I want to use nRF51822 to read smart card signal, and smart card need clock signal input. Thanks.
You can use a timer and toggle a gpio. The following example will generate a 4MHz signal on a gpio. It uses only HW peripherals.
Alternatively, you can configure the SPI to output a 4 MHz clock signal, but then you need to constantly write dummy data to the TXD register.
#include "nrf.h"
#include "nrf_gpiote.h"
#include "bsp.h"
#define OUTPUT_PIN_NUMBER (1)
// Configure OUTPUT_PIN_NUMBER as an output.
nrf_gpio_cfg_output(OUTPUT_PIN_NUMBER);
// Configure GPIOTE channel 0 to toggle the pin state
nrf_gpiote_task_config(0, OUTPUT_PIN_NUMBER, \
NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIOTE_INITIAL_VALUE_LOW);
// Configure PPI channel 0 to toggle OUTPUT_PIN on every TIMER2 COMPARE[0] match.
NRF_PPI->CH[0].EEP = (uint32_t)&NRF_TIMER2->EVENTS_COMPARE[0];
NRF_PPI->CH[0].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0];
// Enable PPI channel 0
NRF_PPI->CHEN = (PPI_CHEN_CH0_Enabled << PPI_CHEN_CH0_Pos);
// Start 16 MHz crystal oscillator .
// Wait for the external oscillator to start up.
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0){}
// Configure timer 2
NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos;
NRF_TIMER2->PRESCALER = 0;
NRF_TIMER2->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
// Clears the timer, sets it to 0.
NRF_TIMER2->TASKS_CLEAR = 1;
// Load the initial values to TIMER2 CC registers.
NRF_TIMER2->CC[0] = 2;
// Start the timer
NRF_TIMER2->TASKS_START = 1;
for(;;){}
Thanks for the example but I think the PPI task needs to be enabled otherwise it wouldn't work. I think you need the following:
nrf_gpiote_task_configure(0, OUTPUT_PIN_NUMBER, \
nrf_gpiote_task_enable(OUTPUT_PIN_NUMBER); // add this
