I am using 3 axis LIS2D12H accelerometer interfaced with NRF51832 with SPI interface. The sensor has sampling rate from 1 HZ to 5.376 KHz which is happening at sensor only. I am taking sensor data at 400 Hz by setting register values in sensor. I am implementing FFT algorithm in microcontroller over a raw sensor data received by 3 axis for vibration analysis. I can have resolution of FFT from 64 to 2048. My confusion is how should I sample it at microcontroller for FFT, there are FFT function in ARM cortex which I am using. Shall I take raw samples in buffer and sample them or shall I take each reading from sensor and sample them individually. If that is the case how shall I select sampling frequency at microcontroller level and/or at what rate microcontroller shall read data
