_EVT_BONDED_PEER_CONNECTED)
			if (m_gatts_c.srv_changed_char.characteristic.handle_value == BLE_GATT_HANDLE_INVALID)
				if (ret != NRF_ERROR_BUSY)
		} break;
			advertising_start(false);
		} break;
		case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
			// Note: You should check on what kind of white list policy your application should use.
			if ( p_evt->params.peer_data_update_succeeded.flash_changed && (p_evt->params.peer_data_update_succeeded.data_id == PM_PEER_DATA_ID_BONDING))
				NRF_LOG_DEBUG("New Bond, add the peer to the whitelist if possible");
				NRF_LOG_DEBUG("\tm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d",m_whitelist_peer_cnt + 1,BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
				if (m_whitelist_peer_cnt < BLE_GAP_WHITELIST_ADDR_MAX_COUNT)
					// Bonded to a new peer, add it to the whitelist.
					m_whitelist_peers[m_whitelist_peer_cnt++] = p_evt->peer_id;
					// The whitelist has been modified, update it in the Peer Manager.
					if (ret == BLE_ERROR_GAP_DEVICE_IDENTITIES_DUPLICATE)
						m_whitelist_peers[--m_whitelist_peer_cnt] = PM_PEER_ID_INVALID;
					else if (ret != NRF_ERROR_NOT_SUPPORTED)
					NRF_LOG_HEXDUMP_INFO(m_whitelist_peers, sizeof(m_whitelist_peers));
		} break;
		} break;
/**@brief Function for setting up GATTC notifications from the Notification Provider.
 * @details This function is called when a successful connection has been established.
static void apple_notification_setup(void)
	ret_code_t ret;
	nrf_delay_ms(100); // Delay because we cannot add a CCCD to close to starting encryption. iOS specific.
	ret = ble_ancs_c_notif_source_notif_enable(&m_ancs_c);
	ret = ble_ancs_c_data_source_notif_enable(&m_ancs_c);
	NRF_LOG_DEBUG("Notifications Enabled.");
/**@brief Function for printing an iOS notification.
 * @param[in] p_notif  Pointer to the iOS notification.
static void notif_print(ble_ancs_c_evt_notif_t * p_notif)
	NRF_LOG_INFO("\r\nNotification");
	NRF_LOG_INFO("Event:       %s", (uint32_t)lit_eventid[p_notif->evt_id]);
	NRF_LOG_INFO("Category ID: %s", (uint32_t)lit_catid[p_notif->category_id]);
	NRF_LOG_INFO("Category Cnt:%u", (unsigned int) p_notif->category_count);
	NRF_LOG_INFO("UID:         %u", (unsigned int) p_notif->notif_uid);
	NRF_LOG_INFO("Flags:");
	if (p_notif->evt_flags.silent == 1)
		NRF_LOG_INFO(" Silent");
	if (p_notif->evt_flags.important == 1)
		NRF_LOG_INFO(" Important");
	if (p_notif->evt_flags.pre_existing == 1)
		NRF_LOG_INFO(" Pre-existing");
	if (p_notif->evt_flags.positive_action == 1)
		NRF_LOG_INFO(" Positive Action");
	if (p_notif->evt_flags.negative_action == 1)
		NRF_LOG_INFO(" Negative Action");
/**@brief Function for printing iOS notification attribute data.
 * @param[in] p_attr Pointer to an iOS notification attribute.
static void notif_attr_print(ble_ancs_c_attr_t * p_attr)
	if (p_attr->attr_len != 0)
		NRF_LOG_INFO("%s: %s", (uint32_t)lit_attrid[p_attr->attr_id],
				nrf_log_push((char *)p_attr->p_attr_data));
	else if (p_attr->attr_len == 0)
		NRF_LOG_INFO("%s: (N/A)", (uint32_t)lit_attrid[p_attr->attr_id]);
 * @param[in] p_attr Pointer to an iOS App attribute.
static void app_attr_print(ble_ancs_c_attr_t * p_attr)
		NRF_LOG_INFO("%s: %s", (uint32_t)lit_appid[p_attr->attr_id], (uint32_t)p_attr->p_attr_data);
		NRF_LOG_INFO("%s: (N/A)", (uint32_t) lit_appid[p_attr->attr_id]);
/**@brief Function for printing out errors that originated from the Notification Provider (iOS).
 * @param[in] err_code_np Error code received from NP.
static void err_code_print(uint16_t err_code_np)
	switch (err_code_np)
		case BLE_ANCS_NP_UNKNOWN_COMMAND:
			NRF_LOG_INFO("Error: Command ID was not recognized by the Notification Provider. ");
		case BLE_ANCS_NP_INVALID_COMMAND:
			NRF_LOG_INFO("Error: Command failed to be parsed on the Notification Provider. ");
		case BLE_ANCS_NP_INVALID_PARAMETER:
			NRF_LOG_INFO("Error: Parameter does not refer to an existing object on the Notification Provider. ");
		case BLE_ANCS_NP_ACTION_FAILED:
			NRF_LOG_INFO("Error: Perform Notification Action Failed on the Notification Provider. ");
/**@brief Function for initializing the timer module.
static void timers_init(void)
	ret_code_t ret;
	ret = app_timer_init();
/**@brief Function for handling events from the GATT Servive client module.
   @param[in] p_evt GATT Service event.
static void gatts_c_evt_handler(nrf_ble_gatts_c_evt_t * p_evt)
	ret_code_t ret = NRF_SUCCESS;
	switch (p_evt->evt_type)
		case NRF_BLE_GATTS_C_EVT_DISCOVERY_COMPLETE:
			NRF_LOG_DEBUG("GATT Service and Service Changed characteristic found on server.");
					p_evt->conn_handle,
					&p_evt->params.srv_changed_char);
			ret = pm_peer_id_get(p_evt->conn_handle, &peer_id);
			memset(&m_peer_srv_buf[0], 0, sizeof(m_peer_srv_buf[0]));
			m_peer_srv_buf[0].charateristics[0] = p_evt->params.srv_changed_char;
			m_gatts_discovered = true;
			if(m_gatts_discovered && m_ancs_discovered)
				ret = pm_peer_data_remote_db_store(peer_id,
						(ble_gatt_db_srv_t *)m_peer_srv_buf,
						sizeof(m_peer_srv_buf),
						NULL);
				if (ret == NRF_ERROR_STORAGE_FULL)
					ret = fds_gc();
		} break;
		case NRF_BLE_GATTS_C_EVT_DISCOVERY_FAILED:
			NRF_LOG_DEBUG("GATT Service or Service Changed characteristic not found on server.");
		case NRF_BLE_GATTS_C_EVT_DISCONN_COMPLETE:
			NRF_LOG_DEBUG("GATTS Service client disconnected connection handle %i.",
		case NRF_BLE_GATTS_C_EVT_SRV_CHANGED:
			NRF_LOG_DEBUG("Service Changed indication received.");
/**@brief Function for handling the Apple Notification Service client.
 * @details This function is called for all events in the Apple Notification client that
 *          are passed to the application.
 * @param[in] p_evt  Event received from the Apple Notification Service client.
static void ancs_c_evt_handler(ble_ancs_c_evt_t * p_evt)
		case BLE_ANCS_C_EVT_DISCOVERY_COMPLETE:
			NRF_LOG_DEBUG("Apple Notification Center Service discovered on the server.");
			ret = nrf_ble_ancs_c_handles_assign(&m_ancs_c, p_evt->conn_handle, &p_evt->service);
			// Copy the needed ANCS handles into a ble_gatt_db_srv_t struct that will be stored in
			// flash.
			memset(&m_peer_srv_buf[1], 0, sizeof(m_peer_srv_buf[1]));
			p_char[0].characteristic = p_evt->service.control_point_char;
			p_char[1].characteristic = p_evt->service.notif_source_char;
			p_char[1].cccd_handle    = p_evt->service.notif_source_cccd.handle;
			p_char[2].characteristic = p_evt->service.data_source_char;
			p_char[2].cccd_handle    = p_evt->service.data_source_cccd.handle;
			m_ancs_discovered = true;
			if (m_gatts_discovered && m_ancs_discovered)
						NULL);
					ret = fds_gc();
			apple_notification_setup();
		} break;
		case BLE_ANCS_C_EVT_NOTIF:
			m_notification_latest = p_evt->notif;
			notif_print(&m_notification_latest);
		case BLE_ANCS_C_EVT_NOTIF_ATTRIBUTE:
			m_notif_attr_latest = p_evt->attr;
			notif_attr_print(&m_notif_attr_latest);
			if (p_evt->attr.attr_id == BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER)
				m_notif_attr_app_id_latest = p_evt->attr;
		case BLE_ANCS_C_EVT_DISCOVERY_FAILED:
			NRF_LOG_DEBUG("Apple Notification Center Service not discovered on the server.");
		case BLE_ANCS_C_EVT_APP_ATTRIBUTE:
			app_attr_print(&p_evt->attr);
		case BLE_ANCS_C_EVT_NP_ERROR:
			err_code_print(p_evt->err_code_np);
			// No implementation needed.
/**@brief Function for initializing GAP connection parameters.
 * @details Use this function to set up all necessary GAP (Generic Access Profile)
 *          parameters of the device. It also sets the permissions and appearance.
	ret_code_t              ret;
	ret = sd_ble_gap_device_name_set(&sec_mode, (const uint8_t *)DEVICE_NAME, strlen(DEVICE_NAME));
	ret = sd_ble_gap_ppcp_set(&gap_conn_params);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
	ret_code_t ret = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for handling the Apple Notification Service client errors.
static void apple_notification_error_handler(uint32_t nrf_error)
	APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling a Connection Parameters error.
	ret_code_t             ret;
	cp_init.disconnect_on_fail             = true;
	cp_init.evt_handler                    = NULL;
	ret = ble_conn_params_init(&cp_init);
/**@brief Function for handling Database Discovery events.
 * @details This function is a callback function to handle events from the database discovery
 *          module. Depending on the UUIDs that are discovered, this function should forward the
 *          events to their respective service instances.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
	ble_ancs_c_on_db_disc_evt(&m_ancs_c, p_evt);
	nrf_ble_gatts_c_on_db_disc_evt(&m_gatts_c, p_evt);
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
	ret_code_t           ret;
	ret = pm_init();
	sec_param.bond           = SEC_PARAM_BOND;
	sec_param.mitm           = SEC_PARAM_MITM;
	sec_param.lesc           = SEC_PARAM_LESC;
	sec_param.keypress       = SEC_PARAM_KEYPRESS;
	sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
	sec_param.oob            = SEC_PARAM_OOB;
	sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
	sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
	sec_param.kdist_own.enc  = 1;
	sec_param.kdist_own.id   = 1;
	sec_param.kdist_peer.enc = 1;
	sec_param.kdist_peer.id  = 1;
	ret = pm_sec_params_set(&sec_param);
	ret = pm_register(pm_evt_handler);
 * @brief Delete all data stored for all peers.
	ret_code_t err_code;
	NRF_LOG_INFO("Erase bonds!");
	err_code = pm_peers_delete();
	uint32_t ret = bsp_indication_set(BSP_INDICATE_IDLE);
	// Prepare wakeup buttons.
	ret = bsp_btn_ble_sleep_mode_prepare();
	ret = sd_power_system_off();
 * @details This function is called for advertising events that are passed to the application.
	ret_code_t ret;
	switch (ble_adv_evt)
		case BLE_ADV_EVT_FAST:
			NRF_LOG_INFO("Fast advertising");
			ret = bsp_indication_set(BSP_INDICATE_ADVERTISING);
		case BLE_ADV_EVT_SLOW:
			NRF_LOG_INFO("Slow advertising");
			ret = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
		case BLE_ADV_EVT_FAST_WHITELIST:
			NRF_LOG_INFO("Fast advertising with Whitelist");
			ret = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
		case BLE_ADV_EVT_IDLE:
			sleep_mode_enter();
		case BLE_ADV_EVT_WHITELIST_REQUEST:
			ble_gap_addr_t whitelist_addrs[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
			ble_gap_irk_t  whitelist_irks[BLE_GAP_WHITELIST_ADDR_MAX_COUNT];
			uint32_t       addr_cnt = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
			uint32_t       irk_cnt  = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
			ret = pm_whitelist_get(whitelist_addrs, &addr_cnt, whitelist_irks, &irk_cnt);
			NRF_LOG_DEBUG("pm_whitelist_get returns %d addr in whitelist and %d irk whitelist",
					addr_cnt,
					irk_cnt);
			// Apply the whitelist.
			ret = ble_advertising_whitelist_reply(&m_advertising,
					whitelist_addrs,
					addr_cnt,
					whitelist_irks,
					irk_cnt);
	pm_handler_secure_on_connection(p_ble_evt);
		case BLE_GAP_EVT_CONNECTED:
			NRF_LOG_INFO("Connected.");
			ret = bsp_indication_set(BSP_INDICATE_CONNECTED);
			m_cur_conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
			ret = nrf_ble_qwr_conn_handle_assign(&m_qwr, m_cur_conn_handle);
			NRF_LOG_INFO("Disconnected.");
			if (p_ble_evt->evt.gap_evt.conn_handle == m_ancs_c.conn_handle)
				m_ancs_c.conn_handle = BLE_CONN_HANDLE_INVALID;
			break; // BLE_GAP_EVT_DISCONNECTED
			ble_gap_phys_t const phys =
					.rx_phys = BLE_GAP_PHY_AUTO,
					.tx_phys = BLE_GAP_PHY_AUTO,
			ret = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
		} break;
		case BLE_GATTC_EVT_TIMEOUT:
			ret = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle,
		case BLE_GATTS_EVT_TIMEOUT:
			ret = sd_ble_gap_disconnect(p_ble_evt->evt.gatts_evt.conn_handle,
 * @param[in] event  Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
	ret_code_t ret;
	switch (event)
		case BSP_EVENT_SLEEP:
			sleep_mode_enter();
		case BSP_EVENT_DISCONNECT:
			ret = sd_ble_gap_disconnect(m_cur_conn_handle,
			if (ret != NRF_ERROR_INVALID_STATE)
		case BSP_EVENT_WHITELIST_OFF:
			if (m_ancs_c.conn_handle == BLE_CONN_HANDLE_INVALID)
				ret = ble_advertising_restart_without_whitelist(&m_advertising);
		case BSP_EVENT_KEY_0:
			ret = nrf_ble_ancs_c_request_attrs(&m_ancs_c, &m_notification_latest);
		case BSP_EVENT_KEY_1:
			if (m_notif_attr_app_id_latest.attr_id == BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER
					&& m_notif_attr_app_id_latest.attr_len != 0)
				NRF_LOG_INFO("Request for %s: ", (uint32_t)m_notif_attr_app_id_latest.p_attr_data);
				ret = nrf_ble_ancs_c_app_attr_request(&m_ancs_c,
						m_notif_attr_app_id_latest.p_attr_data,
						m_notif_attr_app_id_latest.attr_len);
		case BSP_EVENT_KEY_2:
			if (m_notification_latest.evt_flags.positive_action == true)
				NRF_LOG_INFO("Performing Positive Action.");
				ret = nrf_ancs_perform_notif_action(&m_ancs_c,
						m_notification_latest.notif_uid,
						ACTION_ID_POSITIVE);
		case BSP_EVENT_KEY_3:
			if (m_notification_latest.evt_flags.negative_action == true)
				NRF_LOG_INFO("Performing Negative Action.");
						ACTION_ID_NEGATIVE);
	uint32_t ram_start = 0;
	// Enable BLE stack.
	ret_code_t             ret;
	ble_ancs_c_init_t      ancs_c_init;
	nrf_ble_gatts_c_init_t gatts_c_init;
	ret = nrf_ble_qwr_init(&m_qwr, &qwr_init);
	// Init the GATTS client module.
	memset(&gatts_c_init, 0, sizeof(gatts_c_init));
	gatts_c_init.evt_handler = gatts_c_evt_handler;
	ret = nrf_ble_gatts_c_init(&m_gatts_c, &gatts_c_init);
	// Init the Apple Notification Center Service client module.
	memset(&ancs_c_init, 0, sizeof(ancs_c_init));
	ret = nrf_ble_ancs_c_attr_add(&m_ancs_c,
			BLE_ANCS_NOTIF_ATTR_ID_APP_IDENTIFIER,
			m_attr_appid,
			ATTR_DATA_SIZE);
	ret = nrf_ble_ancs_c_app_attr_add(&m_ancs_c,
			BLE_ANCS_APP_ATTR_ID_DISPLAY_NAME,
			m_attr_disp_name,
			sizeof(m_attr_disp_name));
			BLE_ANCS_NOTIF_ATTR_ID_TITLE,
			m_attr_title,
			ATTR_DATA_SIZE);
			BLE_ANCS_NOTIF_ATTR_ID_MESSAGE,
			m_attr_message,
			ATTR_DATA_SIZE);
			BLE_ANCS_NOTIF_ATTR_ID_SUBTITLE,
			m_attr_subtitle,
			ATTR_DATA_SIZE);
			BLE_ANCS_NOTIF_ATTR_ID_MESSAGE_SIZE,
			m_attr_message_size,
			ATTR_DATA_SIZE);
			BLE_ANCS_NOTIF_ATTR_ID_DATE,
			m_attr_date,
			ATTR_DATA_SIZE);
			BLE_ANCS_NOTIF_ATTR_ID_POSITIVE_ACTION_LABEL,
			m_attr_posaction,
			ATTR_DATA_SIZE);
			BLE_ANCS_NOTIF_ATTR_ID_NEGATIVE_ACTION_LABEL,
			m_attr_negaction,
			ATTR_DATA_SIZE);
	ancs_c_init.evt_handler   = ancs_c_evt_handler;
	ancs_c_init.error_handler = apple_notification_error_handler;
	ret = ble_ancs_c_init(&m_ancs_c, &ancs_c_init);
/**@brief Function for initializing the advertising functionality.
	ret_code_t             ret;
	ble_advertising_init_t init;
	static ble_uuid_t m_adv_uuids[1]; /**< Universally unique service identifiers. */
	m_adv_uuids[0].uuid = ANCS_UUID_SERVICE;
	m_adv_uuids[0].type = m_ancs_c.service.service.uuid.type;
	init.advdata.name_type                = BLE_ADVDATA_FULL_NAME;
	init.advdata.include_appearance       = true;
	init.advdata.flags                    = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
	init.advdata.uuids_complete.uuid_cnt  = 0;
	init.advdata.uuids_complete.p_uuids   = NULL;
	init.advdata.uuids_solicited.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
	init.advdata.uuids_solicited.p_uuids  = m_adv_uuids;
	init.config.ble_adv_whitelist_enabled = true;
	init.config.ble_adv_fast_enabled      = true;
	init.config.ble_adv_fast_interval     = APP_ADV_FAST_INTERVAL;
	init.config.ble_adv_fast_timeout      = APP_ADV_FAST_DURATION;
	init.config.ble_adv_slow_enabled      = true;
	init.config.ble_adv_slow_interval     = APP_ADV_SLOW_INTERVAL;
	init.config.ble_adv_slow_timeout      = APP_ADV_SLOW_DURATION;
	ret = ble_advertising_init(&m_advertising, &init);
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  True if the clear bonds button was pressed to wake the application up.
	uint32_t ret;
	bsp_event_t startup_event;
	ret = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
	ret = bsp_btn_ble_init(NULL, &startup_event);
/**@brief Function for initializing the Event Scheduler.
static void scheduler_init(void)
	APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
/**@brief Function for initializing the database discovery module.
static void db_discovery_init(void)
	ret_code_t ret = ble_db_discovery_init(db_disc_handler);
static void log_init(void)
	ret_code_t ret = NRF_LOG_INIT(NULL);
	app_sched_execute();
		nrf_pwr_mgmt_run();
/**@brief Function for application main entry.
	bool erase_bonds;
	// Initialize.
	log_init();
	timers_init();
	scheduler_init();
	power_management_init();
	ble_stack_init();
	gap_params_init();
	gatt_init();
	db_discovery_init();
	services_init();
	advertising_init();
	conn_params_init();
	peer_manager_init();
	// Start execution.
	NRF_LOG_INFO("Apple Notification Center Service client example started.");
	advertising_start(erase_bonds);
	// Enter main loop.
	for (;;)
		idle_state_handle();
sdk_config.h
please help me out this problem
  • Hi.
    So you are not able to connect or pair with another device after disconnecting from the first device you paired with?
    Did you delete the bond information before trying to connect to a new device?
    Have you made sure that your device isn't advertising with a whitelist after disconnecting the first device?
    Are the maximum allowed bonds, BLE_GAP_WHITELIST_ADDR_MAX_COUNT > 1?
  • Hey Joakim,
       Here is the snippet I am using to avoid my problem. The problem seems to be advertising whitelist reply. This holds the boards to only connected to already connected peered device and was not able to pair with other devices, to do so either we were erasing peered devices or connecting to same paired devices.
    Solution: Fast advertising mode
                   Not Fast advertising with whitelist
    memset(whitelist_addrs,0x00,sizeof(whitelist_addrs));
    #if DEBUG_MAIN
    printf("\npm_whitelist_get returns %d addr in whitelist and %d irk whitelist\r\n", addr_cnt, irk_cnt);
    for(uint8_t i = 0; i<8; i++)
    for(int j =5; j>=0;j--)
    printf("%02x,",whitelist_addrs[i].addr[j]);
    printf("\n");
    /*ret = ble_advertising_whitelist_reply(&m_advertising,
    whitelist_addrs,
    addr_cnt,
    whitelist_irks,
    irk_cnt);
    APP_ERROR_CHECK(ret);*/
    }break;
    #if DEBUG_MAIN
    printf("\nNew Bond, add the peer to the whitelist if possible\n");
    printf("\nm_whitelist_peer_cnt %d, MAX_PEERS_WLIST %d\n", m_whitelist_peer_cnt + 1, BLE_GAP_WHITELIST_ADDR_MAX_COUNT);
    uint16_t dummy_peer_id = p_evt->peer_id;
    if(dummy_peer_id == m_whitelist_peers[i])
    else if(m_whitelist_peers[i] == 0xffff)
    m_whitelist_peers[i] = dummy_peer_id;
    m_whitelist_peer_cnt = m_whitelist_peer_cnt + 1;
    //printf("ith value:%d\n",i);
    // ret = pm_device_identities_list_set(m_whitelist_peers, (uint32_t )i);
    // APP_ERROR_CHECK(ret);
    // ret = pm_whitelist_set(m_whitelist_peers, (uint32_t )i);
    //peer_list_get(m_whitelist_peers, &m_whitelist_peer_cnt);
    //m_whitelist_peers[m_whitelist_peer_cnt] = p_evt->peer_id;
    //ret = pm_device_identities_list_set(m_whitelist_peers, m_whitelist_peer_cnt);
    /*if (ret == BLE_ERROR_GAP_DEVICE_IDENTITIES_DUPLICATE)
    printf("\nDUPLICATE ID FOUND----------------->>>>>>\n");
    printf("\nNRF_ERROR_NOT_SUPPORTED\n");
    //printf("\nm_whitelist_peer_cnt------------------------>>%d\n", pm_peer_count());
    //m_whitelist_peer_cnt = pm_peer_count();
    // ret = pm_whitelist_set(m_whitelist_peers, m_whitelist_peer_cnt);
    //m_whitelist_peer_cnt = m_whitelist_peer_cnt + 1;
    #if DEBUG_MAIN
    printf("%04x\n", m_whitelist_peers[i]);
    } break;
    iadded this to peer manger event handler
    } break;
  • hi Joakim
    I want to generate a custom delay of one microsecond  without using any timers By simply Executing instructions I want to generate is there any possibility please let me know
  • Could you please create a new ticket about this?
    Joakim
